Shellshock
pentium
Shellshock
Unread postby pentium » Thu Sep 25, 2014 8:56 am
Now that the word is out about this absolutely massive bash exploit, should any of us folks still running Irix machines on the net be at all concerned?
An article on it.
duck
Re: Shellshock
Unread postby duck » Thu Sep 25, 2014 9:59 am
Only on two cases:
The specific: If you use a bash script for CGI
The general: If you've replaced /bin/sh with bash
I'll add that the exploit-tests I've seen in my logs are using ping to test if it works; ours is in /usr/etc and AIUI that's not in the default path so even if you're vulnerable it wouldn't trigger the scriptkiddies at least.
___(o)=
\____)
Re: Shellshock
Unread postby ClassicHasClass » Thu Sep 25, 2014 1:58 pm
You're more cooked if you're on a system where /bin/sh == /bin/bash. OS X is such a system. I quickly built a standalone bash for 10.4+ PPC/Intel if you want one of those.
http://tenfourfox.blogspot.com/2014/09/ ... -bash.html
But I think IRIX is very low risk.
VenomousPinecone
Shellshock Bash bug?
Unread postby VenomousPinecone » Thu Sep 25, 2014 3:45 pm
Screen Shot 2014-09-25 at 3.37.27 PM.png (19.21 KiB) Viewed 1856 times
Re: Shellshock
Unread postby josehill » Thu Sep 25, 2014 4:06 pm
Re: Shellshock
Unread postby foetz » Thu Sep 25, 2014 4:34 pm
good thing i never liked bash :P
Re: Shellshock
Unread postby ClassicHasClass » Thu Sep 25, 2014 5:59 pm
Re: Shellshock
Unread postby SAQ » Thu Sep 25, 2014 8:19 pm
Why'd they start replacing /bin/sh with BASH anyway? Sun went into depth as to why that was not a good idea (and better to have a static /bin/sh), and it's not like sh added too much bloat to the system.
Re: Shellshock
Unread postby hamei » Thu Sep 25, 2014 8:45 pm
SAQ wrote:Why'd they start replacing /bin/sh with BASH anyway?
Heathen ! get thee hence, thou Unbeliever !
Re: Shellshock
Unread postby josehill » Thu Sep 25, 2014 8:58 pm
SAQ wrote:Why'd they start replacing /bin/sh with BASH anyway? Sun went into depth as to why that was not a good idea (and better to have a static /bin/sh), and it's not like sh added too much bloat to the system.
What are you, some sort of graybeard who knows things and stuff? ;)
Re: Shellshock
Unread postby ClassicHasClass » Thu Sep 25, 2014 10:36 pm
Second patch seems to pass muster:
http://seclists.org/oss-sec/2014/q3/734
I updated the OS X universal bash already (10.4-10.9, PPC and x86).
http://tenfourfox.blogspot.com/2014/09/ ... dated.html
Re: Shellshock
Unread postby josehill » Fri Sep 26, 2014 6:03 am
ClassicHasClass wrote:I updated the OS X universal bash already (10.4-10.9, PPC and x86).
Thanks, CHC! I'll load it on some machines today!
Re: Shellshock
Unread postby robespierre » Fri Sep 26, 2014 6:03 am
$ sudo -s
# chmod -x /bin/bash
# ln -f /bin/ksh /bin/sh
fuggeddaboutit....
duck
Re: Shellshock
Unread postby duck » Fri Sep 26, 2014 10:04 am
robespierre wrote:
$ sudo -s
fuggeddaboutit....
On linux this will likely break things badly. Remember that these kids have been thinking that sh = bash since they first licked a beige box.
___(o)=
\____)
VenomousPinecone
Re: Shellshock
Unread postby VenomousPinecone » Fri Sep 26, 2014 11:11 am
duck wrote:[...]since they first licked a beige box.
Whaddya' mean? that's not what the floppy drive is for? All these years of my life spent in confusion.
Return to “SGI: Security”
