Debian 7.11 sparc: Dual Creator 3D configuration ?
yungjoon
Unread postby yungjoon » Sun Nov 06, 2016 1:42 am
Hi,
I installed a Xfce debian 7.11 with my Ultra60, the two creator 3D seem to be recognized, a desktop is displayed on each output.
But I am stuck on only one desktop, I can't move the pointer to the other desktop.
There are no Xorg.conf file in /etc/X11/.
Anyone has an idea about a way to access both desktops ?
Thanks ...
tingo
Re: Debian 7.11 sparc: Dual Creator 3D configuration ?
Unread postby tingo » Fri Nov 11, 2016 10:20 am
Does it matter which edge you try to move the cursor off? Sometimes the monitor physically is on the wrong side of what Xorg thinks...
Also, what is the output of 'xrandr'?
Torfinn
yungjoon
Unread postby yungjoon » Tue Nov 15, 2016 11:37 pm
Hi,
xrandr shows only one output and something like 1280x1024 at 960Hz (crazy frequency!). There is a problem in driver installation but I don't see how it is set, there si no Xorg.conf file...
tingo
Unread postby tingo » Fri Nov 18, 2016 2:08 am
How about the log file?
/var/log/Xorg...
does it tell you anything?
Torfinn
yungjoon
Unread postby yungjoon » Sun Feb 05, 2017 6:29 am
Hi,
Sorry for my (very) delayed reply, my sun was out of order since november, I just managed to make it it boot again. I have only a Xorg.0.log file in /var/log/. Here is its content:
[ 26.015]
X.Org X Server 1.12.4
Release Date: 2012-08-27
[ 26.015] X Protocol Version 11, Revision 0
[ 26.015] Build Operating System: Linux 2.6.32-5-sparc64-smp sparc Debian
[ 26.015] Current Operating System: Linux ULTRA60 3.2.0-4-sparc64-smp #1 SMP Debian 3.2.78-1 sparc64
[ 26.015] Kernel command line: root=/dev/sda2 ro
[ 26.016] Build Date: 09 February 2015 11:37:29AM
[ 26.016] xorg-server 2:1.12.4-6+deb7u6 (Julien Cristau <jcristau@debian.org>)
[ 26.016] Current version of pixman: 0.26.0
[ 26.016] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 26.016] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 26.017] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 1 01:00:26 1970
[ 26.040] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 26.059] (==) No Layout section. Using the first Screen section.
[ 26.059] (==) No screen section available. Using defaults.
[ 26.059] (**) |-->Screen "Default Screen Section" (0)
[ 26.059] (**) | |-->Monitor "<default monitor>"
[ 26.061] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 26.061] (==) Automatically adding devices
[ 26.061] (==) Automatically enabling devices
[ 26.096] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 26.096] Entry deleted from font path.
[ 26.408] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 26.418] Entry deleted from font path.
[ 26.418] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 26.418] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 26.418] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 26.418] (II) Loader magic: 0x701dd850
[ 26.418] (II) Module ABI versions:
[ 26.418] X.Org ANSI C Emulation: 0.4
[ 26.419] X.Org Video Driver: 12.1
[ 26.419] X.Org XInput driver : 16.0
[ 26.419] X.Org Server Extension : 6.0
[ 26.432] (--) SBUS:(0xf006e17c) Sun FFB2+ Vertical Creator 3D at /SUNW,ffb@1e,0
[ 26.435] (--) SBUS:(0xf0076348) Sun FFB2+ Vertical Creator 3D at /SUNW,ffb@1d,0
[ 26.439] (II) LoadModule: "extmod"
[ 26.465] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 26.487] (II) Module extmod: vendor="X.Org Foundation"
[ 26.487] compiled for 1.12.4, module version = 1.0.0
[ 26.487] Module class: X.Org Server Extension
[ 26.489] ABI class: X.Org Server Extension, version 6.0
[ 26.489] (II) Loading extension SELinux
[ 26.489] (II) Loading extension MIT-SCREEN-SAVER
[ 26.489] (II) Loading extension XFree86-VidModeExtension
