Sofimage|3d 4.0 on 1600sw
gighindro
Unread postby gighindro » Thu Jul 25, 2013 12:57 am
Greetings,
there's a way to change res in SI|3d 4.0 to 1600x1024?
thanks
Re: Sofimage|3d 4.0 on 1600sw
Unread postby vishnu » Mon Jul 29, 2013 5:36 pm
Couldn't you just use xsetmon to set the monitor resolution to that and then size the SI window to cover the entire screen?
Unread postby foetz » Sat Aug 03, 2013 1:17 pm
iirc the main softimage window is sort of custom. i've never been able to do anything else but either stowing or restoring it.
hermessgi
Unread postby hermessgi » Wed May 28, 2014 7:59 pm
Yes you can check the documentation. But I believe under display resolution it says "1024 × 768, 1280 × 1024, 1600 × 1024 (SGI Visual Workstation for Windows only), or 1600 × 1200 (Note: For 1600 × 1024, set the SI_SCREENRES environment variable to SI_1600X1024 for maximum horizontal display.)"
Looks like you can monkey with the environment script to make it work. I know I've set up a Dell 1920x1200 monitor and the SGI 1600x1024 monitor using the SI_SCREENRES environment variable.
Unread postby uunix » Sun Nov 09, 2014 1:45 pm
For anyone who wants more info on this. hermessgi is correct
edit the file /usr/Softimage/Soft3D_4.0/.softimage400 <I presume, the 4.0 and 400 are dependant on your version of softimage.
add the following line for 1600sw monitors.
setenv SI_SCREENRES SI_1600X1024
This works a treat on my o2 with 1600sw.
Return to “SGI: Video”
