Siemens Nixdorf RW 320 (Indigo R3k)
escimo
Re: Siemens Nixdorf RW 320 (Indigo R3k)
Unread postby escimo » Thu Mar 09, 2017 10:53 am
Don't know a better place where to put the photo. BTW: have the perm of the owner to show this photo w/ SNI labeled Indy's, one white, the other origin color w/ foreign SNI logo.
Sorry for rape the thread after four month for this :-\
Sun Solaris 2.4 @ SPARCstation 2 and SNI PCD-4H. Migration path: NetBSD
jirka
Unread postby jirka » Fri Mar 10, 2017 8:12 am
The white SNI-labelled Indy is really interesting! Thank you very much for the picture!
jirka
Unread postby jirka » Sat May 20, 2017 2:30 pm
Just upgraded the machine with more RAM and the Z-buffer card:
1 33 MHZ IP12 Processor
FPU: MIPS R2010A/R3010 VLSI Floating Point Chip Revision: 4.0
CPU: MIPS R2000A/R3000 Processor Chip Revision: 3.0
On-board serial ports: 2
Main memory size: 80 Mbytes
Integral Ethernet: ec0, version 0
Integral SCSI controller 0: Version WD33C93B, revision C
Iris Audio Processor: revision 10
Graphics board: GR2-XS24 with Z-buffer
The Z-buffer thingy can is this one: http://www.ebay.com/itm/Z-buffer-for-SGI-IRIS-Indigo-system-030-8060-001-/142345006643
:O2: :O2: :1600SW: :1600SW: :Indy: :Indy: :Indigo: :Indigo:
escimo
Unread postby escimo » Sun May 21, 2017 2:42 am
Nice update. So this is now the maxed out version of the XS?
jirka
Unread postby jirka » Sun May 21, 2017 10:04 am
Yes, it is. There is no more space for expansion. Actually it's a very nice update: 3D stuff is much faster now. Visualization in the MeshTV were very slow withoiut the Z-buffer card and now are OK.
Users browsing this forum: ChinChiller and 0 guests