[ 26.489] (II) Loading extension XFree86-DGA
[ 26.489] (II) Loading extension DPMS
[ 26.490] (II) Loading extension XVideo
[ 26.490] (II) Loading extension XVideo-MotionCompensation
[ 26.490] (II) Loading extension X-Resource
[ 26.490] (II) LoadModule: "dbe"
[ 26.492] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 26.519] (II) Module dbe: vendor="X.Org Foundation"
[ 26.519] compiled for 1.12.4, module version = 1.0.0
[ 26.520] Module class: X.Org Server Extension
[ 26.520] ABI class: X.Org Server Extension, version 6.0
[ 26.520] (II) Loading extension DOUBLE-BUFFER
[ 26.520] (II) LoadModule: "glx"
[ 26.521] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 26.550] (II) Module glx: vendor="X.Org Foundation"
[ 26.550] compiled for 1.12.4, module version = 1.0.0
[ 26.551] ABI class: X.Org Server Extension, version 6.0
[ 26.551] (==) AIGLX enabled
[ 26.551] (II) Loading extension GLX
[ 26.551] (II) LoadModule: "record"
[ 26.553] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 26.566] (II) Module record: vendor="X.Org Foundation"
[ 26.566] compiled for 1.12.4, module version = 1.13.0
[ 26.566] Module class: X.Org Server Extension
[ 26.566] ABI class: X.Org Server Extension, version 6.0
[ 26.566] (II) Loading extension RECORD
[ 26.566] (II) LoadModule: "dri"
[ 26.568] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 26.578] (II) Module dri: vendor="X.Org Foundation"
[ 26.578] compiled for 1.12.4, module version = 1.0.0
[ 26.578] ABI class: X.Org Server Extension, version 6.0
[ 26.578] (II) Loading extension XFree86-DRI
[ 26.579] (II) LoadModule: "dri2"
[ 26.580] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 26.582] (II) Module dri2: vendor="X.Org Foundation"
[ 26.582] compiled for 1.12.4, module version = 1.2.0
[ 26.582] ABI class: X.Org Server Extension, version 6.0
[ 26.582] (II) Loading extension DRI2
[ 26.584] (==) Matched sunffb as autoconfigured driver 0
[ 26.584] (==) Matched sunffb as autoconfigured driver 1
[ 26.584] (==) Matched fbdev as autoconfigured driver 2
[ 26.584] (==) Assigned the driver to the xf86ConfigLayout
[ 26.584] (II) LoadModule: "sunffb"
[ 26.585] (II) Loading /usr/lib/xorg/modules/drivers/sunffb_drv.so
[ 26.596] (II) Module sunffb: vendor="X.Org Foundation"
[ 26.596] compiled for 1.12.1, module version = 1.2.1
[ 26.596] Module class: X.Org Video Driver
[ 26.596] ABI class: X.Org Video Driver, version 12.0
[ 26.596] (II) LoadModule: "fbdev"
[ 26.597] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 26.623] (II) Module fbdev: vendor="X.Org Foundation"
[ 26.623] compiled for 1.12.1, module version = 0.4.2
[ 26.623] ABI class: X.Org Video Driver, version 12.0
[ 26.623] (II) SUNFFB: driver for Creator, Creator 3D and Elite 3D
[ 26.623] (II) FBDEV: driver for framebuffer: fbdev
[ 26.624] (++) using VT number 7
[ 26.624] (WW) Falling back to old probe method for sunffb
[ 26.627] (--) Assigning device section with no busID to SBUS:/SUNW,ffb@1e,0
[ 26.627] (WW) SUNFFB: More than one matching Device section found: Autoconfigured Video Device sunffb
[ 26.630] (--) Assigning device section with no busID to SBUS:/SUNW,ffb@1d,0
[ 26.630] (WW) SUNFFB: More than one matching Device section found: Autoconfigured Video Device sunffb
[ 26.630] (WW) Falling back to old probe method for fbdev
[ 26.631] (II) Loading sub module "fbdevhw"
[ 26.631] (II) LoadModule: "fbdevhw"
[ 26.632] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 26.636] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 26.637] compiled for 1.12.4, module version = 0.0.2
[ 26.637] ABI class: X.Org Video Driver, version 12.1
[ 26.637] (II) SUNFFB(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 26.637] (==) SUNFFB(0): RGB weight 888
[ 26.638] (==) SUNFFB(0): Default visual is TrueColor
