How to back install showPS?
gijoe77
Unread postby gijoe77 » Sun Jan 08, 2017 1:48 am
I installed Illustrator 5.5 on a octane running 6.5.23f (probably going to upgrade to 6.5.30f). Illustrator dies like the following after launching:
/usr/adobe/Illustrator_5.5/bin/illustrator[782] 6498 memory fault
I read up that it's because SGI dumped Adobe's showPS after 6.5.22 - and I see people are running Illustrator 5.5 on much later releases of IRIX - how are y'all getting around this? I dug up a binary from a earlier release and adding this line to the ENV:
PSVIEWER=/usr/bin/X11/showps
but illustrator is still dying.
Re: How to back install showPS?
Unread postby recondas » Sun Jan 08, 2017 6:13 am
gijoe77 wrote:I installed Illustrator 5.5 on a octane running 6.5.23f (probably going to upgrade to 6.5.30f). Illustrator dies like the following after launching: /usr/adobe/Illustrator_5.5/bin/illustrator[782] 6498 memory fault
I'm not sure it'll cure the memory fault you're getting, but it's not uncommon for new Illustrator installs (under IRIX 6.5.23 and later) to need the Adobe-provided DPS tools (aka dpsnx.agent). There's a discussion in this nekochan thread that touches on adding dpsnx.agent.
gijoe77
Unread postby gijoe77 » Sun Jan 08, 2017 1:55 pm
No luck in that department, I re-run the script with no success :(
BTW what is normalizer? I see it in the dir you posted. Is that a separate adobe product or might it have sort of synergy with the other adobe products?
