Out Of Box Experience with AIX
ritchan
Unread postby ritchan » Thu Dec 08, 2011 1:36 pm
Most of these are probably due to sheer ignorance, but I still hate AIX's out of box experience. RIght off the bat, there is no SSH included, and you need to get the AIX Linux Toolbox for that (which is a whole new exercise in itself). They include every shell out there except bash and the default shell is ksh. According to online documentation on ksh, ksh supports completion via ESC-ESC. Tried that, didn't work. Doesn't even have a command history, and the command prompt is just a single $ or #, which is incredibly helpful.
I can't shift-tab upwards to check output. There is no less, only more which sucks more. Network connectivity is limited to plain old ftp, which AFAIK does not support auto file transfer type. Since there's no working web browser, if you want to download updates for AIX, you have to use a different computer to get to IBM's website, and then type in all the ftp commands on the AIX box. smitty is not smart enough to phone home for updates. The default partition/filesystem sizes are tiny and ridiculous, with no option to change this in the installer, and each upgrade necessitates at least several partition resizes, which at least AIX handles nicely since partitions don't have to be contiguous. But isn't that in itself inefficient? I found myself intentionally wasting some free space on the drive just so one of the many filesystems would still have space to expand into in the future. Hell if I know which.
dtsession panics and refuses to start the fugly window manager when you so much as change your hostname. The graphical AIX introductory assistant asks you to insert the disc and press Enter to continue, but fails to register the ENTER keypress when you finally hit it, because it's just a graphical shell around something that's better handled by smitty anyway. You need to install the AIX Linux Toolbox to get any modicum of general functionality, and there is of course NO dependency resolution.
Last but not least, the OS takes ages to boot. The only saving grace this OS has is that df has a -m and -g option, which lets you specify exactly whether you want volume sizes to be listed in megabytes or gigabytes, instead of the -h option on Linux which does a great enough job that I don't really care anyway.
If there's something I listed here that's annoying simply because I don't know how it works in AIX, please tell me. I certainly had a lot of patience the last time I got this working. I must've forgotten all the hard work to get all my favourite things up and running like the AIX Linux Toolbox, and eventually KDE3.
Originally Posted by Tommie
Please delete your post. It is an insult to all the hard work society has put into making you an intelligent being.
Like somebody at AMD said about a decade ago: Benchmarking is like sex. Everybody brags about it, everybody loves doing it and nobody can agree on performance.
zmttoxics
Re: Out Of Box Experience with AIX
Unread postby zmttoxics » Thu Dec 08, 2011 2:59 pm
Is that ugly desktop CDE? I actually like CDE.... :P
Anyways, the hostname problem is typical for unix. That generally means you didn't change it in all of the places, or didn't specify an fqdn when you should have, or dns is returning something else (this is rare, but rhel6 and solaris 11 are fairly dependent on external dns to be correct), etc... I would re-read the docs on it for your version of AIX and make sure you hit all of the right spots.
If you didn't set an fqdn because you don't think you have one, just use example.com.
Stuff.
yetanother**ixuser
Unread postby yetanother**ixuser » Fri Dec 09, 2011 4:57 am
concerning shell laziness...my .env file *gg*
me@somemachine:/home/me> cat .env
export UNAME=somemachine
export  myid=`id | sed -n -e 's/).*$//' -e 's/^.*(//p'`
export  bold=`tput smso`
export  norm=`tput rmso`
#set prompt: login & system name (reverse video) & path (normal)
if [ $myid = root ]
        then    typeset -x PSCH='${bold}#:${norm}\${PWD}> '
                PS1="${bold}#:${norm}\${PWD}> "
        else    typeset -x PSCH='>'
                PS1="${bold}$LOGNAME@$UNAME:${norm}\${PWD}> "
                PS2=">"
                PS3="#?"
fi
export PS1 PS2 PS3
set -o vi
bash
and guess what...openssh is available :lol: a real smart admin here
me@somemachine:/home/me> ssh -v
OpenSSH_3.8.1p1, OpenSSL 0.9.6m 17 Mar 2004
no plan
kev009
Unread postby kev009 » Fri Dec 09, 2011 5:05 am
What's funny is that a couple of interns could easily whip the UX into shape and bundle some more modern BSD stuff and provide a decent shell experience.
