Indy XL TrueColor
Re: Indy XL TrueColor
Unread postby foetz » Wed Mar 18, 2015 5:27 pm
PowerGraphics wrote:If I understand well, all I need to do to my system supports 24bit (dithered or not), it would be put in the Xserver file, only the command -depth 24, and nothing else, not even put -class TrueColor (or PseudoColor or DirectColor), is this?
just try it, it can't do much harm
alexott
Unread postby alexott » Sun May 03, 2015 3:10 am
robespierre wrote:SGI's Virtual-24 technology is hardware-assisted dithering. The Xserver provides a 24-bit DirectColor visual to applications, which can run as if they had a 24-bit graphics device. The GL system dithers that visual using an 8-bit LUT optimized for the colors the application uses.
By contrast, HP's Color Recovery technology also processes the data on the backend, turning the dithering back into an approximation of the original color information. It was only found on the 715's HCRX and the 712's integrated graphics.
Did SGI implemented Virtual-24 with zero performance penalty? I know that HP did so: http://www.bytecellar.com/2005/02/09/my_hp_9000_7126/
PowerGraphics
Unread postby PowerGraphics » Sat Jul 22, 2017 7:45 pm
When I used IRIX 5.3 on my Indy, changing the Xserver file, it was possible to use truecolor, the photos were super perfect and bright. I know it was simulated, but it was possible.
How to do this in IRIX 6.2 or 6.5?
Unread postby vishnu » Mon Jul 24, 2017 12:30 pm
PowerGraphics wrote:When I used IRIX 5.3 on my Indy, changing the Xserver file, it was possible to use truecolor, the photos were super perfect and bright. I know it was simulated, but it was possible.
Depending on what your Indy can actually do, it would probably be some variant of this:
http://software.majix.org/irix/desktop-depth.shtml