[ 26.638] (==) SUNFFB(0): Using gamma correction (1.0, 1.0, 1.0)
[ 26.638] (==) SUNFFB(0): Using HW cursor
[ 26.638] (II) Loading sub module "fb"
[ 26.638] (II) LoadModule: "fb"
[ 26.638] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 26.651] (II) Module fb: vendor="X.Org Foundation"
[ 26.651] compiled for 1.12.4, module version = 1.0.0
[ 26.651] ABI class: X.Org ANSI C Emulation, version 0.4
[ 26.651] (II) Loading sub module "xaa"
[ 26.651] (II) LoadModule: "xaa"
[ 26.654] (II) Loading /usr/lib/xorg/modules/libxaa.so
[ 26.674] (II) Module xaa: vendor="X.Org Foundation"
[ 26.674] compiled for 1.12.4, module version = 1.2.1
[ 26.674] ABI class: X.Org Video Driver, version 12.1
[ 26.674] (II) Loading sub module "ramdac"
[ 26.674] (II) LoadModule: "ramdac"
[ 26.674] (II) Module "ramdac" already built-in
[ 26.674] (II) Loading sub module "dbe"
[ 26.674] (II) LoadModule: "dbe"
[ 26.676] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 26.676] (II) Module dbe: vendor="X.Org Foundation"
[ 26.676] compiled for 1.12.4, module version = 1.0.0
[ 26.676] Module class: X.Org Server Extension
[ 26.676] ABI class: X.Org Server Extension, version 6.0
[ 26.676] (II) Loading extension DOUBLE-BUFFER
[ 26.677] (==) SUNFFB(0): DPI set to (96, 96)
[ 26.677] (==) SUNFFB(1): RGB weight 888
[ 26.677] (==) SUNFFB(1): Default visual is TrueColor
[ 26.677] (==) SUNFFB(1): Using gamma correction (1.0, 1.0, 1.0)
[ 26.677] (==) SUNFFB(1): Using HW cursor
[ 26.677] (II) Loading sub module "fb"
[ 26.677] (II) LoadModule: "fb"
[ 26.678] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 26.678] (II) Module fb: vendor="X.Org Foundation"
[ 26.678] compiled for 1.12.4, module version = 1.0.0
[ 26.678] ABI class: X.Org ANSI C Emulation, version 0.4
[ 26.678] (II) Loading sub module "xaa"
[ 26.678] (II) LoadModule: "xaa"
[ 26.680] (II) Loading /usr/lib/xorg/modules/libxaa.so
[ 26.680] (II) Module xaa: vendor="X.Org Foundation"
[ 26.681] compiled for 1.12.4, module version = 1.2.1
[ 26.681] ABI class: X.Org Video Driver, version 12.1
[ 26.681] (II) Loading sub module "ramdac"
[ 26.681] (II) LoadModule: "ramdac"
[ 26.681] (II) Module "ramdac" already built-in
[ 26.681] (II) Loading sub module "dbe"
[ 26.681] (II) LoadModule: "dbe"
[ 26.683] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 26.683] (II) Module dbe: vendor="X.Org Foundation"
[ 26.683] compiled for 1.12.4, module version = 1.0.0
[ 26.683] Module class: X.Org Server Extension
[ 26.683] ABI class: X.Org Server Extension, version 6.0
[ 26.683] (II) Loading extension DOUBLE-BUFFER
[ 26.683] (==) SUNFFB(1): DPI set to (96, 96)
[ 26.683] (II) UnloadModule: "fbdev"
[ 26.684] (II) Unloading fbdev
[ 26.684] (II) UnloadSubModule: "fbdevhw"
[ 26.684] (II) Unloading fbdevhw
[ 26.684] (--) Depth 24 pixmap format is 32 bpp
[ 26.685] (II) /dev/fb0: Detected FFB2+/vertical, Z-buffer, Double-buffered.
[ 26.685] (II) /dev/fb0: BT498 (PAC2) ramdac detected
[ 26.688] (II) /dev/fb0: Detected Creator/Creator3D
[ 26.720] (II) SUNFFB(0): Using XFree86 Acceleration Architecture (XAA)
[ 26.720] Screen to screen bit blits
[ 26.720] Solid filled rectangles
[ 26.720] 8x8 mono pattern filled rectangles
[ 26.720] Indirect CPU to Screen color expansion
[ 26.720] Solid Lines
[ 26.720] Dashed Lines
[ 26.720] Driver provided ScreenToScreenBitBlt replacement
[ 26.721] Driver provided WritePixmap replacement
[ 26.721] (II) /dev/fb0: Using acceleration
[ 26.721] (==) SUNFFB(0): Backing store disabled
[ 26.721] (==) SUNFFB(0): Silken mouse enabled
[ 26.727] (II) /dev/fb0: DGA support initialized.
[ 26.728] (==) SUNFFB(0): DPMS enabled
[ 26.728] (==) RandR enabled
[ 26.729] (II) /dev/fb1: Detected FFB2+/vertical, Z-buffer, Double-buffered.
