Mips3 E-Uae
marmotta
Mips3 E-Uae
Unread postby marmotta » Sat Jan 07, 2017 12:43 pm
I not able to find it... I very curious to view my Indigo2 (R4400) performance in Amiga emulation. No way to compile e-uae for mips3 irix 6.2?
necron2600
Re: Mips3 E-Uae
Unread postby necron2600 » Thu Aug 17, 2017 11:26 pm
I was able to compile it on a R4k Indy (mips3) with 6.5.22 without any problem (nekoware's mips3 stuff are installed).. I took the orig tardist (mips4) author's patch that is avail inside the tardist.. but it would not run... well it just sat there not doing anything, no GUI menu showed up either. The exact same compile done on an O2 (mips4) worked fine.. just at 300mhz it was quite slow. My Octane @ 600mhz runs it adequately so I do not have high hopes for a r4k.
I was compiling with MIPSPro.. maybe I'll try gcc next.
marmotta
Re: Mips3 E-Uae
Unread postby marmotta » Thu Aug 17, 2017 11:52 pm
Ok, thanks for the interest, I'm very curious to see the speed of 250mhz r4k of Indigo2 and r4k 150mhz of Indigo :-)
necron2600
Re: Mips3 E-Uae
Unread postby necron2600 » Fri Aug 18, 2017 12:23 am
compiled with GCC (mips3) it seems to load up the GUI/menu now. but it took awhile. This is on a 150mhz Indigo-without-the-go.
I started a Sword of Sodan game.. its a slide show with music very choppy.
Maybe more tweaks to settings could make it better....
marmotta
Re: Mips3 E-Uae
Unread postby marmotta » Fri Aug 18, 2017 1:03 am
Wow! Thanks! You can share the tardist on nekoware?
necron2600
Re: Mips3 E-Uae
Unread postby necron2600 » Fri Aug 18, 2017 11:51 am
tarball of binary below...
My attempts to compile with MIPSPro did not seem to work well on my Indy. GCC, esp v3, may not be super optimized on the platform.
Depending on how far you get with performance, I can see about creating a tardist for this.
e-uae-compiled-mips3.tar
e-uae compiled for mips3 with GCC 3.4.6
(4.4 MiB) Downloaded 11 times
marmotta
Re: Mips3 E-Uae
Unread postby marmotta » Mon Aug 21, 2017 1:38 am
I tried to run the binary but with my Indigo (as expected) without nekoware I missing the libz. Now I need to install the nekoware ;-)
marmotta
Re: Mips3 E-Uae
Unread postby marmotta » Wed Aug 23, 2017 1:15 am
I have installed all required libraries from TGCWare (I have Irix 6.2) but I have the libaudio.so missing issue (notorious). Exist a easy solution? Or I need to downgrade to 5.3 or upgrade to 6.5 (I prefer to not upgrade... I have others machines with 6.5)
Re: Mips3 E-Uae
Unread postby jan-jaap » Wed Aug 23, 2017 1:52 am
You have libaudio.a in /usr/lib32
I think it's as easy as (MIPSpro):
cc -shared -all -o libaudio.so libaudio.a
GCC has slightly different syntax, probably "-Wl,-shared -Wl,-all" or similar.
marmotta
Re: Mips3 E-Uae
Unread postby marmotta » Wed Aug 23, 2017 3:58 am
Yes, libaudio.a is present (you know good your ex machine ;-) )
Now I try...
marmotta
Re: Mips3 E-Uae
Unread postby marmotta » Wed Aug 23, 2017 9:29 am
Compiling libaudio.so succesfull (I added the -n32 option)
Now when I launch uae I have this error:
983:./uae: rld: Error: unresolvable symbol in ./uae: __libc_attr
marmotta
Re: Mips3 E-Uae
Unread postby marmotta » Wed Aug 23, 2017 1:23 pm
The issue is libc.so.1 in /lib32 I have tried to copy the version on 6.5.3 without success (if I start uae it immediately "killed")
Other solution?
marmotta
Re: Mips3 E-Uae
Unread postby marmotta » Tue Sep 05, 2017 3:26 pm
Uae on my Indy r5000 (mips4)..... not bad! But the graphics is very very slow :-(
