Install Flame Without Corrupting Users Environment?
strong_epoxy
Unread postby strong_epoxy » Sun May 24, 2015 9:03 pm
Install Flame and it takes over the machine's environment. Toolchest is abreviated etc... Is there a way to install it like a normal piece of software?
:Cube: :Octane: :Octane2: :O2: :1600SW: :Indigo2IMP: :Indigo: :Indy: :320: :1600SW: :Fuel: :Onyx2:
Re: Install Flame Without Corrupting Users Environment?
Unread postby foetz » Sun May 24, 2015 11:00 pm
chkconfig desktop on
after the installation should do the trick. however the (formerly) discreet programs do what they do for good reason so changing stuff that's set by the installer might cause problems
Unread postby Raion-Fox » Mon May 25, 2015 9:56 am
Install Discreet products under separate users from your main account :)
Unread postby foetz » Mon May 25, 2015 3:14 pm
TeamBlackFox wrote:Install Discreet products under separate users from your main account :)
that's not enough. the installer changes global settings
Unread postby vishnu » Tue May 26, 2015 12:44 am
If all it's borking is the toolchest just grab the system.chestrc (or whatever it's called, don't have mine on at the mo to check for sure), copy it to your home directory as .chestrc and edit to your heart's content! :mrgreen:
Return to “SGI: Video”
