Panasonic AG-1970p -> DIVO?
Zerolapse
Unread postby Zerolapse » Wed May 04, 2016 7:31 am
Hey All,
This might be a dumb question but I bought a beautiful Panasonic AG-1970p to capture some old home movies. I originally intended to plug it into either my O2 or my Octane compression board to capture, but I noticed that it's got BNC connectors on the rear as well as s-video. Are these just composite over BNC or are they actually SDI? The manual is really non-specific about them (it just says they're video in and video out basically) so I'm assuming they're just composite, but I figured I'd try to verify that. The reason I'm asking is that I actually have a DIVO board in my Octane (bought for another purpose) and enough fibre channel disk to deal with the resulting uncompressed video which would likely be preferable for editing.
Thanks!
-Jesse
The current fleet.
Re: Panasonic AG-1970p -> DIVO?
Unread postby robespierre » Wed May 04, 2016 8:06 am
There is no reason to believe the output is SDI unless it is marked "Serial". no professional gear has ever used RCA connectors for anything.
edit: here are what SDI connectors on video gear look like. The first image is from a D1 deck and uses SMPTE 259M-C; the second is from a D2 deck and uses SMPTE 259M-A. They both also have parallel video I/O, which is exactly the same data over a parallel cable.
D1 connectors
D2 connectors
Unread postby uunix » Wed May 04, 2016 8:35 am
Zerolapse wrote:Hey All,
Thanks!
-Jesse
If it's the same model that I have in the loft, which is white and broke, it is not SDi it's RF. It was one of the first bits of video kit I wrongly bought.
Zerolapse
Unread postby Zerolapse » Wed May 04, 2016 1:47 pm
Nice, thanks for clearing that up, guys! I do have an svideo -> sdi converter so I can get it done either way, but using the O2 (or repairing my compression board) might be slightly more sensible.
Thanks again!
-Jesse
The current fleet.
Return to “SGI: Video”
