6.5 packages
6.5 packages
Unread postby foetz » Wed Jan 08, 2014 9:40 pm
figured one thread for the updates is probably the best way. everything is built with MIPSpro unless noted otherwise. the base dir is:
http://www.nekochan.net/downloads/index.php?path=foetz/
>> you can always use "rulesoverride" and ignore my deps as long as you have adequate replacements <<
MIRROR
r-a-c.de/dist/sgi/6.5/
append the package name since there's no listing
let's get right to it. new today:
  • uncrustify
  • f90ppr
these are source code formatters for terminal use. uncrustify is a terribly "modern" c++ junk but compared to using a java based ide for formatting it's still a blessing :P as an exception i used g++ for this one but no worries, it doesn't require any gnu libs.
f90ppr is the same but only for fortran and also written in fortran. i uploaded a 64bit and 32bit version, both mips4 and i used a lot of the specials mipspro has to offer so these 2 should run like hell :P
a version of f90ppr for 6.2 is likely to follow more or less soon but no luck with uncrustify which seems to require a quite recent g++. anyhow the 6.2 version of f90ppr should then also work for those of you running 6.5 with mips3.
Re: 6.5 packages
Unread postby vishnu » Thu Jan 09, 2014 10:21 pm
I should post some screenshots of the horribly formatted code written by the tiny subset of mechanical engineers at my place of employ who have decided they can program... :lol:
Re: 6.5 packages
Unread postby foetz » Fri Jan 10, 2014 6:55 am
haha, they might wanna make use of it :P
Re: 6.5 packages
Unread postby foetz » Wed Jan 15, 2014 2:48 pm
  • snappy_111.tardist
  • fltk_132.tardist
the second one should be clear and the first one is google's compression lib.
rvic
Re: 6.5 packages
Unread postby rvic » Thu Jan 16, 2014 6:26 pm
Thank you for the effort
Are these packages for 6.5.22 minimum or they could be installed in let's say 6.5.15 ?
Are there any packages for the lesser versions of 6.5 irix ... prior to 6.5.22 ?
Or should i use the 6.2 ones ... actually that's what i did until now.
For me 6.5.15 seems the best overall distribution ... in speed and stability ... i own an O2.
Thank you
Re: 6.5 packages
Unread postby foetz » Thu Jan 16, 2014 7:16 pm
rvic wrote:Thank you for the effort
i'm not sure actually :P
for some it might come down to a try but unless something is used that only existed in a version above 6.5.15 it should be fine.
Re: 6.5 packages
Unread postby foetz » Mon Feb 10, 2014 7:46 pm
algol68g_28.tar.bz2
for more info: http://jmvdveer.home.xs4all.nl/
PymbleSoftware
Re: 6.5 packages
Unread postby PymbleSoftware » Sun Feb 23, 2014 6:03 pm
foetz wrote:algol68g_28.tar.bz2
I think it was built without (or with broken) thread support or something. This from a quad 1GHz Tezro with 8Gb RAM:
cat test2.agl && bin/a68g test2.agl
MODE SIEVER = STRUCT (SEMA full, empty, REF INT n);
PROC make siever = SIEVER: (LEVEL 0, LEVEL 1, NEW INT);
PROC start siever = (SIEVER s, INT n) VOID:
  (n MOD 2 /= 0 | DOWN empty OF s; n OF s := n; UP full OF s);
PROC next unmarked = (SIEVER s) INT:
  (DOWN full OF s; INT n = n OF s; UP empty OF s; n);
PROC sieve = (SIEVER current) VOID:
  (INT n = next unmarked (current);
  print ((whole (n, -int width), new line));
  SIEVER new = make siever;
  PAR (
    DO IF INT i = next unmarked (current);
      i MOD n /= 0
      THEN start siever (new, i)
      FI
    OD,
    sieve (new)
SIEVER first = make siever;
INT n := 1;
PAR (DO n PLUSAB 1; start siever (first, n) OD, sieve (first))
         3
         5
         7
        11
        13
        17
        19
        23
        29
        31
18        sieve (new)
          1
a68g: runtime error: 1: cannot create thread (not enough space) (detected in
VOID collateral-clause starting at "(" in line 12).
tezro:~/local-code/algol>
R.
