Some concept screenshots I made a while ago
Dodoid
Unread postby Dodoid » Wed Feb 15, 2017 8:17 am
I posted these in another thread a few months ago but I figure they should get their own. Mishmash of things relating to if SGI magically decided to come back to IRIX today.
Modern, flat-styled IRIX, showing About box:
Just the desktop. Minimal :) :
Mobile IRIX, main screen:
I tried to center the OS around the Icon Catalog the way iOS and Android are centered around app launchers.
Mobile IRIX, toolchest and iconified programs:
Toolchest and iconified programs are on a "slide-in" sidebar to save space.
Mobile IRIX, notifications:
Phones need notification centers! Here's my take on what SGIs would look like. Designed to not totally kill your screen space and distract you like Android's tends to.
I also hastily faked a screenshot of the SGI website if this happened:
and a small army of Image
Shiunbird
Re: Some concept screenshots I made a while ago
Unread postby Shiunbird » Wed Feb 15, 2017 9:25 am
I'm curious about how you would see the console on mobile IRIX working... a slide up keyboard with most used key shortcuts on top? (Esc, Tab, arrows, etc)
Dodoid
Unread postby Dodoid » Wed Feb 15, 2017 9:48 am
Shiunbird wrote:I'm curious about how you would see the console on mobile IRIX working... a slide up keyboard with most used key shortcuts on top? (Esc, Tab, arrows, etc)
I would suspect something like that. I sort of thought about there being something like Windows Phone's Continuity, so maybe it's more useful when the phone is docked.
Unread postby vishnu » Wed Feb 15, 2017 11:46 am
More likely would be OpenIRIX Community Edition... ;)
Unread postby foetz » Wed Feb 15, 2017 5:05 pm
ha, these are nice :D
smj
Unread postby smj » Fri Feb 17, 2017 11:38 pm
Always fun to see design exercises like this. Nice work.
cesss
Unread postby cesss » Sat Feb 18, 2017 8:24 am
After quite a few years using OS X (after SGI decision to drop IRIX), I realize NeXTSTEP had many things that sweetly solved the (very few) things that weren't convenient in IRIX. For example:
-app-bundles (turning it unnecessary to install applications... they're seen as an icon in the desktop, but they're actually a directory holding all the binaries, libs, data, etc that make the application).
-internationalization (maybe the NeXTSTEP i18n approach isn't 100% perfect, but it's the better I know).
-fat binaries. I don't understand why this feature has so many detractors (although most detractors are also binary-distribution detractors, so it's understandable that people who push for a world where everything was source code would be detractors for fat binaries, because they hate binaries in the first place). If IRIX was resurrected, I'd love it to adopt fat binaries as the path for supporting multiple architectures.
-what you can do with DMG images in OS X is shockingly powerful. Yes, today we have FUSE as an equivalent outside of OS X, but back in the years when I was a daily IRIX developer there was no equivalent.
So, in conclusion, I guess the OS of my dreams would be a merging of IRIX with NeXTSTEP... well I believe most of it would be IRIX, but I'd adopt the app-bundle paradigm in the desktop, I'd link some of the MACH kernel into the IRIX kernel (perhaps in a similar way to what the XNU kernel does in OS X: it's not the MACH kernel, it's another kernel which links stuff from MACH as a library), and I'd make disk image mounting as a very central service.
For the GUI look & feel, I'd choose IndigoMagic. The only thing I'd adopt from OS X are multitouch gestures. The rest, pure IndigoMagic.
Unread postby Raion-Fox » Sat Feb 18, 2017 9:57 am
That would be a terrible idea. Mach has shitty performance. If you want to resurrect IRIX do it with a BSD kernel as the base not the abomination and unspeakable horror that is Mach. It's performance sucks, it's UNIX compatibility is shockingly underwhelming and MacOS and to an extent NeXTSTEP are garbage. Fuck launchd, fuck libnotify, fuck Aqua, fuck Darwin and XNU and fuck the entirety of Apple because they don't care about power users and they abandon their customers with overpriced and underpowered hardware and what little code they do release is under the shitty Apache 2.0 license.
Your point about app bundles is good but you can do this theoretically on BSD with jails or chroot or other setups.
The internationalization support is a good point but with noto fonts on BSD I can do most anything besides input methods which Google Translate has me covered for Chinese and Japanese.
Fat binaries aren't an Apple originating invention. IBM i is essentially architecture independent due to its binary format.
.dmg images were always so annoying I'd much prefer applications and source to be distributed in a tarball with xz or bzip2 compression.
For a new IRIX release I would take from BSD, specifically FoxBSD, NetBSD and OpenBSD the following features:
PF firewall
Jails
CGD
Veriexec
PKGSRC or XBPS
And for the GUI the primary changes I'd implement:
Transparency settings
Text antialiasing
Easy hotkey customization
A tint2 type taskbar as an option instead of iconifying.
