[Review] Alias PowerAnimator v6
gocram
Re: [Review] Alias PowerAnimator v6
Unread postby gocram » Wed Dec 10, 2014 1:40 am
Another excellent thread, thanks for all the information and pictures! Threads like these embody what SGI always meant for me and my attraction to the platform and its amazing software library.
I would've loved to have been able to use this software myself at the time, or even know (like all those other monumental bygone software packages). I sadly only have access to some of it.
Either way, thanks again, keep up the excellent work.
LOOKING FOR:
ITEMS FOR SALE/TRADE
Unread postby jan-jaap » Tue Mar 03, 2015 5:57 am
ivelegacy wrote:which machine do you have guys, to run this marvelous application ?
i think an O2+/R12K is not enough, am i wrong ?
Alias|Wavefront used to publish 'qualified hardware' lists, but I can't find them right now. But this software is from 1995. It's almost certainly for IRIX 5.x, and might even still come with COFF binaries for IRIX 4.x
In 1995, the SGI 'entry' workstation was an Indy, and the IMPACT Indigo2 (with R4400 CPU) was as fast as it got without moving up to big iron.
I'd like to run this on, let's say, a 4D PowerSeries with R3000 CPUs and VGX graphics, or a Crimson Reality Engine 8-)
Unread postby foetz » Tue Mar 03, 2015 1:02 pm
the version 6 here was targeted at irix5. it was completely elf and had a few mips2 (r4x00) optimized versions of some program parts optionally available. it also came with a few legacy coff programs but they were just included for backwards compatibility and don't affect the actual program in any way.
the problem with this version however is the gfx support. it will not run on anything with impact or later. the only exception is infinite reality because the basics of that didn't change until the end.
ivelegacy wrote:which is the equivalent Application for a modern SGI/MIPS workstation (Octane/Fuel) ?
well, a later poweranimator :P
they had issues with vpro tho. only the later alias versions which didn't have the poweranimator license model anymore ran fine with vpro. don't get me wrong unlike the version 6 here the later versions do run with vpro. there're just a few glitches here and there.
Unread postby vishnu » Tue Mar 03, 2015 3:39 pm
Or Maya 6.5
Unread postby foetz » Tue Mar 03, 2015 5:01 pm
Or Maya 6.5
hehe of course any other 3d package that runs on whatever machine you have can be used. as always it's a matter of taste
Unread postby foetz » Tue May 26, 2015 6:25 am
grab the attachment of the post linked to below for large screen shots of alias/2. might just as well be the only ones you'll ever find
viewtopic.php?f=11&t=16729653#p7379715
Unread postby foetz » Sat Jan 23, 2016 11:17 am
i guess most of you are using later alias versions from the time when it was under the sgi roof. however if you wanna add some even more classic feel to it there's a way to get somewhat close:
first turn the palette off. just hit windows -> palette and it's gone. despite the 3 dots there that's just an on/off switch.
click the options button on the title bar of the shelf and load my v6_shelf file, replacing whatever shelf you currently have. you might wanna save yours first in case you customized it.
next head over to preferences -> interface -> palette/shelves layout and hit the cube for options. you should now have the window that looks like my screen shot. i framed the important parts in red. set the rest to your liking. hit go when done and you should have something useful already. in some cases tho the main window might be a little off. without the borders now you can't drag the edges nor the window itself to correct the size and/or position so in this case we need the hotkeys. for moving the window hit Alt+F7 while the mouse is somewhere over the window. the same goes for sizing it by using Alt+F8. it might take a few tries to get it right but in the end you should have something similar to my full screen shot.
so far so good, now to get the real alias research feeling don't use the icons but right click on the shelf tabs. my v6_shelf (as far as possible) has the same order and content as v6's and older versions' menus so that's pretty much as classic as you can get :-)
v6_shelf.bz2
(9.28 KiB) Downloaded 35 times
arhiman57
Unread postby arhiman57 » Sun Feb 28, 2016 1:21 am
Just about Alias 2, a new great video on youtube ! A lot of work is done on Alias directly on the screen with old 4D, include Pseudopod stuff :D
:PI: :PI: :PI: :Indigo: :Indigo: :Indigo: :Indy: :Indy: :Indy: :Indy: :Indy: :Indy: :Indigo2: :Indigo2IMP: :Onyx2: :Octane: :O2: :1600SW: :Fuel: :PrismDT:
Unread postby foetz » Sun Feb 28, 2016 2:38 am
fantastic, much thanks for that link!
by far the most comprehensive material i've seen so far :D
