Tape drives
Best tape archiver tool?
tar
9
56%
cpio
1
6%
xfsdump
6
38%
Total votes: 16
mia
Re: Tape drives
Unread postby mia » Wed Nov 21, 2012 9:27 pm
It is an impressive setup... how much disk space do you have, and how many spindles total?
:Onyx2:
hhoffman
Re: Tape drives
Unread postby hhoffman » Thu Nov 22, 2012 12:17 am
The array was actually sold this year.
mia
Re: Tape drives
Unread postby mia » Thu Nov 22, 2012 2:12 pm
That's really an impressive flame setup. Anyway, Hhoffman, your benchmarks have shown that I'm doing something wrong, and there's room for improvement, since we have a fairly comparable hardware, would you know why I'm not getting the same throughput as yours?
:Onyx2:
hhoffman
Re: Tape drives
Unread postby hhoffman » Fri Nov 23, 2012 12:39 am
maybe it depends on your configuration and setup. What irix version are you running?
mia
Re: Tape drives
Unread postby mia » Fri Nov 23, 2012 12:59 am
hhoffman wrote:maybe it depends on your configuration and setup. What irix version are you running?
6.5.30
:Onyx2:
hhoffman
Re: Tape drives
Unread postby hhoffman » Fri Nov 23, 2012 2:53 am
I'm using 6.5.28f. Maybe that is a reason ...?
Also I have upgraded to 8GB RAM a few months ago.
What is your setup?
Re: Tape drives
Unread postby recondas » Sun Mar 02, 2014 7:39 am
Another data point for mia's excellent compilation of tape drive performance, using a Quantum TC-L42AN LTO-4 SAS drive.
The test file used was located on a single spindle (an internal 15k 73G Seagate ST373454LC) connected to the IO9 SCSI controller in an 8P O350/V12 running 6.5.30:
diskperf -W -D -r 4k -m 4m testfile
# Disk Performance Test Results Generated By Diskperf V1.2
# Test name     : Unspecified
# Test date     : Sun Mar  2 09:31:16 2014
# Test machine  : IRIX64 electraglide 6.5 07202013 IP35
# Test type     : XFS data subvolume
# Test path     : testfile
# Request sizes : min=4096 max=4194304
# Parameters    : direct=1 time=10 scale=1.000 delay=0.000
# XFS file size : 4294967296 bytes
       4096    1.01   24.70    1.03    1.04    1.00    1.13
       8192    2.00   42.88    2.09    2.09    1.93    2.24
      16384    3.93   67.88    4.28    4.28    3.83    4.38
      32768    7.54   92.00    8.96    8.96    7.28    8.32
      65536   13.97   95.66   19.77   19.82   13.59   15.02
     131072   24.41   95.85   49.65   49.59   23.49   25.66
     262144   38.93   95.81   50.24   50.23   37.64   38.78
     524288   55.26   95.85   63.86   50.32   53.20   54.35
    1048576   70.12   95.78   81.12   62.31   67.31   62.83
    2097152   80.91   95.77   81.64   81.66   77.93   77.90
    4194304   87.72   95.76   85.29   81.63   84.07   82.97
The (external) tape drive was connected to an LSI SAS1068 controller:
Integral SCSI controller 3: Version SAS/SATA LS1068
  Tape drive: unit 4 on SCSI controller 3: Linear Tape-Open
# mt status
        Controller: SCSI
        Device: QUANTUM: ULTRIUM 4       21704506
        Status: 0x20242
        Drive type: Linear Tape-Open
        Media : READY, writable, at BOT
# mt blksize
 Recommended tape I/O size: 262144 bytes (512 512-byte blocks)
 Minimum block size: 1 byte(s)
 Maximum block size: 16777215 bytes
 Current block size: 4096 byte(s)
mkfile -nv 46936088000 testfile.deleteme
 timex tar cvKbf 4096 /dev/rmt/tps3d4 testfile.deleteme
Warning: Inclusion of file -> testfile.deleteme will create a non-portable archive
a testfile.deleteme 91672047 blocks
real    10:09.56
user        0.25
sys      4:15.50
Or roughly 73.37 MB/s (the test file was 46936088000 bytes/44761.7 megabytes, divided by 10m10s/610 seconds clock time). The test file was on a single U160 disk, so it might be possible to increase performance if the test file was read from an array of disks with higher throughput.
