Onyx2 Deskside, 4x400MHz R12K, IR3, 8GB RAM
Black Cardinal
Re: Onyx2 Deskside, 2x250MHz R10K, IR2, 1GB RAM
Unread postby Black Cardinal » Sat Feb 12, 2011 5:58 pm
recondas wrote:In the top left panel of the 'Edit post' window should be selections for "Delete post", "Post icon", "Subject" and "Message body". The field to the right of "Subject" should be a editable text box containing the thread title. Changing the contents for that text box will change/update the thread title.
Thanks, that worked. I had tried that earlier but the preview kept the old subject so I thought it wouldn't work and didn't follow through with the submit button before.
ratfink wrote:If you have a way to measure power consumption, I'd be curious to see the consumption with the power supply on, but the key off. I know some SGIs are pretty high (something like 30w for a powered off Octane.)
When I power down this evening I'll take the measurement and post it here. I recall that it was actually pretty small, however, which surprised me because I expected similar numbers.
Edit: 19.8W with the system off but the breaker on. Guess it's not that small.
Black Cardinal
Black Cardinal
Re: Onyx2 Deskside, 4x400MHz R12K, IR3, 8GB RAM
Unread postby Black Cardinal » Thu May 11, 2017 8:56 pm
I actually upgraded this machine quite a while ago but forgot to post updated hinv and gfxinfo dumps. My Onyx2 is now a full IR3 machine and runs twin 1920x1080 displays (NEC EA232WMi). It also has PCI gigabit ethernet in a shoebox.
Power consumption while idle is now ~900W and just over 1kW with all 4 CPUs at 100% and the IR3 driving SkyRocket to both displays.
EDIT: I just noticed that hinv is reporting 8GB RAM, but I thought it still had only 5GB. I don't remember making that upgrade, although it had been on my mental to-do list for some time. But I just pulled one of the node boards and sure enough, it's fully loaded with red DIMMs! :oops: :D I've updated the subject and my signature to match.
            IP31 Board: barcode KRT708     part 030-1523-001 rev  C
   IP31PIMMR12KS Board: barcode KRT237     part 030-1423-002 rev  G
        MODULEID Board: barcode K0010960   part              rev
            IP31 Board: barcode JZT780     part 030-1523-001 rev  C
      4P1G5_MPLN Board: barcode DNA039     part 013-1839-001 rev  E
   IP31PIMMR12KS Board: barcode JZZ703     part 030-1423-002 rev  F
          GE16-4 Board: barcode GLN975     part 030-1398-001 rev  A
         PCI_XIO Board: barcode DJD873     part 030-1062-002 rev  C
             MIO Board: barcode EYZ086     part 030-0880-003 rev  E
          BASEIO Board: barcode ESL146     part 030-0734-002 rev  J
4 400 MHZ IP27 Processors
FPU: MIPS R12010 Floating Point Chip Revision: 3.5
CPU 0 at Module 1/Slot 2/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 3.5. Scache: Size 8 MB Speed 266 Mhz  Tap 0xa
CPU 1 at Module 1/Slot 2/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 1/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 3 at Module 1/Slot 1/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 8192 Mbytes
Memory at Module 1/Slot 82: 4096 MB (enabled)
  Bank 7 contains 512 MB (Standard) DIMMS (enabled)
Memory at Module 1/Slot 81: 4096 MB (enabled)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: InfiniteReality3
Gigabit Ethernet: tg1, module 1, PCI bus 0 slot 0
Iris Audio Processor: version RAD revision 7.0, number 1
Origin PCI XIO board, module 1 slot 2: Revision 3
  PCI Adapter ID (vendor 0x14e4, device 0x1645) PCI slot 0
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 6
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 7
HUB in Module 1/Slot 2: Revision 6 Speed 100.00 Mhz (enabled)
HUB in Module 1/Slot 1: Revision 6 Speed 100.00 Mhz (enabled)
IO6prom on Global Master Baseio in Module 1/Slot io2: Revision 6.136
   Managed (":0.0") 3840x1080
   Display has 2 channels
   4 GEs (of 4), occmask = 0x0f
   2 RM10 boards (of 2) 1/1/0/0
   Texture Memory: 256MB/256MB/-/-
   Small pixel depth
   32K cmap
   brd: 80f61806 3041606/3041606/-/- f9391002
   rm0: 15032057 15431057
         4631057 2/2/2/2
         4d31057 2/2/2/2/2/2/2/2
         4938057 5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5
   rm1: 15032057 15431057
         4631057 2/2/2/2
    dg: 05532057
         5838057 1/1/1/1
         5631057 1/1
   GE:   NIC #:      0000.002b.f18c (family: 0b)
         Serial #:   GLN975
         Part #:     030-1398-001
   KT:   No NIC serial number available.
