Basilisk and Irix
sbarton
Basilisk and Irix
Unread postby sbarton » Mon Oct 03, 2011 10:54 am
Would like some feedback from anyone who has used Basilisk on IRIX in the past.
I've tried a pkg I found here on Nekochan as well from the SGI Freeware archive on my 6.5.30 octane and O2. The SGI version seems to run a bit better than the neko package, but I can't seem to get it to show 8-bit color. Lots of apps need 256 colors vs truecolor on classic MacOS and the video color depth should be changeable on the fly, but the monitors control panel only shows "millions" of colors as an option.
On my solaris system using the same HD image (MacOS 7.5.5) and same ROM, the OS can dynamically change color depth between 8/16/24 bit color.
Other than this issue, which affects alot of programs I want to run, the system runs brilliantly on an Octane. I'm suprised more people havent' played around with it on IRIX.
Thx
Hakimoto
Re: Basilisk and Irix
Unread postby Hakimoto » Mon Oct 03, 2011 10:16 pm
Basilisk is a beautiful piece of software. I never had much in the way of real classic Mac hardware (except a SE/30 which actually came with A/UX) but I LOVED the emulators. ;-)
grace, elegance and style.
necron2600
Unread postby necron2600 » Tue Sep 08, 2015 3:20 pm
Nothing dynamic... but you can do it statically:
Basilisk will use your X11's color bit settings.
To set it to 8bit, so Basilisk can run at 256 colors:
/usr/lib/X11/xdm/Xservers
:0 secure /usr/bin/X11/X -bs -nobitscale -c -solidroot sgilightblue -cursorFG red -cursorBG white -pseudomap 4sight
To restore to 24bit (assuming you had 24bit to begin with):
restore your orig Xservers file.. or copy the following:
:0 secure /usr/bin/X11/X -bs -nobitscale -c -solidroot sgilightblue -cursorFG red -cursorBG white -depth 24 -class TrueColor
Then restart X11. You can reboot, or do the following (much quicker than rebooting):
/usr/gfx/gfxstop.sh
/usr/gfx/gfxstart.sh
Note, once you gfxstop.sh, you are then dropped to the text based console. Login as root and run gfxstart.sh to start X11 back up.
-Kevin
Unread postby hamei » Tue Sep 08, 2015 6:26 pm
necron2600 wrote:Nothing dynamic... but you can do it statically:
This should work (I don't have basilisk to test )
~/.Xdefaults:
basilisk*applicationDepth: 8
The 4Dwm desktop visual doesn't limit every window to the same color depth.
Unread postby foetz » Tue Sep 08, 2015 7:23 pm
necron2600 wrote:/usr/gfx/gfxstop.sh
these are wrong. it is startgfx and stopgfx. also without ".sh". you can also use a one-liner:
(/usr/gfx/stopgfx ; /usr/gfx/startgfx) &
necron2600
Unread postby necron2600 » Sat Sep 19, 2015 8:56 pm
Regarding .Xdefaults and applicationDepth settings..
My attempts to see an 8bit window on a 24bit X session failed.
I tested with 'winterm' and 'xeyes', as well as BasiliskII.
I ensured my .Xdefaults file actually worked with something... even setting every application:
*geometry: +0+910
or a specific application like xosview:
xosview*background: 000000
After running: xrdb ~/.Xdefaults I am able to launch various apps and know the above settings work.
However, setting the *applicationDepth: 8 does not have any affect (at least on my setup..)
I can verify the color depth using 'xwininfo' command. The Depth is always showing as 24.
Any ideas as to what is going on with Xdefaults and *applicationDepth? There seems to be very little search hits on google for Xdefaults including applicationDepth. Maybe only specific apps support this?
Thanks again!
-Kevin
Unread postby hamei » Sun Sep 20, 2015 2:14 am
necron2600 wrote:However, setting the *applicationDepth: 8 does not have any affect (at least on my setup..)
I just tried this, same here.
But techpubs graphics faqs clearly states :
sgi wrote: By default, the SGI X Server is configured to use an 8-bit
PseudoColor visual. X-based applications can request other visuals
directly if they are available.
All you have to do is figure out how to make the application request 8-bit color directly :D
Luckily, the source for Basilisk is right there for us members of the public to hack on if necessary. Sounds like a nice improvement, actually.
Oh wait. The secret search word is "colormap". Anything else will get you 4,000 helpful paragraphs about how to change the display settings of your Windows monitor. Don't ask how I found out :P
Try some of these :
http://hea-www.harvard.edu/~fine/Tech/X11visuals.html
necron2600
Unread postby necron2600 » Sat Dec 10, 2016 10:14 pm
The day has come! Basilisk on IRIX with 8bit color depth!
Thanks to rickyzhang (on emaculation.com) who modded the SDL bits to work with setting any color depth a bit over 3 months ago.
http://www.emaculation.com/forum/viewto ... f=6&t=9021
I grabbed the latest/main from GIT.. compiled. and got wonderful 256 colors on an Octane2 with no fiddling of the X server.
Add in displaycolordepth 8 to your basilisk prefs file, or launch BasiliskII --displaycolordepth 8 at the command line.
My testing had Prince of Persia working. It worked, slightly slow.. eventually Basilisk core dumped though.. so use with caution.
Attached is a compiled binary in a tarball.
BasiliskII-with-colordepth.tar.gz
GCC Compiled basiliskII from latest git checkout
(538.93 KiB) Downloaded 17 times
