Origin 300, 2x500MHz R14K, 1GB, 1x73GB + 1x300GB
jpstewart
Unread postby jpstewart » Mon May 21, 2012 3:55 pm
I recently took a chance on an "As-Is" Origin 300 from eBay. I won the auction for just $36, and the shipping was a lot less than what I've seen from other sellers. (It was halfway across Canada but still north of the border, so no customs hassles...which might explain why shipping was less than half the cost of other Origins I've looked at from US sellers.)
Turns out that in this case "As-Is" meant fully functional! :D I was a little disappointed that it was only 2 CPUs and only 1GB RAM. I had been hoping it would have disk sleds in it, and so I was very pleasantly surprised to find that it had a 73GB system disk (with no root password on what appears to be a fresh install of 6.5.29) and a 300GB Seagate disk in the second slot, along with a QL12160 SCSI card in one of the PCI slots. That made up for having only 2 CPUs. So all in all, it was better than expected! :!: Even more so considering it was still well under $100 even after adding shipping and taxes.
hinv -vm:
       IP45_2CPU Board: barcode MJH014     part 030-1780-001 rev -C
       IO8 Board: barcode MJL112     part 030-1673-003 rev -F
2 500 MHZ IP35 Processors
CPU 0 at Module 001c24/Slot 0/Slice A: 500 Mhz MIPS R14000 Processor Chip (enab
  Processor revision: 2.4. Scache: Size 2 MB Speed 250 Mhz  Tap 0xa
CPU 1 at Module 001c24/Slot 0/Slice C: 500 Mhz MIPS R14000 Processor Chip (enab
Main memory size: 1024 Mbytes
Memory at Module 001c24/Slot 0: 1024 MB (enabled)
  Bank 0 contains 512 MB (Premium) DIMMS (enabled)
  Bank 1 contains 512 MB (Premium) DIMMS (enabled)
Integral SCSI controller 3: Version QL12160, low voltage differential
Integral SCSI controller 6: Version QL12160, low voltage differential
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Integral Fast Ethernet: ef0, version 1, module 001c24, pci 4
HUB in Module 001c24/Slot 0: Revision 2 Speed 200.00 Mhz (enabled)
IP35prom in Module 001c24/Slot n0: Revision 6.210
USB controller: type OHCI
uname -aR:
IRIX64 orion 6.5 6.5.29m 01090133 IP35
scsicontrol -i /dev/scsi/*:
/dev/scsi/sc0d1l0:  Disk          SGI     ST373307LC      2741
ANSI vers 3, ISO ver: 0, ECMA ver: 0; supports:  16bit synch linkedcmds cmdqueig
Device is  ready
/dev/scsi/sc0d2l0:  Disk          SEAGATE ST3300007LC     0002
Device is  ready
diskpatch -v:
sc0d1l0:  Disk         SGI     ST373307LC      2741  Serial: 3HZ0MW7R
sc0d2l0:  Disk         SEAGATE ST3300007LC     0002  Serial: 3KR0E5B7
l1cmd serial all:
Local System Serial Number      NVRAM         M2001347
Reference System Serial Number  NVRAM         M2001347
Local Brick Serial Number       EEPROM        MJH014
Reference Brick Serial Number   NVRAM         MJH014
EEPROM      Product Name    Serial      Part Number           Rev  T/W
NODE        IP45_2CPU       MJH014      030_1780_001          C    00
IO8         IO8             MJL112      030_1673_003          F    00
EEPROM      JEDEC Info                Part Number         Rev
DIMM 0      CE0000000000000027F43B00  M3 46L6510BT1-CA0   0B
DIMM 2      no hardware detected
DIMM 1      CE00000000000000279F3B00  M3 46L6510BT1-CA0   0B
DIMM 3      no hardware detected
l1cmd flash status:
Flash image B currently booted
Image      Status        Revision    Built
  A     valid           1.10.12      02/01/2002 14:40:22
  B     default         1.10.12      02/01/2002 14:40:22
l1cmd env:
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.12
       12V DIG    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.25
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.97
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.34
        5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.99
      3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.42
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.50
   Speedo2 CPU    Enabled  10%   1.44/  1.76  20%   1.28/  1.92    1.59
          1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.48
FAN 0     LEFT    Enabled         2160         3960
FAN 1   CENTER    Enabled         2160         4007
FAN 2    RIGHT    Enabled         2160         4105
FAN 3       PS    Enabled         2160         3175
FAN 4      PS'    Enabled         2160         4371
                           Advisory  Critical  Fault     Current
Description    State       Temp      Temp      Temp      Temp
NODE 0            Enabled  30C/ 86F  35C/ 95F  40C/104F  19c/ 66F
NODE 1            Enabled  30C/ 86F  35C/ 95F  40C/104F  19c/ 66F
l1cmd pci:
Slot    Power
Slot 1  15.0
Slot 2  0.0
I won't bother with pictures. It's nothing special visually. But I'm still very excited. I'll probably spend next weekend putting it through it's paces to compare it to my 2x250MHz Octane.
And I just love the L1 functionality. I wish all systems had that! I do notice that it's quite an old L1 firmware version and that will have to be updated. (In fact, something in the boot process is complaining about the firmware being too old to support some feature.) I've read up on that in the wiki and the cautionary tales in the forum about trying to jump too many versions at a time. I think I've got a bit more reading to do before I actually understand it well enough to attempt the multi-stage incremental updates to the firmware and the flash utility. But you guys have done the hard parts: figuring out the process and documenting it. Thanks for that! Otherwise I'd be in big trouble. :lol:
HP C8000
Digital DECstation 5000/125
Adrenaline
Re: Origin 300, 2x500MHz R14K, 1GB, 1x73GB + 1x300GB
Unread postby Adrenaline » Mon May 21, 2012 4:23 pm
wow what a killer deal you got, congrats!
:Indigo: 33mhz R3k/48mb/XS24 :Indy: 150mhz R4400/256mb/XL24 :Fuel: 600mhz R14kA/2gb/V10 Image 8x1.4ghz Itanium 2/8GB :O3x08R: 32x600mhz R14kA/24GB :Tezro: 4x700mhz R16k/8GB/V12/DCD/SAS/FC/DM5 (2x) :O3x0: 4x700mhz R16k/4GB :PrismDT: 2x1.6ghz 8mb/12gb/SAS/2xFGL
tux
Unread postby tux » Mon May 21, 2012 5:00 pm
Adrenaline wrote:wow what a killer deal you got, congrats!
No kidding - that was a honey of a deal! Good on you, man.
:Fuel: asterix - R16K 700 MHz, V10, 2 GByte ram
:Octane2: speedracer - Dual R14k 600 MHz, V12, 2 GByte ram
:O2: moosehead - R12k 400 MHz, 768 MByte ram
:O2: Ox - R5k 300 MHz, 224 MByte ram
:Indy: ryoko - R5k 180 MHz, 128 MByte ram
:Indigo2IMP: Iris - R10k 195 MHz, Max Impact, 512 MByte ram
[ -] stingray - Macintosh IIci
smj
Unread postby smj » Tue May 22, 2012 3:57 am
Congratulations! Sounds like it was a good addition for you even without the extra CPUs.
I've got a box of quieter fans to try and swap into my O300s (Adrenaline's Cooler Master units). You might want to check the threads referenced from a recently-added section of the O300 nekowiki page. But with the Octane you're all set for remote access, so you could just put it out in the garage or down in the basement.