Dodoid
Unread postby Dodoid » Sat Feb 18, 2017 1:57 pm
Raion-Fox wrote:PF firewall
Jails
CGD
Veriexec
PKGSRC or XBPS
Text antialiasing
Can we make IRIX 7 now :D ?
I would do more designs if it interests people.
Unread postby Raion-Fox » Sat Feb 18, 2017 3:46 pm
We need a kernel that can work with the legacy code, drivers etc. And therein is part of the issue. I could drop some contacts I have at HPE here and let various devs talk to them but we will see
Unread postby robespierre » Sat Feb 18, 2017 4:16 pm
Mach is very outdated and inefficient, and there are basic problems in its design (for instance, page tables can grow even if the application doesn't use any more memory).
Dodoid
Unread postby Dodoid » Sat Feb 18, 2017 8:34 pm
Can't leave the old applications behind, now can we :) .
Forgot to mention, ISLE would also turn systems on and off as needed, hence the "scaling" name. Referring to scaling of servers (and power use), nothing to do with scaling of images or video.
EDIT: Did a Nekochan search. It seems that Cyclone was actually a cloud computing project of theirs shortly after Rackable bought them. I must have remembered the name.
Dodoid
"Modern IRIX" UI running on Kronos/Linux
Unread postby Dodoid » Sun Feb 26, 2017 8:31 pm
Alright, so I got bored over the weekend and decided to replicate the (photoshopped) interface shown above as a real thing using my Kronos platform. This is a real interface, running on Linux on a spare ThinkPad T60, and it really does work alongside normal Linux applications running in windows (though it's toolchest is full of placeholder menu items right now). IRIX 7 w/ FoxBSD anyone :D ?
Kronos is essentially a python program using Webkit and GTK connected to a local Apache2 server with PHP. The goal is to write desktop applications (or, in this case, the desktop itself!) using web languages. If anyone has seen the video about the Pegasus X on my channel, it uses an early version of Kronos with no window manager (and therefore practically no usability for normal, local software running in windows other than the main Kronos one). I often refer to it as "pure Kronos". Somewhere I have a version of pure Kronos that does windowing using iframes and JavaScript in the main window, but again only Kronos applications and it's slow. The newer version, which I often call "Kronos 2" or "Openbox Kronos" uses a window manager (I tend to use Openbox) to place Kronos applications in regular XWindows windows, which the window manager allows you to move around as normal. On Kronos 2, the Kronos desktop (which, in this case, contains the toolchest, desktop background, and so on) is a large window configured to stay behind everything else, not allow movement or resizing, and never show borders. JavaScript + PHP allows Kronos applications to access the underlying system (performing file operations or running shell commands for example).
Anyway, basically what it means is that I can throw together something like this "modern IRIX" UI very quickly, have it interface with the system through PHP, and have it look good thanks to CSS3.
Running on my desk with a uxterm open. Openbox windows still have the default window decoration theme.
Closeup of screen. Stunning 1024x768 resolution, courtesy of Lenovo.
Toolchest is functional and translucent, just like the original design.
I've named it Project IRENKA, which stands for "IRIX-like ENvironment with Kronos Applications". Any thoughts? I quite like it, and hope to do a bit more work on it soon.
Dans34
Unread postby Dans34 » Mon Feb 27, 2017 11:18 am
I really like the look of this kronos app thing , what do we need to get it running ?
:Octane: R12K/400 Octane, 1024MB, 36GB 15K MAX3036NC , MXI
Dodoid
Unread postby Dodoid » Tue Feb 28, 2017 7:53 am
Dans34 wrote:I really like the look of this kronos app thing , what do we need to get it running ?
Pure Kronos w/ Pegasus X software (and PXEM Pegasus X emulator) is available at http://rittybox.com/pegasus. Kronos 2 has not yet been publicly released. I'm hoping to release it alongside the Kronos API (kapi), which I don't feel is secure enough to release. Right now, the Kronos API can be accessed with no limitations so long as the connection originates from localhost. While this stops the guy across the room from messing with your machine through the API, it means that a webpage you load in Firefox could use Javascript to connect to the API at localhost, and because it's coming from your sytem, the API would trust it. Working on code to provide Kronos applications with a key as a JavaScript variable when they are loaded, which they can use to access the API. Applications running in a browser would not have access to the key, because Firefox/Chrome/whatever would not be passing it to the page when it loads, so any attempt they make to use the API would be denied (and probably logged).
Basically, it sucks to use Kronos 2 without the standard API, and the API is insecure. Should be ready for release soon. Note that Pure Kronos does not have the API and is mostly unable to run a decent browser anyway, so this risk should not be a factor (I can think of one potential vulnerability that would allow apps to be installed by a malicious website, but the user would still have to run them in order for them to execute code and I'm not sure if it would work to begin with).
Return to “SGI: Discussion”
