Silencing an O2 using a Noctua NF-R8-1800 as PSU fan
szzsszzs
Unread postby szzsszzs » Mon Jun 27, 2011 1:33 pm
Not a groundbreaking piece of news, but I can confirm that the original PSU fan of the O2
can be easily replaced by a practically noiseless Noctua NF-R8-1800 fan.
Fan specs: Noctua NF-R8-1800, 1800 rpm, 53 m3/h, 17 dB(A), 80x80x25 mm
Noctua website:
http://www.noctua.at/main.php?show=prod ... d=9&lng=en
This type of fan is widespread in PC computer shops (at least in Hungary), that's why I am writing this post.
The fan works very well in a 200 MHz R5k O2 with a single 18 GB r10k SCSI drive and an AV card.
I operated my blue toaster at full CPU load for hours without having any trouble.
One can sleep 4 meters away from the running O2, only the HDD is whispering when getting closer.
Cheers,
Zsolt
[[C|-|E]]
Re: Silencing an O2 using a Noctua NF-R8-1800 as PSU fan
Unread postby [[C|-|E]] » Mon Jun 27, 2011 1:49 pm
Yup, it is really worth upgrading the PSU fan with a Noctua or something similar :).
Image _Betty Blue_
R12000A 400 Mhz; 1 Gb RAM; 72 Gb 15K HDD; IRIX 6.5.29
CrystalEyes; Dial Box; O2Cam "ZEYE"; external Toshiba SD-M1711 DVD-ROM; Octane speakers;
Lock bar; SGI microphone.
Mods: PSU Noctua fan; internal Toshiba SD-M1401 DVD-ROM; Adaptec AIC-7880P SCSI card.
_REKIEM_I7_
Seasonic X 1250W PSU / Intel I7 2600k 4 x 5,00 Ghz / 2 x Gainward 2Gb GTX 560Ti Phantom 2 / 32 Gb DDR3 / Intel x25-M 160 Gb SSD and 10 extra Tb
_REKIEM_T5400_
875W PSU / 2 x Intel Xeon Harpertown 4 x 3,33 Ghz / 1 x EVGA Geforce 4Gb GTX 980 Supercloked / 32 Gb DDR2 667 ECC / Samsung 840 Series Pro 128GB SSD and 3 extra Tb
_Raspberry Pi_
Unread postby hamei » Mon Jul 04, 2011 7:46 pm
szzsszzs wrote:Not a groundbreaking piece of news, but I can confirm that the original PSU fan of the O2 can be easily replaced by a practically noiseless Noctua NF-R8-1800 fan.
Thanks for the little kick in the butt there ... quieting down the O2 has been a "back shelf" project for me for ages, this post finally triggered some action.
Yes, the Noctua is very quiet. Now I have to look at the green light to see if the computer is running. O2's aren't so noisy anyhow but still ... maybe the best ten bucks I've spent this year. Silent - good !
grazie
[[C|-|E]]
Unread postby [[C|-|E]] » Tue Jul 05, 2011 12:39 pm
The second source of noise, in my case, was the hard disc drive. However, since I replaced it with the Seagate I am using know the computer became really quiet, hehe :)
Image _Betty Blue_
_REKIEM_I7_
_REKIEM_T5400_
_Raspberry Pi_
JeroenJ
Unread postby JeroenJ » Mon Aug 29, 2011 12:37 pm
Thanks for the tip! Ordered the fan, installed it & it works like a (very silent) charm :)
SiliconClassics
Unread postby SiliconClassics » Tue Aug 30, 2011 1:24 pm
Does it move as much air as the original O2 fan? Would it be safe to upgrade a 400MHz R12K system this way?
ShadeOfBlue
Unread postby ShadeOfBlue » Wed Aug 31, 2011 4:08 am
The original fan can move 80 m^3/h, but this one moves only 66% as much. The O2's PSU also adjusts the voltage of the fan according to the temperature, so it probably won't run the new fan at full speed because it's calibrated for the old one. [IIRC, there's a potentiometer inside the PSU to adjust this.]
The best way to see if it provides proper cooling would be to get a few of those cheap $2 thermometers from eBay, attach the sensors to various chips inside the O2 (CPU, CRIME, MACE, GBE), run the O2 for a few hours at full load and write down the temperatures, then replacing the fan and repeating the process.
Anything over 70°C is probably very unhealthy.
mapesdhs
Unread postby mapesdhs » Mon Sep 12, 2011 12:58 pm
I did something similar with an Arctic F8 TC, though I rigged it to run at max speed instead of being temp controlled. Still inaudible though, and
with a Fujitsu MAS3036NC disk (36GB 15K), the system is silent. Spec is R7K/350, 512MB. To reduce power consumption even more (it's just
a gateway machine), the unit has no AV module and no CDROM. Keep meaning to install a Gbit NIC, not gotten round to it yet though.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
Krokodil
Unread postby Krokodil » Mon May 11, 2015 11:22 am
Just replaced the O2 fan with the Noctua. Is there anything further I need to do? Though it seems to be running ok.
Did you adjust any of the potentiometers to increase the fan speed and if so how?
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
mapesdhs
Unread postby mapesdhs » Mon May 11, 2015 12:38 pm
I didn't do anything, just connected it up as normal and that's it. Note that nowadays I use the other version of the F8 which doesn't have the temp control, so no need to meddle with the cable.
To clarify: I've never used the Noctua that's the subject of this thread, I use the Arctic F8 instead. Basically the same idea though.
Sad to report though I stopped using the O2 as a gateway a while ago, as I couldn't get the Phobos GigE card working properly, and I wanted better speed than 100Mbit. Thus, I built a Zenyal-based uATX box with a simple uATX board (and Intel model that has two GigE ports), Pentium G2020, silent fans, etc. However, I've done further fan mods since then for other people.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
