New package: XScreensaver 5.30
Axatax
Unread postby Axatax » Tue Oct 07, 2014 3:49 am
Sent a new XScreensaver to /incomming.
This version pulls in all of the patches from the previous versions and incorporates the 5.10 XDM locking patch.
I don't think the XScreensaver in /current can even be installed at this point (?) due to impossible-to-meet dependencies.
neko_xscreensaver-5.30.tardist
:Octane2: Dual R14K@600MHz, 2GB RAM, V12, 1x72GB HDD
:O2: R10K@175MHz, 512MB RAM, 1x72GB HDD
:Cube: 68040@33MHz, 128MB RAM, NeXTdimension 32MB, 2x 4.3GB HDD
...And lots of other UNIX-like systems for which there is no icon.
Axatax
Re: New package: XScreensaver 5.30
Unread postby Axatax » Sun Oct 12, 2014 6:21 pm
I sent new versions of neko_xscreensaver and neko_rssglx into /incoming.
The previous versions I sent are junk.
New versions --
neko_xscreensaver-5.30-r3.tardist
neko_rssglx-1.9.1-r1.tardist
Hey -- I'm learning, and /incomming is "beta", right?
The previous rssglx had binaries permissioned as my user and the xscreensaver was built without SGI X extensions.
Unread postby vishnu » Tue Oct 14, 2014 12:25 pm
Did you include skyrocket from rss? On my V12 equipped 600MHz Octane2 skyrocket drops something like 19 out of every 20 frames... :shock:
Axatax
Unread postby Axatax » Tue Oct 14, 2014 4:01 pm
It's the whole package, and there is a new saver, Pixel City.
Unread postby guardian452 » Tue Oct 14, 2014 6:09 pm
vishnu wrote:Did you include skyrocket from rss? On my V12 equipped 600MHz Octane2 skyrocket drops something like 19 out of every 20 frames... :shock:
It ran great on that old infinitereality onyx of mine which you poo-pooed because it was so old (1995). Ok, not 60hz but it could easily hang at 30 or 20 most of the time.
ISTR The only one it really struggled with was hyperspace.
Axatax
Unread postby Axatax » Tue Oct 14, 2014 7:23 pm
They all work really good on my V12 Octane with the exception of Lorenz which is a real pig.
Unread postby vishnu » Fri Oct 17, 2014 11:41 pm
Seriously? On the root window? At what resolution? Because my Linux box and my Octane are both circa-1994, both dual processor, both using (what was then) state of the art graphics (Nvidia GForce 5700 w/256 meg RAM vs. V12 w/128 meg RAM) both running at 1600x1200, and the difference in smoothness is dramatically better on my Linux box... :|
Axatax
Unread postby Axatax » Sun Oct 19, 2014 11:38 pm
2x 600 Octane here and it works perfectly. Definitly nothing like 19/20 dropped frames - just (very) slight studder when alot of fireworks go off at once.
Axatax_
Unread postby Axatax_ » Sat Jan 31, 2015 2:55 pm
Sent the xscreensaver 5.32 and rss-glx update to /incomming.
