SoftImage|3d install
praetor242
Unread postby praetor242 » Fri Apr 14, 2017 9:17 pm
I I think I'm going to take a break from porting and try my hand at 3D work. SoftImage is enticing because of how many movies its done, but I'm having a problem.
I have SoftImage and a license, but if I try to install the license server, it fails. I'm not sure why because IRIX already has FlexLm, but if I try to import the license, it doesn't see it.
How do I get SI to see the license I have?
Re: SoftImage|3d install
Unread postby uunix » Sat Apr 15, 2017 12:48 am
iirc, the flexlm licence goes in a different place than normal. I will check for you.
[Edit]My licence is located at /usr/Softimage/Flexlm/licenses/softimage.lic
SiliconClassics
Unread postby SiliconClassics » Sat Apr 15, 2017 5:32 am
No need for a license server - just follow the instructions I posted in this thread:
viewtopic.php?t=16722455
praetor242
Unread postby praetor242 » Sat Apr 15, 2017 10:59 am
Oh sweet! Thanks alot :D
praetor242
Unread postby praetor242 » Sun Apr 16, 2017 12:15 pm
I got it all working :D But damned, it is super intimidating. I need to find some good tutorials for it.
Unread postby foetz » Sun Apr 16, 2017 12:29 pm
we have quite some vet softies here. if you're stuck at something specific somebody should be able to help you out
praetor242
Unread postby praetor242 » Sun Apr 16, 2017 12:51 pm
I discovered how to make a cube :D
Unread postby foetz » Sun Apr 16, 2017 4:00 pm
praetor242 wrote:I discovered how to make a cube :D
all sorted then :P
SiliconClassics
Unread postby SiliconClassics » Mon Apr 17, 2017 5:31 am
Jeremy Birn has a bunch of beginner Soft|3D tutorials on his web site. So does Ed Harriss. Probably a good place to start. There's also a New Riders book called "Inside Softimage|3D" that is probably the best guide aside from the original user's manuals. It goes for about $5 on eBay.
Users browsing this forum: vishnu and 1 guest
