Dell UltraSharp 2410 / fuel V12 problem
BetXen
Unread postby BetXen » Thu Jan 12, 2012 10:52 am
Hi
I've got a problem displaying any of the 1920x1200 resolutions ("60" and "60p") on my brand new Dell U2410 monitor. The monitor goes in economy mode and tells me no signal is present. Thing is that 1920x1200 works just fine with my PC (at 60Hz too).
If that can help: http://support.dell.com/support/edocs/MONITORS/U2410/en/ug/about.htm#Specifications
BetXen
Re: Dell UltraSharp 2410 / fuel V12 problem
Unread postby BetXen » Thu Jan 12, 2012 11:46 am
No more problems....!
I've finally tried the DVI cable that connected my PC to the U2410 and it works fine at 1920x1200_60p. The other cable also works fine when connected to my PC.
The first one was a DVI-D Dual Link cable (three rows of eight pins and a solitary flat blade) and seems not to be compatible with V12. DVI-D Single Link cable (two sets of nine pins, and a solitary flat blade) poses no problem at all. Both of them are "digital only", as opposite to DVI-A (analog) or DVI-I (digital & analog).
mapesdhs
Unread postby mapesdhs » Thu Jan 12, 2012 12:03 pm
Excellent! Now you mentioned it, I do remember something about sorting out cables when I first set up my HP.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
BetXen
Unread postby BetXen » Thu Jan 12, 2012 12:17 pm
I hope that having written it down here will help someone in the future :D
Users browsing this forum: vishnu and 1 guest
