getopt_long for IRIX
BSDero
Unread postby BSDero » Wed Jul 04, 2012 9:01 pm
Hi guys!!
I was playing with my SGI and needed an Irix implementation of getopt_long(), so I got source code from NetBSD and OpenBSD and created a SGI version of it.
I tested an example program of getopt_long() I found in google and all seems works flawlessly :), except by a one line change. However the behavior is same than gnu's getopt_long().
I got a tar with sources, header, Makefile and test program, it builds with MipsPro in Irix 6.5. If anybody interested, I would like to share this.
__Zacatito__Image 600 MHZ R14000; 17GBytes HD
__Nopalito__Image 200 MHZ R5000; 9GBytes HD
Guadalajara, Jal and Aguascalientes, Ags
Mexico
PymbleSoftware
Re: getopt_long for IRIX
Unread postby PymbleSoftware » Wed Jul 04, 2012 10:17 pm
BSDero wrote:Hi guys!!
From memory there is/was something about this on the MIPS Pro nekochan wiki page.. if not I intended to put something on there at the same time I wrote the section on work arounds or porting or something like that..
EDIT
oh, wait nup.. that was the senenv/putenv thing .. I did have a solution for getopt_long() which I intended to put in a section after ..
http://www.nekochan.net/wiki/MIPS_Pro#s ... ng_in_IRIX
I think I did this when porting hercules IBM mainframe emulator to IRIX.. years ago..
R.
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
canavan
Unread postby canavan » Thu Jul 05, 2012 11:49 am
An Implementation of getopt_long is part of gnulib http://www.gnu.org/software/gnulib/MODULES.html#module=getopt-posix. I usually just copy the source files into a suitable directory and add them to the list of .c-Files in the Makefile.
PymbleSoftware
Unread postby PymbleSoftware » Thu Jul 05, 2012 1:44 pm
Updated to the wiki to point back here.... http://www.nekochan.net/wiki/MIPSpro#ge ... ng_in_IRIX
R.
死の神はりんごだけ食べる
BSDero
Unread postby BSDero » Wed Jul 11, 2012 8:08 am
In those GCC-isms related issues I've found *bsd source code easier to port and maintain witrhout all that flags and thinks like that. Source code is way easier to port, clear and maintain.
Mexico
necron2600
Unread postby necron2600 » Tue Sep 12, 2017 12:17 pm
For anyone who has trouble with getopt_long and IRIX..
I know we have a Wiki on this that says "google around for the example code to implement this" .. which was not very helpful for me.
Granted, once I figured it out, it now seems easy but it took some time for me to get to that point. I want this thread to help anyone else with this problem.
Attached is a tarball with ya_getopt .. Yet-Another getopt implementation.. compiles on IRIX and I tested it already (however not very extensively! so hopefully nothing breaks from this).
Tarball contains:
tar tpf ../getopt_long-in-irix.tar
getopt_long-in-irix/ya_getopt.c
getopt_long-in-irix/ya_getopt.h
getopt_long-in-irix/libya_getopt.so
getopt_long-in-irix/README
the .c and .h are from ya_getopt. libya_getopt.so is a compiled shared library on IRIX 6.5/mips4 with GCC (we all love GCC right? ;)
The README has some rough notes for anyone who may find themselves in a getopt_long() missing situation and may be clueless as to what to do:
Here is the README (its rough notes.. )
# These are notes for getopt_lang() in IRIX (GCC)
# Yet Another GetOpt implementation (drop-in)
https://github.com/kubo/ya_getopt
# COMPILE shared library (GCC)
# http://www.cprogramming.com/tutorial/shared-libraries-linux-gcc.html
gcc -c -Wall -Werror -fpic ya_getopt.c
gcc -shared -o libya_getopt.so ya_getopt.o
# LINK with your code (examples)
gcc -Wall -o test main.c -lya_getopt
# LINK with your code specifying .so library directory location
gcc -L/whereis/ya_getopt/ -Wall -o test main.c -lya_getopt
# Copy ya_getopt.h to your source and edit relevant files:
#include "ya_getopt.h"
# Replace getopt_long() calls in your code to ya_getopt_long()
# Example Makefile changes (and/or Environment variable adjustments)
LDFLAGS = -L/usr/nekoware/lib -L/usr/lib32 -L/whereis/ya_getopt/
LIBS = -lya_getopt
# Note:
Ensure libya_getopt.so is stored somewhere where the binary can access
Such as /usr/local/lib/
It does compile with MIPSpro as well:
cc -c ya_getopt.c
Thanks again to Kubo @ https://github.com/kubo/ya_getopt for his ya_getopt code.
(90 KiB) Downloaded 5 times
Reason: merged
duck
Unread postby duck » Fri Sep 15, 2017 11:57 pm
NetBSD's pkgsrc has a package with netbsd-compatibility functions that include getopt_long. It's called libnbcompat. This works on IRIX, and might provide other useful things if you are feeling porty.
http://pkgsrc.se/pkgtools/libnbcompat
http://cdn.netbsd.org/pub/pkgsrc/curren ... pat/files/
The files in files/ should be enough to compile and you won't need the pkgsrc tree.
Edit: added URL to the files
___(o)=
\____)