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
Re: 6.5 packages
Unread postby foetz » Sun Feb 23, 2014 9:19 pm
i only used regular configure options and didn't modify any source so as i said via pm already i'm not related to the project in any way and it did classify irix as unsupported platform. there were no errors and my thread related stuff works fine for any other program so you might wanna talk with the author about any issues that might come up
Re: 6.5 packages
Unread postby hamei » Sun Feb 23, 2014 11:19 pm
foetz wrote:... you might wanna talk with the author about any issues that might come up
Don't know if this applies but when I was messing with GraphicsMagicke I was told that threads in Irix and Open MP clash. Last time I talked to the head guy, he was working on this but up til now, you can't compile GM with both threads and OpenMP.
Seems odd since SGI was the mom of OpenMP but like a wilful child, it's forgotten its loving parents :(
Re: 6.5 packages
Unread postby jan-jaap » Mon Feb 24, 2014 12:36 am
The problem is that IRIX supports two thread models: traditional (sproc) threads and POSIX threads. You cannot mix thread models in a single IRIX process.
Several libraries in IRIX use sproc threads internally, probably because they date back to IRIX 5.3 or early 6.x days. For a developer this means that if you decide to use this library, and your code is threaded, it must use sproc threads.
Needless to say, these days everything assumes pthreads.
Re: 6.5 packages
Unread postby hamei » Mon Feb 24, 2014 2:23 am
jan-jaap wrote:The problem is that IRIX supports two thread models: traditional (sproc) threads and POSIX threads. You cannot mix thread models in a single IRIX process.
Thanks, j-j. Good to know the reason ... is there an easy way to know which libaries use which threads ?
Re: 6.5 packages
Unread postby jan-jaap » Mon Feb 24, 2014 5:03 am
I guess you should run
/usr/bin/nm -u
against /usr/lib32/*.so and grep for sproc ?
On my Origin 350 (IRIX 6.5.30) these libraries show up:
libC.so
libcl.so
libdmnet.so
libdplace.so
libdprof.so
libftn.so
libil.so
libinstr.so
libmoviefile.so
libmovieplay.so
libmp.so
libmp_pthreads.so
libnanothread.so
libpthread.so
libss.so
libvkSGI.so
Several of these belong to the WorkShop debugger. Before you ask: I don't know why libmp_pthreads.so and libpthread.so match :P
But man(5) pthreads is clear:
      Using sprocs
          The sproc(2) model of threading is incompatible with POSIX threads.
          Attempts by an sproc process to create pthreads and vice-versa will
          be rejected.
Re: 6.5 packages
Unread postby foetz » Fri Sep 19, 2014 10:55 pm
  • dillo304_fltk-gcc.tar.bz2
this is a double pack containing fltk 1.3.2 static libs and dillo 3.0.4. as the name suggests both compiled with neko gcc 4.7.
fltk is without docs and the fluid program, just the libs. it defaults to /usr/local/dillo3. you can put it anywhere as long as you edit fltk-config accordingly.
dillo has the vsnprintf changes applied but also a much lighter version of the downloads.cc patch as well as 2 ssl related dialogs disabled. the latter makes duckduckgo or ixquick actually usable because these dialogs have no "don't ask again" option. they affect occurences of X509_V_ERR_SELF_SIGNED_CERT_IN_CHAIN and X509_V_ERR_UNABLE_TO_GET_ISSUER_CERT_LOCALLY
Re: 6.5 packages
Unread postby vishnu » Sat Sep 20, 2014 4:54 pm
Just for funzies I'm still working on a MIPSPro compile of dillo that I pulled from the tip of their svn on August 30th...
