Indigo2 R10K/195MHz| 1GB | HI-AA w/ TRAM | EISA 100Mb | I2 Video
archaic
Unread postby archaic » Wed Mar 22, 2017 8:22 pm
1 195 MHZ IP28 Processor
Main memory size: 1024 Mbytes
  Tape drive: unit 2 on SCSI controller 0: DAT
On-board serial ports: 2
Graphics board: High-AA Impact/TRAM option card
Indigo2 video (ev1): unit 0, revision 4.
EISA bus: adapter 0
   Product ID 0x0, 2 GEs, 1 RE, 4 TRAMs
   VC3 rev A, CMAP rev DMC rev D
   21" monitor (id 0xb)
   Video board present
    Video Format Flags:  (none)
    Sync Disabled
    Using Gamma Map 0
Patrick
- You have got to be kidding... -
Re: Indigo2 R10K/195MHz| 1GB | HI-AA w/ TRAM | EISA 100Mb | I2 Video
Unread postby Trippynet » Thu Mar 23, 2017 1:43 am
Nice little system you've got there, very nice in fact! Any chance of some pictures?
Unread postby vishnu » Fri Mar 24, 2017 10:22 am
A gig of ram! And a tape drive! Nice... :mrgreen:
archaic
Unread postby archaic » Thu Mar 30, 2017 6:38 pm
Trippynet wrote:Nice little system you've got there, very nice in fact! Any chance of some pictures?
I am currently having an issue with my photobucket. I will get some pictures posted up later.
Patrick
Patrick
