Octane 2 2*R12K 400MHz 2,5GB RAM vPro v12
eudatux23
Unread postby eudatux23 » Fri Sep 19, 2014 9:20 am
This is my main SGI workstation running IRIX 6.5.30. I use it mainly for watching graphics demos, light web surfing and playing OpenGL-games like Quake III. IMHO it is amazing what this old machines can do. It's a lot of fun using it today.
Here are the relevant outputs for you:
hinv -vm:
rocktane 3# hinv -vm
      PM20400MHZ Board: barcode MDA241     part 030-1476-002 rev  B
            IP30 Board: barcode FTB546     part 030-1467-001 rev  A
    PWR.SPPLY.ER Board: barcode AAE1090253 part 060-0035-002 rev  A
             FP1 Board: barcode 27915C     part 030-0891-003 rev  E
           ODY32 Board: barcode LLX642     part 030-1403-003 rev  B
2 400 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 2560 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V6
/usr/gfx/gfxinfo:
rocktane 4# /usr/gfx/gfxinfo
        Managed (":0.0") 1024x768
        BUZZ version A.1
        PB&J version 1
        32MB memory
                Banks: 2, CAS latency: 3
         Monitor 0 type: Unknown
         Video Output: 1024 pixels, 768 lines, 59.96Hz (1024x768_60)
uname -aR:
rocktane 5# uname -aR
IRIX64 rocktane 6.5 6.5.30m 07202013 IP30
scsicontrol -i /dev/scsi/sc0d1l0:
rocktane 8# scsicontrol -i /dev/scsi/sc0d1l0
/dev/scsi/sc0d1l0:  Disk          SEAGATE ST173404LC      0004
Device is  ready
A picture of it running Quake III
Reason: topic renamed as per request
:Octane2: SGI Octane 2 - Dual R12K 400 MHz - 250 0MB RAM - 73 GB HDD - vPro v12 - IRIX 6.5.30
:Indigo2IMP: SGI Indigo² - R10K 175 MHz - 320 MB RAM - 73 GB SCSI HDD - High Impact-AA + TRAM - IRIX 6.5.22f
:O2: SGI O2 - R5K 180 MHz - 96 MB RAM - 18 GB HDD - CRM - IRIX 6.5.30
eudatux23
Re: Octane 2 2*R12K 400MHz 2,5GB RAM vPro v6
Unread postby eudatux23 » Sat Apr 04, 2015 2:55 pm
New picture added:
Unread postby ClassicHasClass » Sat Apr 04, 2015 7:37 pm
Pretty!
eudatux23
Unread postby eudatux23 » Mon Apr 06, 2015 5:37 am
Is it possible to change the thread title because of the upgrade to V12?
Unread postby foetz » Mon Apr 06, 2015 6:19 am
eudatux23 wrote:Is it possible to change the thread title because of the upgrade to V12?
sure, but also change your hinv then :P
Unread postby recondas » Mon Apr 06, 2015 4:25 pm
foetz was kind enough to make the change to the title you requested, but anyone can change the title/subject line of posts they originated by clicking the "Edit" button located at the bottom of the post in question. Once you're in 'edit' mode, look for the "Subject" field near the top of the edit panel.
