Forum bug (arrows in code tags break posts)
Y888099
Re: Forum bug (arrows in code tags break posts)
Unread postby Y888099 » Fri May 12, 2017 3:36 am
Raion-Fox wrote:Windows sucks at localization
It's English, but this version of Windows(1) appears of having been modified when the previous owner installed Altium-R14, which is known to be invasive. Might be the same reason for Xilinx ISE, OrCAD, TinaDesign ... all the software I installed after the purchase. All of these applications required additional packages and RegBin modification. I set them English, but Altium came already installed when I bought the workstation, the previous owner is French. Perhaps it's a clue.
I need to try from a different PC.
(1) System Properties says "Windows XP, manufactured by IBM, supported by Altium Limited", never opened this panel, never noticed before. WTF? :shock:
Hakimoto
Unread postby Hakimoto » Sat May 13, 2017 1:58 am
OK, I think then we can all agree that the bug is not with the forum software...
grace, elegance and style.
Y888099
Unread postby Y888099 » Sat May 13, 2017 4:23 am
Hakimoto wrote:OK, I think then we can all agree that the bug is not with the forum software...
Not sure, it doesn't happen on other forums, e.g. on EEvBlogs where I have never experimented strange behaviors when put things between [ code ] ... [ / code ]. Including bash and C code, which happens to have a lot of arrows.
btw, to cut the story short with Nekochan, I have already set up a "filter script" (based on 'sed') removing all the poisoned patterns from my edit-board. In case of need I will use the attach function to attach a file.
Unread postby josehill » Sat May 13, 2017 12:01 pm
Are you using a "code=php" tag instead of a simple "code" tag?
Y888099
Unread postby Y888099 » Sat May 13, 2017 12:11 pm
josehill wrote:Are you using a "code=php" tag instead of a simple "code" tag?
Simple "code" tag.
Unread postby josehill » Sat May 13, 2017 12:44 pm
Y888099 wrote:Simple "code" tag.
Since nobody else here has been able to duplicate your issue, I suggest that you go to the phpBB website to see if anyone has filed a bug report that matches your issue. https://tracker.phpbb.com
If there are no such reports, then consider filing your own bug report, providing detailed information about your local posting environment and the explicit steps you take when you experience your problem.
For example, here is a report that seems similar to your issue, but it appears when using the "php" qualifier in the "code" tag and does not appear when the qualifier is not used. https://tracker.phpbb.com/browse/PHPBB3-9105
Return to “Nekochan Net”
