6.5 packages
Re: 6.5 packages
Unread postby foetz » Sat Feb 14, 2015 10:12 am
nice thanks, grabbed it :-)
Re: 6.5 packages
Unread postby foetz » Wed Mar 18, 2015 9:56 pm
  • curl_7410.tardist
  • openssh_68p1.tardist
  • openssl_102.tardist
so that your box is safe :-)
Re: 6.5 packages
Unread postby vishnu » Thu Mar 19, 2015 12:45 pm
That's 1.0.2a, released today, right? Because they made five security fixes today to the 1.0.2 release in January... :shock:
Re: 6.5 packages
Unread postby foetz » Thu Mar 19, 2015 3:34 pm
lol seems i missed it by just a few minutes :P
EDIT:
  • openssl_102a.tardist
okay there it is
Re: 6.5 packages
Unread postby foetz » Fri Mar 20, 2015 8:25 pm
  • re2c_0141.tardist
this is quite neat. it's a regex to c translator. for details have a look at http://re2c.sourceforge.net.
it's "modern" c++ tho so mipspro builds on pre-6.5 irix are not gonna happen without quite some rewrites.
Re: 6.5 packages
Unread postby foetz » Sat Jun 13, 2015 5:40 pm
  • libmemcached_012.tardist
  • libev_419.tardist
  • memcached_1424.tardist
for the speedy stuff
Re: 6.5 packages
Unread postby foetz » Sun Jun 14, 2015 3:31 pm
  • libevent_2022.tardist
with ssl support
Re: 6.5 packages
Unread postby foetz » Mon Jun 29, 2015 4:35 pm
  • nedit_56a.bz2
  • xpdf_304.tardist
xpdf with greetings to hamei :D
Re: 6.5 packages
Unread postby foetz » Tue Sep 29, 2015 7:47 pm
mirror added. see first post
Re: 6.5 packages
Unread postby foetz » Sun Nov 08, 2015 12:36 pm
  • php_5530.tar.bz2
  • php_5530_apache24.tar.bz2
  • php_5530_ext.tar.bz2
  • apache_2417.tar.bz2
this is a special set for techgrrl but also for anyone else interested in using their sgi as a webserver of course.
the first php has no special sapi and can be used as fcgi with any webserver supporting it or of course for just running php scripts otherwise.
the second one contains as the name suggests the sapi for apache 2.4.x. copy the module from its dir to the other apache modules and edit the config accordingly.
the third php package contains the modules. i built php without much additional stuff to keep it flexible so in most cases you wanna grab the modules as well and use whatever you like. there's quite a bunch of them inside.
apache is, well, just the latest of the 2.4 branch. built with all modules so you can pick whatever you favor
techgrrl
Re: 6.5 packages
Unread postby techgrrl » Sun Nov 08, 2015 4:14 pm
foetz wrote:
  • php_5530.tar.bz2
This is awesome, and I didn't even know there were other download directories there - is this mirrored anywhere?
Cheers my friend!
techgrrl - Image ImageImage ImageImage Image - button pusher, point'n'clicker, photon collector
Re: 6.5 packages
Unread postby foetz » Mon Nov 09, 2015 1:33 am
techgrrl wrote:This is awesome, and I didn't even know there were other download directories there - is this mirrored anywhere?
as mentioned before, check the first post of this very thread :-)
Re: 6.5 packages
Unread postby foetz » Wed Sep 14, 2016 11:11 pm
  • vim_802.tar.bz2
yay a vim update after, well, quite some time and of course we gotta have that for irix so here it is. expects to go to /usr/local and then just add the bin dir to your $PATH or link away.
mips3 users can use the irix 5.3 version (here) as well as everyone using something in between 5.3 and 6.5.22.
Re: 6.5 packages
Unread postby foetz » Fri Oct 14, 2016 6:08 pm
  • ntp_428p8.tardist
  • perl_5125.tardist
jirka
Re: 6.5 packages
Unread postby jirka » Sat Oct 15, 2016 12:35 am
foetz wrote:
  • vim_802.tar.bz2
Many thanks! I use the 5.3 version on my IRIS Indigo (R3k) and it work well.
The version for 6.5 is nice, too (O2 R10k/250, IRIX 6.5.27).
