6.2 / 5.3 packages
Re: 6.2 / 5.3 packages
Unread postby foetz » Wed Oct 15, 2014 1:05 pm
5.3
  • gettext_0144.tardist
  • libjpeg_6b.tardist
  • libpng_1212.tardist
  • sed_412.tardist
  • curl_7200.tardist
  • libxml2_2612.tardist
  • pkgconfig_0120.tardist
  • readline_43.tardist
some of the usual suspects. more or less recent versions but should be fine for most tasks.
Unread postby foetz » Fri Oct 17, 2014 5:00 am
5.3
  • tcl_805.tardist
  • tk_805.tardist
  • libsnprintf.tar.bz2
libsnprintf contains snprintf, vsnprintf, asprintf and vasprintf. it's the same one i used for dillo3 for 6.2. it includes a static lib, ucode lib and a shared lib with so_locations. all not stripped so you can use it in any way you prefer. it does of course also work with all later versions of irix.
Unread postby foetz » Fri Oct 17, 2014 2:38 pm
5.3
  • ntp_412.tardist
Unread postby foetz » Sun Oct 19, 2014 11:26 am
5.3
  • libstrptime.tar.bz2
this is a substitute for strptime() that's not available on 5.3. as usual static, shared and ucode lib included as well as the prototype and not stripped
Unread postby foetz » Thu Oct 23, 2014 1:39 pm
5.3
  • openssl_097m.tardist
  • perl_500504.tardist
  • sylpheed_066.tardist
  • svn_155.tardist
  • aprutil_0912.tardist
  • apr_0912.tardist
also some of the old ones rebuilt thanks to some changes patch 1068 applies
Unread postby foetz » Sun Oct 26, 2014 10:13 am
5.3
  • xchat_143-gcc.tardist
the last version that didn't make heavy use of posix regex and only a gcc build. it was too gcc'ed for the mips c :P
Unread postby foetz » Fri Oct 31, 2014 4:40 pm
5.3
  • gimp_125.tardist
  • tiff_382.tardist
tiff is without c++ support for obvious reasons :P
Unread postby foetz » Mon Nov 24, 2014 8:48 pm
5.3
  • microline_xml.tar.bz2
6.2
  • bcpp_20131209.tardist
microline are the original netscape widgets and bcpp is a c++ source beautifier
Unread postby foetz » Fri Nov 28, 2014 10:13 pm
6.2
  • Perl-Magick-4.27.tar.bz2
  • imagemagick_427.tardist
the always popular set of gfx tools
Unread postby foetz » Mon Dec 01, 2014 4:13 am
5.3
  • gimp_0541.tar.bz2
6.2
  • vim_62.tardist
the last one of the first gimp generation based on motif. for historical reasons and for hamei :P
Unread postby josehill » Mon Dec 01, 2014 8:51 am
foetz wrote:the last one of the first gimp generation based on motif. for historical reasons and for hamei :P
You're a good man, foetz! :)
Unread postby vishnu » Mon Dec 01, 2014 9:04 am
foetz wrote:microline are the original netscape widgets...
Speaking of which, if anyone wants the full set of netscape's motif add-on widgets I've got them, and I've even semi-autoconfed the source tree, which is to say the I've gotten the library itself to compile with autoconf but not all the other subdirectories, which are tests and whatnot. If there's an interest I could possibly be moved to autoconf the whole thing... 8-)
gocram
Unread postby gocram » Mon Dec 01, 2014 9:06 am
Thank you very much for these packaged ports, I really appreciate that.
By the way, speaking of GIMP, has pressure-sensitive (e.g. Wacom) digitizer/tablet input ever been implemented for IRIX? I remember it didn't work for some(?) Nekoware releases.
LOOKING FOR:
ITEMS FOR SALE/TRADE
Unread postby foetz » Mon Dec 01, 2014 10:55 am
thaaaanks :D
me me me ... me :P
on a more serious note: me :D
and no worries about autoconf, i don't care. i.e. no need to spend more time on that at least as far as i'm concerned. would really appreciate the package :-)
gocram wrote:Thank you very much for these packaged ports, I really appreciate that.
i have no idea. never used that with a tablet.
Unread postby hamei » Mon Dec 01, 2014 8:20 pm
foetz wrote:gimp_0541.tar.bz2
Very cool, foetz ! Thank you !
I can't get it to import yet and
gimp warning: Cannot allocate colormap entry for "#acacac"
gimp warning: Cannot allocate colormap entry for "#ff0000"
gimp warning: No brushes available for use with this tool.
but that's just teething problems ... otherwise
this thing looks much nicer to me than the gtk versions :D
I wonder ......