I used the same tape drive definition file in /master.d/scsi as hhoffman with the device info modified to match the Quantum drive used:
/* Quantum LTO-4 HH SAS */
{ TPLTO, TPLTO, 7, 9, "QUANTUM", "ULTRIUM 4", 0, 0, {0},
MTCAN_BSF|MTCAN_BSR|MTCAN_APPEND|MTCAN_SETMK|MTCAN_PART|MTCAN_PREV|
MTCAN_SYNC|MTCAN_SPEOD|MTCAN_CHKRDY|MTCAN_VAR|MTCAN_SETSZ|MTCANT_IMM|MTCAN_BUFFM|
MTCAN_SILI|MTCAN_AUDIO|MTCAN_SEEK|MTCAN_CHTYPEANY|MTCAN_COMPRESS,
40, 5*60, 20*60, 20*60, 3*3600, 4096, 512*512,
tpsc_default_dens_count, tpsc_default_hwg_dens_names,
tpsc_default_alias_dens_names,
  {0}, 0, 0, 0,
   0, (u_char *)0 },
Re: Tape drives
Unread postby recondas » Thu Mar 06, 2014 10:13 am
Another LTO-4 drive with an SAS interface, this time an IBM Half High LTO Gen 4 SAS Tape Drive (got lucky and got both of 'em in in the same 2U enclosure for a I-can't-believe-no-one-else-bid price).
Same test system and parameters as with the Quantum LTO-4 Half-height Model TC-L42AN SAS Tape Drive tested in the previous post.
# mt status
        Controller: SCSI
        Device: IBM: ULTRIUM-HH4     B6W1
        Status: 0x20242
# timex tar cvKbf 4096 /dev/rmt/tps3d4v testfile.deleteme
real     9:37.90
user        0.34
sys      4:07.86
Or approximately 78.80 MB/s (46936088000 bytes/44761.7 megabytes, divided by 9m38s/578 seconds clock time). Slightly higher than the Quantum SAS, though the limiting factor in either case is likely the throughput of single U160 hard drive. I have an external SATA hard drive enclosure that holds up to eight disks. Strictly consumer grade stuff when it comes to things like redundant data storage or even redundant power supplies, but it's desktop quiet (magnitudes quieter than the typical enterprise storage array) and relatively inexpensive to purchase / run. Did I mention it's *quiet* :D.
So I'd like to test the SAS tape drives against desktop SATA array, but first I'll have to resolve a few SAS controller issues.
The SAS controller I'm using is an LSI SAS3800X with two external SFF-8470 ports (the tape drives are both in a 2U rack enclosure, each drive has an external SFF-8088/miniSAS connection).
Initially had some issues with the SAS3800X until I isolated it as the only PCI device in the slave O350. If I connect to both ports on the SAS3800X it results in fatal PCI_Bridge errors. After doing some research I'm pretty sure I can resolve the won't pci-bus cohabitate / pci bridge errors by updating the firmware on the SAS3800X. Unfortunately I can't flash the board from IRIX. lsflash just hangs there without returning the prompt. For anyone else who might consider trying this, I'll mention I was running lsflash against firmware d/l'd from LSI - a process *not* recommended unless you're willing to accept the risk of bricking the controller. I chose to try it because while man lsflash does mention using lsflash with LSI's 1064/1068 controllers, SGI doesn't include 1064/1068 firmware (in /usr/firmware/ls).
So I'll have to temporarily put the project on standby until I get access to a PC with 3.3V PCI-X slots.
mia
Re: Tape drives
Unread postby mia » Thu Mar 06, 2014 10:42 am
That's some great work you did recondas.
:Onyx2:
Re: Tape drives
Unread postby foetz » Thu Mar 06, 2014 4:14 pm
the poll lacks bru :P
Re: Tape drives
Unread postby recondas » Thu Mar 06, 2014 4:29 pm
mia wrote:That's some great work you did recondas.
