Fuel fixer uppper
Hombre71
Re: Fuel fixer uppper
Unread postby Hombre71 » Sun Aug 27, 2017 3:54 am
kubatyszko wrote:I just noticed that you seem to be missing the 5V aux line - all of the "aux" should be showing up in standby.
What is VERY strange, is that you have all of the 3.3V aux ones, and 5V aux PIMM.
ATX only provides one 5V rail in standby, so if you see 5V in one place but not the other that's odd, and even better, since the 3v3 aux ones are actually converted from 5V - this proves that the 5VSB gets to your fuel just fine.
From this information I can deduce that either one of your DS1780 (monitoring chips) is fried or something on the board makes the monitoring not work - could be short of the 5V just before the monitoring input.
Hmmm, I just noticed this indeed
001a01-L1>ALERT: Error initializing DS1780 0, no acknowledge
SGI SN1 L1 Controller
Firmware Image B: Rev. 1.10.12, Built 02/01/2002 14:40:22
Do based on the number 0 can we identify which one is likely to be toast?
Or is there another way to double check both(?) DS1780 chips through L1 command or other test?
Cheers
Hombre71
Unread postby Hombre71 » Sun Aug 27, 2017 3:57 am
I would be interested to see the output from someone's running Fuel with the test intr command in L1.
Mine now gives:
001a01-L1>test intr
I2C interrupts, High: 1  Low: 0
  NODE 0 DS1780, 1:    0 (0x00) 2:    0 (0x00)
  NODE 1 DS1780, 1:    0 (0x00) 2:    0 (0x00)
  NODE 2 DS1780, 1:    0 (0x00) 2:    0 (0x00)
    PIMM DS1780, 1:    0 (0x00) 2:    0 (0x00)
 ODYSSEY DS1780, 1:    0 (0x00) 2:    0 (0x00)
     BUS SELECT I/O Expander:    0
 MARGIN CONTROL I/O Expander:    0
       LED0 LOW I/O Expander:    0
 ASIC CONTROL 1 I/O Expander:    0
 ASIC CONTROL 2 I/O Expander:    0
   POWER ENABLE I/O Expander:    0
     XB CONTROL I/O Expander:    0
   PIMM CONTROL I/O Expander:    0
    ODYSSEY GFX I/O Expander:    0
DISPLAY CONTROL I/O Expander:    0
001a01-L1>
Hombre71
Unread postby Hombre71 » Sun Aug 27, 2017 4:07 am
Cheers[/quote]
I suppose there should be a hint in which fans are reported as 'no acknowledge' as well :
001a01-L1>fan
fan(s) are on.
fan 0 EXHAUST  rpm 0 (255).
fan 1 ERROR I2C:no acknowledge.
fan 2 ERROR I2C:no acknowledge.
fan 3 XIO 1    rpm 0 (255).
fan 4 XIO 2    rpm 0 (255).
fan 5 PS       rpm 0 (255).
001a01-L1>
mazzinia
Unread postby mazzinia » Sun Aug 27, 2017 4:56 am
you could try
test i2c
maybe helps to identify the one having troubles. But I "think" having read on this forum that i2c chips can give errors either if faulty, or if not receiving the +5v
Hombre71
Unread postby Hombre71 » Sun Aug 27, 2017 5:12 am
mazzinia wrote:you could try
test i2c
001a01-L1>test i2cError reading the NODE 0 DS1780 Company ID, bus 68 addr 0x2c -        no acknowledge
error -1 on tst.
001a01-L1>
mazzinia
Unread postby mazzinia » Sun Aug 27, 2017 7:07 am
well, guess we know which one has troubles.
I may be wrong, but feels the same one that went bad in other threads on this forum
Hombre71
Unread postby Hombre71 » Mon Aug 28, 2017 4:18 am
test i2c
error -1 on tst.
001a01-L1>
Yeahh...so I ordered 3 replacement DS1780 chips from AVNET EU. Now to find someone that can do SMD soldering in my area...
Unread postby jan-jaap » Mon Aug 28, 2017 4:39 am
I'd like to figure out how NODE0 ... NODE2 map to the three DS1780 chips on the mainboard. I've got a cranky Fuel myself, and I'd rather not swap thta DS1780 between the PCI slots unless there was no other option.
Hombre71
Unread postby Hombre71 » Mon Aug 28, 2017 4:47 am
jan-jaap wrote:I'd like to figure out how NODE0 ... NODE2 map to the three DS1780 chips on the mainboard. I've got a cranky Fuel myself, and I'd rather not swap thta DS1780 between the PCI slots unless there was no other option.
Is yours complaining about a specific node # ? Because the hard way would be just to replace 1 by 1 the other two, plug the board
into power and run the L1 to see if it keeps complaining....
If you can do your own soldering then that would take some time but it would not be wasted....
Unread postby jan-jaap » Mon Aug 28, 2017 5:17 am
This is really at the limit of what I can do by hand, but I'll try sometime soon (I have the chips).
I guess you could remove one and apply power to see which one "disappears" from the L1.
mazzinia
Unread postby mazzinia » Mon Aug 28, 2017 6:49 am
mmmm before removing the chips , what about checking the current on the pins that should have Vdd etc ? ( the chip schematics are online ) ( this is for the OP )
This to triplecheck that the issue is a chip, and not something prior elsewhere.
And... one chip should be on the backside of the mb.. are we sure that there's nothing that maybe moved there and is causing a short ?
Dunno... a dead spider ?
Hombre71
Unread postby Hombre71 » Mon Aug 28, 2017 7:24 am
mazzinia wrote:mmmm before removing the chips , what about checking the current on the pins that should have Vdd etc ? ( the chip schematics are online ) ( this is for the OP )
I can inspect it when I remove the motherboard eventually. But given the well documented demise of these chips all over
the place it seems likely that one of them called it quits.
kubatyszko
Unread postby kubatyszko » Mon Aug 28, 2017 9:26 pm
Hombre71 wrote:Hmmm, I just noticed this indeed
Cheers
001a01-L1>fan
fan(s) are on.
001a01-L1>
[/quote]
If I had to *guess*, my bet would go on the DS1780 near the ATX socket or below it.
There are 4 of those chips in total:
    Between PCI slots
    Below the ATX socket (can't remember the precise location)
    Somewhere near the Yellow ST chip
    On the PIMM module.
I don't have reliable information on which chip monitors which voltages or fans.
Thing is that all those are simply MONITORING issues, disabling env monitoring (env off) should let you go further and boot the machine. If that doesn't happen then you do have bigger problem with either the PSU or some voltage regulation onboard.
Unread postby jan-jaap » Tue Aug 29, 2017 12:01 am
kubatyszko wrote:There are 4 of those chips in total:
    Between PCI slots
    On the PIMM module.
And there's a fifth on the VPro graphics card.
kubatyszko wrote:Thing is that all those are simply MONITORING issues, disabling env monitoring (env off) should let you go further and boot the machine. If that doesn't happen then you do have bigger problem with either the PSU or some voltage regulation onboard.
The DS1780 chips communicate with the L1 using I2C. I don't know what else is on the I2C bus (ID PROM chips?), but I2C problems can stop the system from booting.
kubatyszko
Unread postby kubatyszko » Tue Aug 29, 2017 12:20 am
    Between PCI slots
    On the PIMM module.
Forgot about the vpro (my experimental fuel has no video card ;-) ).
Yes the id chip on both fuel Mb (8-pin eeprom in a socket near Ethernet port) and vpro(small 6pin dallas chip) are on I2C bus, not sure what else.
