Tezro, 4*1GHz, 8GB, V12 + DCD, DM3, DM5, RAD, ...
Unread postby jan-jaap » Tue Sep 20, 2011 2:28 pm
Looks like I never introduced this one :)
This is a former Discreet Flame station.
It's got a RAD audio board, a PCI card with two extra serial ports, a dual GBit network adapter, two dual 2GBit QL2342 Fibre Channel boards, and of course the DM3. It also came with a DMediaPro breakout box with DM5 installed. The FC disk box with Discreet 'STON+WIR' disks was apparently used with it.
hinv -mv
       IP59_4CPU Board: barcode NRM277     part 030-1989-003 rev -B
       WS_INT_53 Board: barcode NNY825     part 030-1881-007 rev -A
      ODY128B1_2 Board: barcode NPL883     part 030-1884-005 rev -B
             IO9 Board: barcode NRW778     part 030-1771-005 rev -B
     PCI_SIO_UFC Board: barcode NSX945     part 030-1657-003 rev  A
4 1.0 GHZ IP35 Processors
CPU 0 at Module 001c01/Slot 0/Slice A: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
  Processor revision: 3.0. Scache: Size 16 MB Speed 333 Mhz  Tap 0x15
CPU 1 at Module 001c01/Slot 0/Slice B: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 1.0 Ghz MIPS R16000 Processor Chip (enabled)
Main memory size: 8192 Mbytes
Integral SCSI controller 3: Version Fibre Channel QL2342 Port 1, 133 MHz PCI-X
Integral SCSI controller 4: Version Fibre Channel QL2342 Port 2, 133 MHz PCI-X
Integral SCSI controller 5: Version Fibre Channel QL2342 Port 1, 133 MHz PCI-X
  Disk drive: unit 0 on SCSI controller 5 (unit 0)
  Disk drive: unit 1 on SCSI controller 5 (unit 1)
  Disk drive: unit 2 on SCSI controller 5 (unit 2)
  Disk drive: unit 3 on SCSI controller 5 (unit 3)
  Disk drive: unit 4 on SCSI controller 5 (unit 4)
  Disk drive: unit 5 on SCSI controller 5 (unit 5)
  Disk drive: unit 6 on SCSI controller 5 (unit 6)
  Disk drive: unit 7 on SCSI controller 5 (unit 7)
  Disk drive: unit 8 on SCSI controller 5 (unit 8)
  Disk drive: unit 9 on SCSI controller 5 (unit 9)
Integral SCSI controller 6: Version Fibre Channel QL2342 Port 2, 133 MHz PCI-X
  Disk drive: unit 1 on SCSI controller 1 (unit 1)
  Disk drive: unit 2 on SCSI controller 1 (unit 2)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Graphics board: V12
Gigabit Ethernet: tg1, module 001c01, PCI bus 2 slot 3 port 0
Gigabit Ethernet: tg2, module 001c01, PCI bus 2 slot 3 port 1
Iris Audio Processor: version RAD revision 13.0, number 1
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 1
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 2
  PCI Adapter ID (vendor 0x104c, device 0xac28) PCI slot 2
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 1
  PCI Adapter ID (vendor 0x14e4, device 0x1648) PCI slot 3
IOC4 firmware revision 83
Dual Channel Display
IP35prom in Module 001c01/Slot n0: Revision 6.211
/usr/gfx/gfxinfo -v
        Managed (":0.0") 2560x1024
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
        DM5 attached to Dual Channel 0
         Monitor 0 type: Unknown
        Dual Channel Display option
         Monitor 1 type: Unknown         Monitor 2 type: Unknown
         Video Output: 1280 pixels, 1024 lines, 60.00Hz (2@1280x1024_60)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
        Channel 1:
         Origin = (1280,0)
         Sync Disabled
         Using Gamma Map 0
(the V12 is linked to the DM5 using the DCD, an SGI F180 screen is connected to the DM5 output)
diskpatch -v
sc5d0l0:  Disk         STON+WIRST336607FC      7656  Serial: 3JA0BGYY
sc5d1l0:  Disk         STON+WIRST336607FC      7656  Serial: 3JA04FZG
sc5d2l0:  Disk         STON+WIRST336607FC      7656  Serial: 3JA0C0W0
sc5d3l0:  Disk         STON+WIRST336607FC      7656  Serial: 3JA0C29V
sc5d4l0:  Disk         STON+WIRST336607FC      7656  Serial: 3JA0C1JN
sc5d5l0:  Disk         STON+WIRST336607FC      7656  Serial: 3JA09KJ6
sc5d6l0:  Disk         STON+WIRST336607FC      7656  Serial: 3JA0B9HG
sc5d7l0:  Disk         STON+WIRST336607FC      7656  Serial: 3JA04F7S
sc5d8l0:  Disk         STON+WIRST336607FC      7656  Serial: 3JA03A9R
sc5d9l0:  Disk         STON+WIRST336607FC      7656  Serial: 3JA04BBV
sc0d1l0:  Disk         SEAGATE ST3146855LC     0003  Serial: 3LN34EZD
sc1d1l0:  Disk         SEAGATE ST3300007LW     D703  Serial: 3KR1DMP1
sc1d2l0:  Disk         SEAGATE ST3300007LW     D703  Serial: 3KR1DMN8
l1cmd serial all
Local System Serial Number      NVRAM         P1003388
Reference System Serial Number  NVRAM         P1003388
