Octane 2x250MHz, 768MB, 36GB, 2xSE, PVO
jpstewart
Unread postby jpstewart » Mon May 21, 2012 3:49 pm
Apparently I never posted a hinv of my Octane (which I've had for over a year), so here it goes:
hinv -vm:
      PM20250MHZ Board: barcode GLZ858     part 030-1427-001 rev  A
            IP30 Board: barcode LKD648     part 030-1467-001 rev  D
    PWR.SPPLY.ER Board: barcode AAE0170215 part 060-0035-002 rev  A
             FP1 Board: barcode KSN507     part 030-0891-003 rev  G
        XTALKPCI Board: barcode JKG045     part 030-0952-005 rev  E
           MOT10 Board: barcode KXG042     part 030-1241-002 rev  K
             EVO Board: barcode KWY124     part 030-1156-003 rev  B
           MOT10 Board: barcode KCJ752     part 030-1241-002 rev  J
2 250 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 768 Mbytes
Xbow ASIC: Revision 1.4
  Tape drive: unit 2 on SCSI controller 0: DAT
  CDROM: unit 1 on SCSI controller 1
Graphics board: ESI
Graphics board: ESI
Gigabit Ethernet: tg1, PCI slot 3
  PCI Adapter ID (vendor 0x14e4, device 0x1645) PCI slot 3
Personal Video: unit 1, revision 2.0, DigCam version 1.2 connected
gfxinfo -vv:
   HQ rev B, GE12 rev A, RE4 rev C, PP1 rev G,
   VC3 rev A, CMAP rev F, Heart rev F
   Video board present
    Video Format Flags:  (none)
    Sync Disabled
    Using Gamma Map 0
    Monitor Type:  unknown
    Gain (all color components) - 1.000000 (nominal)
   Managed (":0.1") 1280x1024
    Sync Disabled
    Using Gamma Map 0
uname -aR:
IRIX64 gumby 6.5 6.5.22m 10070055 IP30
scsicontrol -i:
/dev/scsi/sc0d1l0:  Disk          COMPAQ  BD03664553      3B05
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  16bit synch linkedcmds cmdqueing
Device is  ready
/dev/scsi/sc0d2l0:  Tape          ARCHIVE Python 01931-XXX5.63
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds
Device is  not ready
/dev/scsi/sc1d1l0:  CD-ROM        HP      DVD-ROM 305     1.01
Device is  not ready
diskpatch -v:
sc0d1l0:  Disk         COMPAQ  BD03664553      3B05  Serial: 3FD0B627
The Archive tape drive is an SGI original DDS-2 drive I stumbled upon on eBay which seems to have the audio-over-SCSI firmware. The drive works flawlessly, too. I've used it for a full backup (and restore!) successfully.
I bought that HP DVD-ROM based on the suggestion in another forum thread and stuck it in a Sun 611 case. Works great, too. Thanks to whoever suggested those HP DVD readers!
The machine also has an IBM-branded Spaceball input device hanging off a serial port but that doesn't show up in the hinv. (Between that and the aforementioned HP drive in a Sun case all running off of an SGI computer I sure do seem to be mixing and matching my Unix vendors!)
Alas, all is not well with the machine. Around the time I got the machine, I posted in another thread about some networking problems. I've since added a PCI cage and Gigabit NIC so it's at least on the network now. But it still has some serious gremlins. I think SAQ hit the nail on the head in that other thread when he suggested looking at the frontplane. In addition to no on-board network connectivity, I get XIO errors whenever I run the system fully configured with both SE cards and the PVO installed. Either SE card alone is rock solid stable. Both SEs together, or any one SE + the PVO, or both SEs + PVO are all unstable configurations. Sometimes the screen will just go black. If the screen stays functional I get messages about "Heart: DMA Memory Address Error" to go with my lock-up.
So for the most part, I run it headless and connect via SSH. Which is a shame considering the Octanes were built for graphics. Someday I'll replace the frontplane. But I keep spending my computer budget on other toys instead....
HP C8000
Digital DECstation 5000/125
Re: Octane 2x250MHz, 768MB, 36GB, 2xSE, PVO
Unread postby hamei » Tue May 22, 2012 7:06 am
jpstewart wrote:The machine also has an IBM-branded Spaceball input device hanging off a serial port but that doesn't show up in the hinv. .
About the Spaceball, mine doesn't show up in hinv either. There must be a generic driver for it because I see it listed in the confidence tests but I use the 3DConnexion driver version 4.64 That may be here on nekochan's ftp. If not, it's not hard to find.
The spaceball works great in the applications I have that use it. For general use it does nothing. The application has to be written to accept Spacey input.
