WTB - bottom plate / wheels for onyx2 / sgi 2200
MrBill
Unread postby MrBill » Sat Feb 18, 2017 11:12 am
I have the rest of the plastic for the machine. It was originally in a rack mount config. Without the bottom the vents are flush with the floor and will certainly overheat.
:Octane: :Octane: :Octane: :Octane2: :Indy: :Indy: :Indy: :Indy: :Indigo: :Indigo2: :Crimson:Image :Tezro: :Tezro: :Onyx2: :Onyx2: :Onyx: :OnyxR: :BA213:
jebmayers
Re: WTB - bottom plate / wheels for onyx2 / sgi 2200
Unread postby jebmayers » Sat Feb 18, 2017 12:32 pm
Hi MrBill,
I had the same problem with my Origin2000, again a rack module I bought the deskside skins for from dexter1 (who is a superstar!). I built a wooden plinth for it that allows good air flow and allows it to move pretty easily on my wooden floor. I also has the benefit that you can screw the bottom of the plastics to the bottom of it which makes it much more solid than relying on the age old plastic catches which seem to break off if I even look at them! ;o)
I'll draw you a diagram of the design and send it if you are interested. The wood I used as this:
http://www.wickes.co.uk/Wickes-Studwork ... e/p/107713
The height when standing edge on is just right to give it good clearance and when layed flat can be used as the cross members which allows air to flow through. Works very well, my stacked Origin 2000 has run happily for hours on this.
I must confess though like you I do want the proper base and wheels! ;o)
Hope this helps anyway,
Jeb
MrBill
Unread postby MrBill » Sat Feb 18, 2017 5:49 pm
Looks a bit more elagant than the copper kitchen pans i have it propped up on right now. Your design looks nicer, should do the job until i find the real thing, thanks.
mashek
Unread postby mashek » Mon Feb 20, 2017 7:34 am
I have them in stock. They are called skateboards.
$100 + shipping
sales calls & paid consulting only: 865-357-6274
mailto:doug@mashek.com
Mashek Systems www: http://www.mashek.com
:320: :540: :1600SW: :O2: :O2+: :Indigo: :Octane: :Octane2: :Tezro: :Indigo2: :Indigo2IMP: :Indy: :Fuel: :PI: :O200: :Onyx: :ChallengeXL: :OnyxR: :O2000: :Onyx2: :O2000R: :O2000E: :O2000E: :O2000E: :metarouter: :O2000E: :O2000E: :O2000E: :O2000E: :Onyx2RE: :Onyx2RE: :Onyx2R: :Onyx2RE: :O3000: :O3000: :O3200: :0300: :0300: :0300: :0300:...
Return to “Hardware Wanted”