Local Brick Serial Number       EEPROM        NNY825
Reference Brick Serial Number   NVRAM         NNY825
INTERFACE   WS_INT_53       NNY825         030_1881_007          A    00
IO9         IO9             NRW778         030_1771_005          B    00
ODYSSEY     ODY128B1_2      NPL883         030_1884_005          B    00
SNOWBALL    SNOWBALL_EDGE   NLB858         030_1927_004          A    00
NODE        IP59_4CPU       NRM277         030_1989_003          B    00
IO DGHTR    CHWS_IO_DAUG    NNW371         030_1875_003          A    00
DIMM 0     1000000000000000B3005A00 444BH               2     8.0  N/A
DIMM 2     1000000000000000FB005A00 444BH               2     8.0  N/A
DIMM 4     CE0000000000000028FB2F00 M3 46L2820BT1-CA0   0B    8.0  N/A
DIMM 6     7F94FFFFFFFFFFFF045EF00D SM57228DSGI100C2   00FF   8.0  N/A
DIMM 1     100000000000000046030500 444BH               2     8.0  N/A
DIMM 3     100000000000000028015A00 444BH               2     8.0  N/A
DIMM 5     CE00000000000000280C3000 M3 46L2820BT1-CA0   0B    8.0  N/A
DIMM 7     CE00000000000000274A0A00 M3 46L2820BT1-CA0   0B    8.0  N/A
l1cmd flash status
Flash image A currently booted
Image      Status        Revision    Built
  A     default         1.38.4       06/30/2005 00:01:55
  B     valid           1.36.14      04/21/2005 09:15:02
l1cmd env
          1.8V    Enabled  10%   1.62/  1.98  20%   1.44/  2.16    1.791
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
        12V #2    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.125
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.337
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.496
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
        5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.251
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
  XIO 12V BIAS    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.938
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.457
  XIO 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
 IP59 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
   IP59 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      IP59 12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.938
     IP59 VCPU    Enabled  10%   1.14/  1.40  20%   1.02/  1.52    1.269
     IP59 SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.470
     IP59 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.480
FAN  0   NODE 1    Enabled         1800         2109
FAN  1   NODE 2    Enabled         1800         2149
FAN  2   NODE 3    Enabled         1800         2177
FAN  3    PCI 1    Enabled         1350         1480
FAN  4    PCI 2    Enabled         1350         1548
FAN  5       HD    Enabled         1620         2033
FAN  6    ODY 1    Enabled         1300         1687
FAN  7    ODY 2    Enabled         1300         1622
FAN  8  N0 LEFT    Enabled         1800         2238
FAN  9  N0 CNTR    Enabled         1800         2127
FAN 10 N0 RIGHT    Enabled         1800         2238
 0 INTERFACE 0       Enabled    [Autofan Control]    76C/168F   40C/104F
 1 INTERFACE 1       Enabled    [Autofan Control]    76C/168F   35C/ 95F
 2 INTERFACE 2       Enabled    [Autofan Control]    76C/168F   34C/ 93F
 3 INTERFACE 3       Enabled    [Autofan Control]    76C/168F   43C/109F
 4 ODYSSEY           Enabled    [Autofan Control]    76C/168F   45C/113F
 5 NODE              Enabled    [Autofan Control]    76C/168F   50C/122F
 6 BEDROCK           Enabled    [Autofan Control]    85C/185F   48C/118F
                     Zone Temp     Target    Current   Zone Fan   Curr/Min
Zone Name  State     Sensors       Average   Average   Index      Fan %
NODE        Enabled           5,6  53C/127F  49C/120F          0   46%/ 46%
BOOST       Enabled           N/A       N/A       N/A     8,9,10   50%/ 50%
HD          Enabled           N/A       N/A       N/A          5   38%/ 38%
PCI         Enabled       0,1,2,3  45C/113F  38C/100F        3,4   57%/ 57%
ODY         Enabled             4  50C/122F  45C/113F          6   64%/ 64%
l1cmd pci
Bus Slot Stat    Power Mode/Speed
  1    1 0x80 01   15W PCI   66MHz
  2    1 0x00 00  7.5W PCI   33MHz
  2    2 0x00 00  7.5W PCI   33MHz
  2    3 0x00 0d   15W PCI   33MHz
  3    1 0x00 0f  none PCIX 133MHz
  3    2 0x00 0d   15W PCIX 133MHz
  4    1 0x00 0d   15W PCIX 133MHz
  4    2 0x00 0f  none PCIX 133MHz
Titox
Re: Tezro, 4*1GHz, 4GB, V12, DM3, DM5, RAD, ...
