GCC-4.8.0 porting.
- rosehillbob
GCC-4.8.0 porting.
I am currently working on replacing the IRIX specific source code removed from GCC 4.8.0 and later distributions. I am down to remaining 10K lines of code to check and if nothing unexpected shows up should have a patch file to build a GCC 4.8.0 compiler ready in a couple of weeks.
Re: GCC-4.8.0 porting.
Great stuff! It's something I've wanted to do myself to be honest, but I probably lack the programming/debugging skills to do it properly. I imagine the later 5.x builds will be a lot more difficult.
Wish you the best of luck!
- Nitrogen: R10000 195MHz CPU, 384MB RAM, SolidIMPACT Graphics, 36GB 15k HDD & 300GB 10k HDD, 100Mb/s NIC, New/quiet fans, IRIX 6.5.22
- Lithium: R14000 600MHz CPU, 4GB RAM, V10 Graphics, 72GB 15k HDD & 300GB 10k HDD, 1Gb/s NIC, New/quiet fans, IRIX 6.5.30
Other system in storage:
R5000 200MHz, 224MB RAM, 72GB 15k HDD, PSU fan mod, IRIX 6.5.30
I really wonder what happened to this interesting project - the announcement was made more than 2 years ago.
From v4.80 it is (possibly) a very small step to v4.81 which would bring support for all major features of C++11.
https://gcc.gnu.org/gcc-4.8/cxx0x_status.html