[ 26.729] (II) /dev/fb1: BT498 (PAC2) ramdac detected
[ 26.732] (II) /dev/fb1: Detected Creator/Creator3D
[ 26.739] (II) SUNFFB(1): Using XFree86 Acceleration Architecture (XAA)
[ 26.739] Screen to screen bit blits
[ 26.739] Solid filled rectangles
[ 26.739] 8x8 mono pattern filled rectangles
[ 26.739] Indirect CPU to Screen color expansion
[ 26.739] Solid Lines
[ 26.740] Dashed Lines
[ 26.740] Driver provided ScreenToScreenBitBlt replacement
[ 26.740] Driver provided WritePixmap replacement
[ 26.740] (II) /dev/fb1: Using acceleration
[ 26.740] (==) SUNFFB(1): Backing store disabled
[ 26.740] (==) SUNFFB(1): Silken mouse enabled
[ 26.741] (II) /dev/fb1: DGA support initialized.
[ 26.741] (==) SUNFFB(1): DPMS enabled
[ 26.741] (==) RandR enabled
[ 26.741] (II) Initializing built-in extension Generic Event Extension
[ 26.741] (II) Initializing built-in extension SHAPE
[ 26.741] (II) Initializing built-in extension MIT-SHM
[ 26.741] (II) Initializing built-in extension XInputExtension
[ 26.741] (II) Initializing built-in extension XTEST
[ 26.741] (II) Initializing built-in extension BIG-REQUESTS
[ 26.742] (II) Initializing built-in extension SYNC
[ 26.742] (II) Initializing built-in extension XKEYBOARD
[ 26.742] (II) Initializing built-in extension XC-MISC
[ 26.742] (II) Initializing built-in extension SECURITY
[ 26.742] (II) Initializing built-in extension XINERAMA
[ 26.742] (II) Initializing built-in extension XFIXES
[ 26.742] (II) Initializing built-in extension RENDER
[ 26.742] (II) Initializing built-in extension RANDR
[ 26.742] (II) Initializing built-in extension COMPOSITE
[ 26.742] (II) Initializing built-in extension DAMAGE
[ 26.743] (II) SELinux: Disabled on system
[ 26.802] (II) AIGLX: Screen 0 is not DRI2 capable
[ 26.802] (II) AIGLX: Screen 0 is not DRI capable
[ 27.009] (II) AIGLX: Loaded and initialized swrast
[ 27.009] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 27.009] (II) AIGLX: Screen 1 is not DRI2 capable
[ 27.009] (II) AIGLX: Screen 1 is not DRI capable
[ 27.012] (II) AIGLX: Loaded and initialized swrast
[ 27.012] (II) GLX: Initialized DRISWRAST GL provider for screen 1
[ 27.666] (II) config/udev: Adding input device Sun Type 5 keyboard (/dev/input/event0)
[ 27.666] (**) Sun Type 5 keyboard: Applying InputClass "evdev keyboard catchall"
[ 27.667] (II) LoadModule: "evdev"
[ 27.668] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 27.684] (II) Module evdev: vendor="X.Org Foundation"
[ 27.684] compiled for 1.12.1, module version = 2.7.0
[ 27.684] Module class: X.Org XInput Driver
[ 27.684] ABI class: X.Org XInput driver, version 16.0
[ 27.684] (II) Using input driver 'evdev' for 'Sun Type 5 keyboard'
[ 27.685] (**) Sun Type 5 keyboard: always reports core events
[ 27.685] (**) evdev: Sun Type 5 keyboard: Device: "/dev/input/event0"
[ 27.685] (--) evdev: Sun Type 5 keyboard: Vendor 0x10 Product 0x5
[ 27.685] (--) evdev: Sun Type 5 keyboard: Found keys
[ 27.685] (II) evdev: Sun Type 5 keyboard: Configuring as keyboard
[ 27.685] (**) Option "config_info" "udev:/sys/devices/root/f005fa24/f00611c4/f00632c8/serio0/input/input0/event0"
[ 27.686] (II) XINPUT: Adding extended input device "Sun Type 5 keyboard" (type: KEYBOARD, id 6)
[ 27.686] (**) Option "xkb_rules" "evdev"
[ 27.686] (**) Option "xkb_model" "pc105"
[ 27.686] (**) Option "xkb_layout" "fr"
[ 27.686] (**) Option "xkb_variant" "latin9"
[ 27.905] (II) config/udev: Adding input device Sun Mouse (/dev/input/event1)
[ 27.905] (**) Sun Mouse: Applying InputClass "evdev pointer catchall"
[ 27.905] (II) Using input driver 'evdev' for 'Sun Mouse'
[ 27.905] (**) Sun Mouse: always reports core events
[ 27.905] (**) evdev: Sun Mouse: Device: "/dev/input/event1"
[ 27.906] (--) evdev: Sun Mouse: Vendor 0x2 Product 0x1
[ 27.906] (--) evdev: Sun Mouse: Found 3 mouse buttons
[ 27.906] (--) evdev: Sun Mouse: Found relative axes
[ 27.906] (--) evdev: Sun Mouse: Found x and y relative axes
[ 27.906] (II) evdev: Sun Mouse: Configuring as mouse
[ 27.906] (**) evdev: Sun Mouse: YAxisMapping: buttons 4 and 5
[ 27.906] (**) evdev: Sun Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 27.906] (**) Option "config_info" "udev:/sys/devices/root/f005fa24/f00611c4/f0064b28/serio1/input/input1/event1"
[ 27.907] (II) XINPUT: Adding extended input device "Sun Mouse" (type: MOUSE, id 7)
[ 27.907] (II) evdev: Sun Mouse: initialized for relative axes.
