IRIX 6.5.15m and upgrading
Re: IRIX 6.5.15m and upgrading
Unread postby robespierre » Mon May 29, 2017 6:57 am
ide doesn't need to be in the volume header, since it can be loaded from the filesystem with sash. It's used rarely enough that the additional steps aren't a problem (need to enter the command prompt and type "boot usr/stand/ide" instead of just clicking "diagnostics")
mazzinia
Unread postby mazzinia » Mon May 29, 2017 7:59 am
sorry to say, but
/usr/stand
doesn't exist on the disk ( I dumped the list of everything )
The only stand present is in the root
/stand
with fx and sash inside ( and now with symmon, too )
Unread postby foetz » Mon May 29, 2017 2:38 pm
mazzinia wrote:mmm I did initialize the disk using the graphical disk manager (aka there's a label)... but now I'm not sure if I did partition it
for low level stuff your best bet always is the terminal. here's how you prepare a disk as system disk:
# fx -x
fx version 6.5, Oct  6, 2003
fx: "device-name" = (dksc)
fx: ctlr# = (0)
fx: drive# = (1) 3
fx: lun# = (0)
...opening dksc(0,3,0)
----- please choose one (? for help, .. to quit this menu)-----
[exi]t             [d]ebug/           [l]abel/           [a]uto
[b]adblock/        [exe]rcise/        [r]epartition/
fx> r
[ro]otdrive        [u]srrootdrive     [o]ptiondrive      [re]size
fx/repartition> ro
fx/repartition/rootdrive: type of data partition = (xfs)
Warning: you will need to re-install all software and restore user data
from backups after changing the partition layout.  Changing partitions
will cause all data on the drive to be lost.  Be sure you have the drive
backed up if it contains any user data.  Continue? y
fx/repartition> /l
[sh]ow/         [sy]nc          [se]t/          [c]reate/
fx/label> sy
fx/label> /exi
then format it:
mkfs /hw/rdisk/dks0d3s0
up next: the volume header
cd /stand
dvhtool -v creat sash sash /dev/rdsk/dks0d3vh
dvhtool -v creat ide ide /dev/rdsk/dks0d3vh
replace the s0d3 parts with whatever you need. the s0 is the controller number and the d3 is the disk id.
now mount the disk's s0 partition (dks0d3s0 in the example here) and start dragging the data over. xfsdump/restore is the recommended way but tar, cpio and alike should work as well.
after that unmount the disk and you're good to go :-)
mazzinia
Unread postby mazzinia » Mon May 29, 2017 3:00 pm
in theory those 3 steps were done
gui to initialize and put a label
script formatted and copied the header ( sash and symmon, in my case )
I checked the headers of the 2, and were identical
the only step I think I forgot to do, was to check the source partitioning, and to repartition the target
mazzinia
Unread postby mazzinia » Tue May 30, 2017 6:12 am
mmmm, indeed the 2 partitions are not identical
sgi115 2# prtvtoc
Printing label for root disk
* /dev/root (bootfile "/unix")
* 512 bytes/sector
* Unallocated space:
* Start Size
* 35546876 296794
Partition Type Fs Start: sec Size: sec Mount Directory
0 xfs yes 8392704 27154172
1 raw 4096 8388608
8 volhdr 0 4096
10 volume 0 35843670
sgi115 3# prtvtoc /dev/rdsk/dks0d9vh
* /dev/rdsk/dks0d9vh (bootfile "/unix")
* 512 bytes/sector
7 xfs yes 4096 71128863
8 volhdr 0 4096
10 volume 0 71132959
sgi115 4#