I remember seeing a while back IBM had some kind of Eclipse(rational) connector where you'd develop on Windows and it would save/build/run on the POWER box. I guess that's their solution.. use Windows as a head end :roll:
Solaris 10 and 11 are the only commercial *NIX that don't feel arcane to me without a custom env.
SGI Fuel, Indy R5k
HP c8000
http://www.kev009.com/ - Blog
porter
Unread postby porter » Fri Dec 09, 2011 11:09 am
kev009 wrote:What's funny is that a couple of interns could easily whip the UX into shape and bundle some more modern BSD stuff and provide a decent shell experience.
Those same interns would also attempt to improve "loadsa stuff" and in term break many mission critical applications that have been running for the last 20 years.
Yup, I reckon those interns could leave their mark.
For every spotty intern who moans about not using zsh or git I'll point to ten people getting real work done.
kev009
Unread postby kev009 » Fri Dec 09, 2011 3:10 pm
Things apparently break anyway without improving the UX (AIX 5.2 WPARs as a "feature"...)
I hardly see how a decent shell profile and some commands will cause full system meltdown. Throw any conflicts into /usr/bsd/ or /usr/gnu and let the user choose if they need something weird for software that went beyond standards in the first place. My AIX machines are all outfitted nicely and it doesn't hamper the base system.
And yeah, nobody does real work with BSD and it always breaks. zsh and git will hose your system if installed and have no productivity merits :roll:
SGI Fuel, Indy R5k
HP c8000
porter
Unread postby porter » Sat Dec 10, 2011 10:29 am
kev009 wrote:zsh and git will hose your system if installed and have no productivity merits :roll:
What pisses me off is kids who write shell scripts and add "#!/bin/zsh" at the top and claim they are being hyperproductive because of it, and instead have made a script that then won't work on the target systems because, funnily enough they didn't have and previously didn't need zsh until the spotty erk decided that they could override the change control of an organisation.
Similar with GIT, just because you use GIT on your favourite FOSS project does not mean you have to force it onto every server you see, having a distributed system that works well using SVN is not magically improved by breaking everything to satisfy your GIT evangelism.
kev009
Unread postby kev009 » Sun Dec 11, 2011 1:28 am
That's a symptom of other failures. Being shiny new feature guy isn't any better than being stuck in the past. Shell scripts should try damn hard to stick to POSIX for obvious reasons, but zsh is fine as an interactive shell. Standards rule for the backend, but frontends can have some sugar.
While I use git on my own projects, SVN maps better to the 40-hour-week-programmer and especially managers. That said, I have yet to see a large project where git bisect wouldn't have been useful at some point. The mature programmer will note things like this when doing tool selection. For example, if I am enthusiastic about git, I can use it with an SVN repo without affecting the organization. If I identify a large inefficiency where git may solve problems (i.e. lots of remote employees), only then is it worth presenting for a a tough migration.
But we're getting a bit off thread topic.. the stuff I'm calling for is mundane. Decent TTY/termcap handling, bump to nvi or include vim in addition to the SysV vi, tab completion by default, shell history, add a useful prompt, etc. If these changes break things, the department (IBM or ISV, wherever the breakage is) need to reevaluate themselves for competence.
SGI Fuel, Indy R5k
HP c8000
stek1961
Unread postby stek1961 » Thu Jan 19, 2012 8:31 am
1. ssh is on the second DVD (I think) Pretty sure bash is on there too.
2. ksh is ace! You need to set your editor to vi and all your vi commands work...
set -o vi
Command history is esc-k, command completion is esc-\, esc-x to delete a character etc.......
3. ssh above includes ssh
4. Aside the fact that smitty is for girls, you can download (for now) updates via 'smitty suma', if a girl, or just 'suma' if a real man.
5. The LVM and BOS are the main things I love about AIX, LV's are deliberately kept small to enable reasonably sized mksysb's - application data should be kept in separate VG's This results in a box that can recovered in 15 mins from DVD, tape or NIM.
Return to “IBM”
