Octane V12 2x600MHz 1GB
Unread postby uunix » Sat Mar 18, 2017 1:00 pm
So some time back I brought a single 300MHz Octane with V8 from chickenue.
Well thanks to jmc, it has been upgraded today.
OCTANE03 1# hinv -v
2 600 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 1024 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V12
Dual Channel Display
OCTANE03 2# /usr/gfx/gfxinfo
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
        Dual Channel Display option
         Monitor 1 type: Unknown         Monitor 2 type: Unknown
Monday, I have another upgrade to an Octane2 with 1.3 XBOW with some interesting stuff.
Re: Octane V12 2x600MHz 1GB
Unread postby vishnu » Mon Mar 20, 2017 7:25 am
Ah! The dreaded Dual Channel Display option, do you have it working?
Unread postby recondas » Mon Mar 20, 2017 4:17 pm
Nice Octane, congratulations.
