Hi,
I have a deskside Onyx2 with dual RM10-256 boards and GM16-4.
I want to install a DG5-8.
Does anyone have the screen resolution options with this configuration?
Or even a link to a document that details this config.
Cheers
InfiniteReality3 video resolutions
- jan-jaap
- Donor
- Contact:
Re: InfiniteReality3 video resolutions
You can program any combination of resolutions, pixel formats (depth) etc. The bottleneck is bandwidth between the RMs and the DG.
The IR Video Format Combiner (ircombine) has a scale showing the bandwidth used.
The bandwidth is *just* not enough for two 1920x1200_60 screens, but it will do twice 1920x1080_60
Additionally, the 6 extra ports on a DG5-8 don't support resolutions as high as the first 2.
For details, refer to the InfiniteReality Video Format Combiner User's Guide.
jan-jaap wrote:The bandwidth is *just* not enough for two 1920x1200_60 screens, but it will do twice 1920x1080_60
Can you do 2 @ 1920 x 1200 @ 50 hz, j-j ? With an lcd, the 60 hz refresh isn't such a big thing ...
1920*1200*60 = 138240000
1920*1080*60 = 124416000
1920*1200*50 = 115200000
- jan-jaap
- Donor
- Contact:
I think when I tried (2 years ago?) the screen wouldn't sync below 57 or 58Hz.
There are a number of predefined combination files included with a reasonably complete IRIX/IR installation - take a look in /usr/gfx/ucode/KONA/dg4/cmb. The predefined combinations can give you a rough idea of what might be possible. Those will only touch on the possibilities, IR graphics are very customizable, so SGI probably anticipated most customers would create their own display formats. To get a better idea open a few of the supplied combination files with ircombine and try tweaking them to see if you can find a combination that suits your needs. Once you understand how it works, the ircombine gui will indicate if you've exceeded the capabilities of your IR graphics set.competentcompton wrote:I want to install a DG5-8. Does anyone have the screen resolution options with this configuration?
I suspect it's not exactly what you had in mind, but the InfiniteReality Video Format Combiner User's Guide should provide enough background on the basics of IR display capabilities to get you started: http://techpubs.sgi.com/library/tpl/cgi ... /ch01.htmlcompetentcompton wrote:Or even a link to a document that details this config.
jan-jaap wrote:I think when I tried (2 years ago?) the screen wouldn't sync below 57 or 58Hz.
Here's a nickel, kid. Go buy yourself a better monitor
- jan-jaap
- Donor
- Contact:
13Hz? I've seen slide shows faster than that
jan-jaap wrote:13Hz? I've seen slide shows faster than that
PowerPoint ! Set it on auto at 13 hz. Is it time to wake up already ? Yay !
