O2 CD drive - where does the little white gear go?
icecubecheddarmilk
Unread postby icecubecheddarmilk » Thu Jun 20, 2013 11:59 pm
Howdy
I recently acquired an old R5k O2, and it suffers from the famous thrown gear problem in the CD drive unit. I've pulled apart the machine and I have the CD drive and the little white gear, but I can't figure out where it actually goes in the mechanism. I've searched the forums but the posts I came across didn't tell me where it should be. Can someone please help me? I'll take a couple of photos if that helps.
kjaer
Re: O2 CD drive - where does the little white gear go?
Unread postby kjaer » Fri Jun 21, 2013 1:44 am
icecubecheddarmilk wrote:Howdy
if it's the pinion I'm thinking of, it's press-fit over the tray motor spindle.
If it's come off because it's split, putting it back on is likely insufficient to restore the drive to operation.
PymbleSoftware
Unread postby PymbleSoftware » Fri Jun 21, 2013 1:48 am
Welcome.
Pictures would be good. Someone could add them to the wiki after we've solved your issue. Where the white cog goes is obvious when you see it but some people just replace the entire drive (with for example a yamaha SCSI CDRW).
R.
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
icecubecheddarmilk
Unread postby icecubecheddarmilk » Sat Jun 22, 2013 2:05 am
Ok I got it working again.
Here are some pictures for the wiki.
Where the gear goes
The gear
PymbleSoftware
Unread postby PymbleSoftware » Sat Jun 22, 2013 3:14 pm
icecubecheddarmilk wrote:Ok I got it working again.
Thanks, the O2 topic ( http://www.nekochan.net/wiki/SGI_O2#CD-ROM ) has been updated and this forum topic credited.
R.
死の神はりんごだけ食べる
smj
Unread postby smj » Mon Jun 24, 2013 1:07 am
Thanks Regan! And welcome/thank you icecubecheddarmilk!
Torque
Unread postby Torque » Wed Apr 09, 2014 9:46 am
Just found this thread. I'm having the exact same issue, a thrown COG (luckily it's still intact).
Does anyone know how to remove the off white CD tray from the black assembly piece? My tray is stuck about 1" open, and I can't for the life of me figure out how to remove it so that I can get to the COG motor shaft location.
Any help is appreciated! :D
kjaer
Unread postby kjaer » Wed Apr 09, 2014 3:27 pm
IIRC it should just pull straight out the front of the drive. If it's really "stuck", though, the gear train is probably bound, which can happen with split pinion as the teeth will no longer mesh near the split. The parts are resilient enough to withstand a reasonable amount of forcing.
Torque
Unread postby Torque » Sun Apr 13, 2014 10:52 am
Thanks for the help... unfortunately it's too locked up to come out easily.
Since I don't have time to fix, I'm happy to donate this unit with all parts to anyone here free, only ask for you to cover the cost of shipping. PM me if interested.
