Recommendations
Ravege
Recommendations
Unread postby Ravege » Fri Oct 30, 2015 10:00 am
Hey guys, contemplating dusting the dust off my SGI boxes. Looking for some ideas on securing, or improving security, or generally hardening the machines. I haven't worked with any UNIX for awhile, so even general/not IRIX specific stuff would be great. Thanks!
:Octane: 2x600 R14K, 8G, V12
:O2: 1x600 R7K, 1G
:Indigo2IMP: 1x75 R8K, 256M
Re: Recommendations
Unread postby robespierre » Fri Oct 30, 2015 11:21 am
remove sendmail, replace with patched qmail
remove inetd, replace with UCSPI
enable strict IPFilter rules
or the easier alternative, use behind a firewall
Re: Recommendations
Unread postby robespierre » Fri Oct 30, 2015 12:37 pm
But you need to take care of application security as well, I would be especially cautious of netscape and acrobat.
Re: Recommendations
Unread postby vishnu » Tue Nov 03, 2015 4:57 pm
robespierre wrote:or the easier alternative, use behind a firewall
Concur. I've got a really solid firewall between my home LAN and the Internet and I've never had any security problems with my IRIX boxes at all. Although, disclaimer wise I don't use my IRIX boxes to surf the Internet. But many members here do and no one's yet reported that their IRIX boxes were attacked as a result...
Re: Recommendations
Unread postby ClassicHasClass » Tue Nov 03, 2015 10:21 pm
Most of my machines are on a secured network that can't route (directly) to the Internet. Only a few have outside facing NICs, and none of them are the SGIs.
Re: Recommendations
Unread postby robespierre » Wed Nov 04, 2015 7:53 am
That's by far the best approach.
Krokodil
Re: Recommendations
Unread postby Krokodil » Sun Nov 08, 2015 11:57 am
ClassicHasClass wrote:Most of my machines are on a secured network that can't route (directly) to the Internet. Only a few have outside facing NICs, and none of them are the SGIs.
All my vintage systems are on a network that has no physical connections to the main network. The only way to get files in and out of the network is by attaching a crossover cable to a FreeBSD box where the files are staged. I just don't feel that my IRIX boxes should be on the internet.
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
necron2600
Re: Recommendations
Unread postby necron2600 » Mon Nov 09, 2015 9:33 am
If you wanted to get more exotic with security protection on IRIX with one of the best products for locking down a system (my opinion).. eTrust Access Control (owned by CA) works with lots of Unix type platforms including IRIX. Last I worked with that product was with eTrust Access Control for UNIX version 8. Its like a tripwire tool but with enforcement and central auditing and control sortof like SELinux and sudo (although it can work standalone on a single system). Intruders cannot circumvent its protections or exploit vulns in apps that easily.
Looking through the CDs for version 5.1.. it seems that it works on the following platforms: DECUNIX4, DYNIXPTX, IRIX64, IRIX, LINUX390, LINUX, NCR, SINIX, SOLARIS x86, UNIXWARE, RSV, Solaris, STOP, AIX43, AIX4, HPUX1020, HPUX10, HPUX11, couple mainframes and NT-i386.
I never did try it on IRIX before.. another weekend project ;)
Its downfall may be it is not simple to setup, poor marketing by CA. Plus, not sure on how much it costs.
-Kevin
Re: Recommendations
Unread postby foetz » Mon Nov 09, 2015 9:40 am
just run everything behind a router/firewall and you're fine. general, golden rule; goes for all systems.
then you can surf and whatever else you wanna do with your sgis and any other specials you might have
Re: Recommendations
Unread postby vishnu » Mon Nov 16, 2015 11:00 am
Krokodil wrote: just don't feel that my IRIX boxes should be on the internet.
But if they're behind a NATing firewall are they really on the Internet? I think there's a big difference between being on the Internet and being able to get to the Internet. In the 8 years since I've had IRIX boxes on my LAN, and knowing of my firewall as the Internet gateway, I've never had a problem. I hasten to add that not knowing of any problems doesn't mean there aren't any problems. For all we know the NSA could be sitting inside all our computers. Although, if they were inside mine, why haven't I been cuffed and stuffed yet? "Guilty of every computer crime we have a law for..." :lol:
Re: Recommendations
Unread postby Trippynet » Mon Nov 16, 2015 12:28 pm
I'm with Vishnu here. My SGIs are all firewalled and have unnecessary services turned off, but otherwise do have Internet access. So far, no problems that I'm aware of.
Overall, I think ancient copies of Firefox and a dead-end and niche OS are not really what you'd call major attack targets. Everything these days seems to focus on Windows or mobile phones where a successful attack can yield a lot more benefit for attackers.
Re: Recommendations
Unread postby robespierre » Mon Nov 16, 2015 12:50 pm
The long time since the last patch means that researching new exploits isn't the point. All the old ones still work and serving an exploit to a vulnerable machine has long been completely automated.
Heartbleed? What's that?
Krokodil
Re: Recommendations
Unread postby Krokodil » Mon Nov 16, 2015 2:56 pm
I know they're not directly facing the internet, but the browsers and applications like java are stone age and questionable in todays wild west internet.
Guilty of every computer crime, eh? lol.
If the NSA is in your computer the reason you haven't been busted is because they don't consider whatever your doing enough to justify blowing their secrecy. But every roadblock you put up against these jerks makes their job that much harder and makes them spend more money on it, it may even force them to risk exposing themselves - like breaking into your house and getting caught.
Re: Recommendations
Unread postby vishnu » Mon Nov 16, 2015 11:33 pm
Krokodil wrote:I know they're not directly facing the internet, but the browsers and applications like java are stone age and questionable in todays wild west internet.
I concur with that sentiment, I don't use any Internet software on any of my sgi's. But I know a lot of folks here have been using firefox 3 on their sgi's with no apparent problem.
Krokodil wrote:Guilty of every computer crime, eh? lol.
Nah, this is the Land of the Free, they'd get some idiot judge to sign a warrant and then they'd show up in an armored personnel carrier, shoot tear gas canisters through my windows, use a robotic battering ram to knock down my door, throw in a dozen flash bang grenades, rush in wearing body armored ninja suits wielding m4 carbines with the safeties off, most likely shoot me fifty or sixty times and then hold a press conference to tell the world what a huge favor they've done them... :shock:
diegel
Re: Recommendations
Unread postby diegel » Mon Nov 16, 2015 11:35 pm
I am still running Irix systems on the Internet. This are private projects, like the nekoware mirror and I had never problems with it. Our company used around the year 2000 a Challenge S as a secondary nameserver. This server was located at another Internet service provider (for free) and we simply forget this server. When this company moved the location some years ago, they asked us if we still using this server. So we got it back and examined it, it was running Irix 6.2 and never get hacked after 10 years running without any administration.
Return to “SGI: Security”