Unread postby Titox » Tue Sep 20, 2011 2:43 pm
Is the next purchase will be a building to keep your computers?
Super nice machine!!!
http://www.f3b.es
http://unixverse.blogspot.com
Unread postby jan-jaap » Wed Sep 21, 2011 12:45 am
Titox wrote:Is the next purchase will be a building to keep your computers?
Yes (not kidding!)
Titox wrote:Super nice machine!!!
Thanks!
Pontus
Unread postby Pontus » Wed Sep 21, 2011 12:56 am
I too am looking for a house to properly house the collection. I'm having nightmares over house prices here, but I guess the Netherlands are even worse.
Congratulations on a great machine.
BetXen
Unread postby BetXen » Wed Sep 21, 2011 1:40 am
Don't even think about swiss prices... or you will cry.
Unread postby jan-jaap » Wed Sep 21, 2011 1:57 am
I'm not going to buy a new house, I want to build an annex. There's nothing wrong with our current house, except that I had to give up my computer room when we had our second son. So right now my collection is split between the attic (cramped and dusty due to the washing machine & laundry dryer), and garage (not a bad garage as far as garages go, but obviously sub-optimal).
A new annex is hopefully going to provide a permanent home for my collection, and a clear separation between family life and hobby, so I won't need to worry that my boys will be harmed by the computers (or vice versa).
Now that I have the Tezro, I more or less have a sample of every MIPS/IRIX generation (family?). Good thing they stopped making them, or I would need a mansion instead of an annex :lol: Let's see:
workstations:
* Personal IRIS 4D/35
* Indigo R3000
* Indigo R4400 Elan
* Indy R4400 XZ
* Indy R5000
* Challenge S
* Indigo2 R4400 Extreme
* Indigo2 R8000 XZ
* Indigo2 R10000 MaxImpact
* O2 R12K/400
* Octane1 2x400 MXE
* Octane2 2x600 V12
* Fuel V12
* Tezro V12
big(ger) iron:
* Professional IRIS 4D/70GT
* PowerSeries 4D/380VGX
* PowerSeries 4D/440VGX
* Crimson RE
* Power Challenge L
* Onyx1 IR
* Origin 200
* Onyx2 IR3
* Origin 350
... and I probably forgot something. For several systems (mostly the workstations) I have spare systems. Additionally, I've got a friggin huge pile of spares so I can easily change e.g. the 4D/35 into a 4D/20 or transform the Power Challenge from 12xR10K/IRIX6.2 into 12xR4400/IRIX5.3 by swapping some bits and a system disk.
kais58
Unread postby kais58 » Wed Sep 21, 2011 12:34 pm
Damn, even I'll admit that's a pretty nice system ;)
Unread postby recondas » Fri Sep 23, 2011 3:39 pm
Just got back from a relatively brief road trip (so sorry for the belated response), but nice system j-j (it don't get much better than that)!!!
4130photo
Unread postby 4130photo » Sat Sep 24, 2011 11:26 am
Really nice machine, you told me you got the tezro, but the specs are really nice... :mrgreen:
This reminds me that i need to get the stones for my octane to get everything up and running
:Indigo: :Indigo2IMP: :Indigo2IMP: :Octane: :O2: :O200: :Octane2: :Onyx2: :Onyx2: :Onyx2R: :1600SW: :1600SW:
Re: Tezro, 4*1GHz, 8GB, V12 + DCD, DM3, DM5, RAD, ...
Unread postby jan-jaap » Mon Sep 26, 2011 2:51 pm
Finally found back the box of O3K DIMMs that had been missing for half a year :roll: So now the tezro has 8GB RAM. I added a DCD as well.
Unread postby jan-jaap » Thu Oct 20, 2011 2:38 pm
Some pictures:
To the left the DMedia breakout box, with the 'black' and 'white' LVDS cables
It's magic 8-)
Titox
Unread postby Titox » Fri Oct 21, 2011 1:48 pm
Beautiful!!!
Why an Autodesk/Discreet system needs 3 Gigabit ethernet ports?
http://www.f3b.es
Unread postby jan-jaap » Sun Oct 23, 2011 1:59 pm
Titox wrote:Why an Autodesk/Discreet system needs 3 Gigabit ethernet ports?
I have no idea (not a Discreet user), but if you look around you'll see that all these (former) Discreet systems have more or less the same cards installed:
(the picture shows a single port ethernet card, but they always seem to be dual port, like my system)
Source: http://download.autodesk.com/us/systemd ... ctane2.pdf
My Tezro:
Titox
Unread postby Titox » Mon Oct 24, 2011 2:20 am
Related to the license system?
If the license is linked to a MAC address maybe is easy to move the license with the ethernet card? But is pure speculation.
http://www.f3b.es
Unread postby jan-jaap » Mon Oct 24, 2011 2:33 am
That's not it. Discreet software is node locked with a dongle attached to one of the serial ports.
Maybe it has something to do with a dedicated network segment for rendering nodes or frame storage.
