Dillo 3.0.5
diegel
Dillo 3.0.5
Unread postby diegel » Mon Jul 13, 2015 1:19 pm
Dillo 3.0.5 is available in beta now:
+- Image buffer/cache improvements.
 - Fix for segfault when there's no dpid and view source is requested.
 - Fix view-source dpi to handle null characters correctly.
 - Made view-source dpi use CSS formatting (it's shorter and cleaner).
   Patches: Jorge Arellano Cid
+- Crosscompile/buildroot-friendly fltk-config test.
   Patch: Peter Seiderer
+- Fix X11 icon name.
 - In location bar, tend toward showing beginning of URL instead of end.
 - Handle irix's version of vsnprintf().
 - INPUT, TEXTAREA placeholder attribute.
 - Better notification when user's domainrc settings block page redirection.
 - Fix bug with font_factor preference and CSS font-size:(larger|smaller).
 - Recognize Menu key in keysrc.
 - HTTPS: change cipher list to "ALL:!aNULL:!eNULL:!LOW:!EXPORT40:!RC4",
   disable SSL3, disable TLS compression.
   Patches: corvid
+- Avoid requesting background images if an ancestor has display:none.
 - Ignore built-in search url if any are specified in dillorc.
Re: Dillo 3.0.5
Unread postby foetz » Mon Jul 13, 2015 1:24 pm
wow they even listed an irix change
diegel
Re: Dillo 3.0.5
Unread postby diegel » Tue Aug 01, 2017 8:52 am
I build a new dillo 3.0.5 with a fixed fltk. The font rendering problem is solved now. It will show up in beta, when neko find some time. If you want to try it now, you can download it at ftp://ftp.nekoware.de:/diegel/neko_dillo-3.0.5.tardist
necron2600
Re: Dillo 3.0.5
Unread postby necron2600 » Tue Aug 01, 2017 7:24 pm
Thank you! #1 app I use on IRIX.
cris_adder
Re: Dillo 3.0.5
Unread postby cris_adder » Wed Aug 02, 2017 1:53 am
Great! Thanks..
