24" GDM-FW9011, virtu cases or machines
NICKERZ
Unread postby NICKERZ » Sun Feb 08, 2015 11:14 pm
Maybe not your traditional SGI fanboy stuff, but I'm looking! I am aware that neither of these are technically SGI hardware (Sony & Boxx respectively)
Re: 24" GDM-FW9011, virtu cases or machines
Unread postby vishnu » Fri Feb 13, 2015 9:13 pm
We had hundreds of the 24" SGI and Sun monitors at work back in the day, we called 'em double-wides, and yes the CRTs were all Sony Trinitrons, really beautiful monitors. We recycled the whole lot of 'em and the recycler sent them all off to the smelter... :|
Unread postby foetz » Sat Feb 14, 2015 1:01 am
vishnu wrote:We had hundreds of the 24" SGI and Sun monitors at work back in the day, we called 'em double-wides, and yes the CRTs were all Sony Trinitrons, really beautiful monitors. We recycled the whole lot of 'em and the recycler sent them all off to the smelter... :|
terrible, i'd be only too glad to take them all :D
Unread postby hamei » Sat Feb 14, 2015 4:30 am
foetz wrote:
vishnu wrote:We had hundreds of the 24" SGI and Sun monitors at work back in the day ... We recycled the whole lot of 'em ... :|
You must live on the ground floor ....
Unread postby vishnu » Sat Feb 14, 2015 11:18 am
They were a two-man lift all right... :roll:
NICKERZ
Unread postby NICKERZ » Mon Feb 23, 2015 10:30 am
That's probably an easy $100K down the drain ;)
Unread postby Trippynet » Mon Feb 23, 2015 12:46 pm
Yep. Decent CRTs are still worth something even today. I used to be in charge of IT for a Psychology department at a university until 2 1/2 years ago and they still to this day use CRTs for most of their research simply because you get millisecond-precise timing from them, plus most decent ones support refresh rates of 100-120Hz. As so many have been scrapped and they've become so rare, a decent 20"+ monitor with good refresh rates therefore has quite a value these days.
TFTs are getting there, but 1ms ones with high refresh rates are still rare and expensive, plus all of them are horrible 16:9 jobbies at the moment.
NICKERZ
Unread postby NICKERZ » Wed Aug 05, 2015 3:43 pm
BUMP!
mashek
Unread postby mashek » Wed Aug 12, 2015 8:22 pm
Hi NICKERZ,
I have two of these that I already fixed the dreaded greenblack issue. They are REALLY heavy, therefore they would ship on pallet.
I want $800each + shipping. I will test them before I ship them (and lift them up onto my bench all by myself if necessary).
Thanks,
Doug
Douglas V. Mashek mailto:doug@mashek.com
Mashek Systems www: http://www.mashek.com
:320: :540: :1600SW: :O2: :O2+: :Indigo: :Octane: :Octane2: :Tezro: :Indigo2: :Indigo2IMP: :Indy: :Fuel: :PI: :O200: :Onyx: :ChallengeXL: :OnyxR: :O2000: :Onyx2: :O2000R: :O2000E: :O2000E: :O2000E: :metarouter: :O2000E: :O2000E: :O2000E: :O2000E: :Onyx2RE: :Onyx2RE: :Onyx2R: :Onyx2RE: :O3000: :O3000: :O3200: :0300: :0300: :0300: :0300:...
NICKERZ
Unread postby NICKERZ » Tue Apr 18, 2017 8:57 am
bump
BetXen
Unread postby BetXen » Sun Apr 23, 2017 9:04 am
Still want one ? I have one, in Switzerland. Where are you ?
Return to “Hardware Wanted”