[ 27.908] (**) Sun Mouse: (accel) keeping acceleration scheme 1
[ 27.908] (**) Sun Mouse: (accel) acceleration profile 0
[ 27.908] (**) Sun Mouse: (accel) acceleration factor: 2.000
[ 27.909] (**) Sun Mouse: (accel) acceleration threshold: 4
[ 27.910] (II) config/udev: Adding input device Sun Mouse (/dev/input/mouse0)
[ 27.910] (II) No input driver specified, ignoring this device.
[ 27.910] (II) This device may have been added with another device file.
The two creator graphics are ok, under solaris 10 I can have two displays and I can travel the pointer between the two desktops.
Any idea ?...
jpstewart
Unread postby jpstewart » Wed Feb 08, 2017 4:54 pm
Well, since nobody's offered any better advice, here's my two cents worth!
To get a dual-head setup working correctly, you'll absolutely need to create an xorg.conf file in /etc/X11. Here are some bits from my own dual-head system (although it's an Intel-based one) with relevant info from your log file substituted in, to get you started:
Section "Device"
   Identifier  "device0"
   Driver      "sunffb"
   BusID       "SBUS:/SUNW,ffb@1e,0"
EndSection
Section "Device"
   Identifier  "device1"
   Driver      "sunffb"
   BusID       "SBUS:/SUNW,ffb@1d,0"
EndSection
Section "Monitor"
   Identifier  "monitor0"
EndSection
Section "Monitor"
   Identifier  "monitor1"
EndSection
Section "Screen"
   Identifier  "screen0"
   Device      "device0"
   Monitor     "monitor0"
EndSection
Section "Screen"
   Identifier  "screen1"
   Device      "device1"
   Monitor     "monitor1"
EndSection
Section "ServerLayout"
   Identifier  "layout"
   Screen      0 "screen0" 0 0
   Screen      1 "screen1" RightOf "screen0"
EndSection
Replace all the ...s with whatever is necessary for you setup. Unfortunately, you'll probably have to spend some time reading the xorg.conf man page to complete the above to make something usable on your configuration. The main points, though, are that you need a Device section with appropriate BusIDs (taken from your posted log) for each graphics card, and a Monitor section for each, two screen sections each associating one Device with one Monitor, and a single ServerLayout section telling xorg how to place the two screens relative to each other. (RightOf in my example can also be LeftOf, Above, or Below depending on how your monitors are arranged.) You might need to add InputDevice sections for you mouse and keyboard, too, and then add them to the ServerLayout.
You'll also have to decide whether or not you want to run in Xinerama mode where the two physical screens are treated as one large logical display and you can drag windows between them (but sometimes end up with windows/applications spanning the two). Without it, applications will stay on the screen they're started on and can't be dragged across. Try both, and see what works for you. To have two distinct screens add:
Section "ServerFlags"
   Option   "Xinerama" "off"
EndSection
That's how I run my multi-head setups. Then you can start applications on one screen or the other by setting DISPLAY=:0.0 or DISPLAY=:0.1 before launching them.
I hope this helps get you going in the right direction. Good luck!
HP C8000
Digital DECstation 5000/125
yungjoon
Unread postby yungjoon » Thu Feb 09, 2017 8:10 am
Hi,
Thanks for your help, will try to rebuild a xorg.conf file from yours.
Anyone have a xorg.conf file from a debian install on his ultrasparc/creator3D config ? It would be the easiest way to correct my file.
yungjoon
Unread postby yungjoon » Thu Feb 09, 2017 11:12 pm
Hi,
I would like to stop temporarely the X server to execute xorg command (I have xfce destop). Is there a simple way to do this ?
I tried:
/etc/init.d/gdm stop || /etc/init.d/gdm3 stop || /etc/init.d/kdm stop || /etc/init.d/xdm stop || /etc/init.d/lightdm stop
It stops X server but don't switch to prompt.
Return to “Sun”
Users browsing this forum: Mustafa and 2 guests