Thanks! I was hoping you'd drop by. I've run the tests several times, the results are pretty consistent.
foetz wrote:the poll lacks bru :P
Everything looks better after a couple of brus. :D
Re: Tape drives
Unread postby recondas » Fri Mar 07, 2014 6:56 pm
Got the firmware on the LSI controller reflashed. That seems to have resolved the issues with PCI_Bridge errors and conflicts with other PCI devices.
With the firmware issues resolved the LSI SAS controller was installed in a Tezro to see if the differences in PCI bus speed had an effect on performance (the PCI busses in an O350 limit PCI devices to a maximum of 100MHz, while the Tezro doesn't limit 133MHz PCI devices):
# l1cmd pci
Bus Slot Stat    Power Mode/Speed
  1    1 0x80 01   15W PCI   66MHz
  2    1 0x00 0f  none PCI   33MHz
  2    2 0x00 00  7.5W PCI   33MHz
  2    3 0x00 01   15W PCI   33MHz
  3    1 0x80 0f  none PCI   66MHz
  3    2 0x80 0f  none PCI   66MHz
  4    1 0x00 0c  7.5W PCIX 133MHz   <----- The LSI SAS3800X
  4    2 0x00 0f  none PCIX 133MHz
I used identical test parameters, the hard drive used this time was a 146 GB Maxtor Atlas 15K2 connected to the IO9 in a Tezro:
# mkfile 4g testfile
# diskperf -W -D -r 4k -m 4m testfile
# Test date     : Fri Mar  7 20:54:16 2014
# Test machine  : IRIX64 tezro 6.5 07202013 IP35
       4096    1.01   22.28    1.03   12.13    1.03    1.15
       8192    2.00   39.23    2.10   19.50    2.03    2.28
      16384    3.90   61.43    4.29   21.49    3.97    4.35
      32768    7.42   86.02    9.00   30.68    7.52    8.16
      65536   13.80   96.79   19.92   35.13   13.51   14.65
     131072   30.35   96.65   26.04   39.15   23.04   24.12
     262144   45.50   96.90   47.72   52.76   36.36   38.03
     524288   51.05   52.79   53.91   53.31   49.45   52.25
    1048576   64.09   66.89   65.82   68.96   61.73   64.94
    2097152   73.34   78.50   75.01   77.91   71.34   73.37
    4194304   80.39   85.54   80.85   85.48   78.35   84.25
The tape drive tested was the IBM Half High LTO Gen 4 SAS Tape Drive
# mt status
        Controller: SCSI
        Status: 0x20242
testfile.deleteme 46936088000 bytes
# timex tar cvKbf 4096 /dev/rmt/tps8d0v testfile.deleteme
real     8:06.70
user        0.28
sys      3:57.85
Not sure if the increase in performance is due to the firmware, the faster PCI bus, or a combination of both, but the difference was noticeable: 91.91 MB/s (46936088000 bytes/44761.7 megabytes, divided by 8m7s/487 seconds clock time).
Re: Tape drives
Unread postby hamei » Fri Mar 07, 2014 9:03 pm
recondas wrote:The tape drive tested was the IBM Half High LTO Gen 4 SAS Tape Drive
# mt status
        Controller: SCSI
        Status: 0x20242
/me slinks back into trailer under the bridge down by the river, giving 2mb/hr Sony SDT-9000 a little pat on the transport drive : "It's okay, little feller. He can't do audio !"
You could record the 1812 Overture in 13 seconds on that thing :( pah rah da ba da ba da rump da bum ...
Re: Tape drives
Unread postby recondas » Sat Mar 08, 2014 8:20 am
hamei wrote:"It's okay, little feller. He can't do audio !"
Haven't been masochistic enough to try it, but it is interesting to note that a couple of the LTO definition files include MTCAN_AUDIO.
(mtcan_audio? take a peek inside /usr/include/sys/mtio.h for the mt gospel according to irix).
Users browsing this forum: Bing [Bot], GRudolf94 and 1 guest
