Alphastation 500 don't post
jammaster
Unread postby jammaster » Tue Feb 28, 2017 8:35 am
Hello!
The workstation only post the low level bios (vga bios on black screen), but no srm or arc console ...
I have try to swap the 2 flash eeproms with working one but nothing.
Is there a jumper for NVRAM factory setting like the alphastation 255's jumperblock (JP1 and JP2)?
dead mobo?
thk.
.......... :Onyx2: ............................... :Indigo2IMP: ..................................... :Indigo2: ........................... :Indigo: .............
IR2E 6GB 4x400Mhz .... MAXImp/4MB 512MB 195Mhz .... Extreme 384MB 250Mhz....Elan 64MB R3K ....
............. :Indy: ................................. :Octane2: .................
XS24 256MB 150 Mhz R5K .... V12 2GB 2x600Mhz ....
Intergraph TDZ2000 GL2 4110GT 1GB 2x600Mhz ... HP Visualize X-Class FX10 4GB 2x1000Mhz ... IBM 5160 V20, 8087 30Mb ... IBM 5162 10Mhz, 287XL, 6Mb, ST-4096 ... APPLE PowerMAC 9600/300 ... APPLE Quadra 840AV ... APPLE PowerMAC G5 Quad ... DEC AlphaStation 255/300 PS40 ... DEC AlphaStation 500/333 PS51 ... IBM RS/6000 PowerStation 7012-320 + GT3i ... SUN SparcStation 20 256MB AG10-E 2xSM81 ... SUN Ultra 80 4x450Mhz ... Amiga 2000HD, ECS 2MB ... Intergraph InterPro 225 ... DEC AlphaServer 4100 4x533Mhz 2MB ... SUN V880 ... DEC Multia 233Mhz
johnnym
Re: Alphastation 500 don't post
Unread postby johnnym » Tue Feb 28, 2017 10:02 am
jammaster wrote:Hello!
dead mobo?
You could try to use a firmware update disk. This could give you output to the serial console port. I have done this on an AXPpci33 to get it going - IIRC after a similar issue than what you describe - vga bios message on black screen. I needed to set the SROM select jumpers (from the AXPpci33 OEM manual page 40 (labelled 2-22)) to "Boot from fail-safe floppy loader", insert the firmware update disk and cycle power. Afterwards the machine gave me console output after an endless 48 seconds and allowed to update the firmware.
I assume the AlphaStation 500 could have a similar functionality and you could update the firmware to the original (no real change to your current config, albeit it might work again afterwards) or the latest firmware depending on what you desire.
EDIT:
The AlphaStation 500 manual also has SROM selection jumpers (see page 120 (labelled C-12)). I assume "Floppy loader" is the relevant configuration.
EDIT2:
It could be that I also had to remove the graphics card before using the fail-safe floppy loader to make sure console output goes to the serial console (also make sure that no keyboard is attached!). If it doesn't print anything with the graphics card installed you could retry without it.
Cheers
johnnym
jammaster
Unread postby jammaster » Tue Feb 28, 2017 10:14 am
thank a LOT
johnnym
Unread postby johnnym » Tue Mar 07, 2017 3:30 am
jammaster wrote:thank a LOT
Just to be sure and to make this thread useful for others, too:
Did the proposed solution solve your original problem?
jammaster
Unread postby jammaster » Fri Apr 21, 2017 10:51 pm
I haven't try yet...
Return to “HP/DEC/Compaq”