   RM0:  NIC #:      0000.0048.3fb5 (family: 0b)
         Serial #:   LMJ452
         Part #:     030-1402-001
   TM0:  NIC #:      0000.004e.3e6c (family: 0b)
         Serial #:   LBT388
         Part #:     030-1588-001
   RM1:  NIC #:      0000.0059.a26b (family: 0b)
         Serial #:   MHV186
   TM1:  NIC #:      0000.0059.9c74 (family: 0b)
         Serial #:   MHV157
   RM2:  No NIC serial number available.
   TM2:  No NIC serial number available.
   RM3:  No NIC serial number available.
   TM3:  No NIC serial number available.
   BP:   No NIC serial number available.
   DG:   NIC #:      0000.001f.7a34 (family: 0b)
         Serial #:   GTP669
         Part #:     030-1055-001
   DGOPT:No NIC serial number available.
    Video Output: 1920 pixels, 1080 lines, 60.00Hz (IR-NEC_EA232WMi_1920x1080_60.vfo)
    Video Format Flags:  (none)
    Sync Output(s):
     Composite sync on Green
     Composite TTL sync on Aux 0
    Using Gamma Map 0
   Channel 1:
    Origin = (1920,0)
    Sync Output(s):
    Using Gamma Map 0
Last edited by Black Cardinal on Sat May 13, 2017 12:59 am, edited 2 times in total.
Black Cardinal
Jack Luminous
Unread postby Jack Luminous » Fri May 12, 2017 6:33 am
Impressive machine ! 8-)
mopar5150
Unread postby mopar5150 » Fri May 12, 2017 9:43 pm
Beautiful system! The Onyx2 deskside is my favorite SGI.
:Tezro: :O3x0: :A350:
Y888099
Unread postby Y888099 » Sat May 13, 2017 4:15 am
What are you planning to do with your Onyx2 Deskside?
Y888099
Unread postby Y888099 » Mon May 15, 2017 2:49 am
I mean, it's 1KWatt machine, one should have 1KU purpose to switch it on
(or just to dare wake up the dragon, also known as The Winter Heater :D )
Black Cardinal
Unread postby Black Cardinal » Mon May 15, 2017 12:43 pm
Y888099 wrote:What are you planning to do with your Onyx2 Deskside?
I get asked this question a lot. :P Whenever someone sees it in my office they always ask what I use it for.
Several months ago I acquired a nice Crystal Eyes set with an emitter and 4 pairs of glasses that I've been meaning to hook up. I want to play with some 3D stereo imaging with my elementary-aged sons. I still need to dig my old Mistubishi Diamondtron out of the closet to handle the 120Hz refresh rate, though. I mostly just compile toy programs to try things out I read about in the documentation for IR and IRIX multiprocessing. I also use it as my IRIX build machine since it's significantly faster than my Indigo2.
I don't have a serious purpose for my Onyx2, but I do play with it once in a while and honestly it's the most fun machine I own. There's something cool about turning that key and hearing the deep low roar of the fans. It can't compete with my Mac Pro or even my MacBook Pro for raw performance (although it keeps up within a respectable distance) but I love how even when the Onyx2 is at 100% processor utilitization it's just as responsive as ever. Even my Mac Pro can be brought to its knees under heavy load (I do a lot of video processing on it).
To be totally honest, the thing I do the most is troubleshoot and fix it. :!: Especially if it's been sitting for more than a couple of months without being powered on, it often comes up with one or more processors disabled due to invalid PROM code. I've gotten pretty proficient at doing the flash and clearalllogs cycle. It's loaded with removable hardware and the opportunity to just tinker is enormous. In my day job I'm fortunate to straddle the line between hardware and software, and this machine gives me the opportunity to play on that line but without the stress of deadlines and customer downtime. (I'm an EE with power and software backgrounds but do FPGA development and system architecture work most of the time now.)
I like it enough that I've actually bought a window air conditioner for my shop office so I can run it in the summer. I don't run the Onyx2 so much that my wife complains about the power bill. It helps that I live in a part of the world with relatively cool summers.
Black Cardinal
Kotomo
Unread postby Kotomo » Mon May 15, 2017 1:30 pm
Sounds similar to the struggles I've been going through with my two Origin2k's. I got one of them all set, working clean as a whistle, only to have the hard drive fail on me one day when I went to power it on. Not the exact same problem, but just another headache.
Consider me forever envious of your Onxy2. Fantastic setup!
:Octane: :Octane: :Octane: :Octane: :Octane2: :Octane2: :Fuel: :O2: :O2: :O2: :O2000: :O2000:
maxsleg
Unread postby maxsleg » Thu Aug 17, 2017 8:23 am
nice lab - like the HP141 - had one myself for a long time!
:ChallengeL: :O2000: :Onyx2: :Onyx: :O2000R: :O2000R: :O2000E: :O2000E: :Onyx2R: :O3000: :0300: :0300: :0300: :Indy: :Indigo2: :Indigo2: :Indigo2IMP: :Octane: :Octane: :Octane2: :Octane2: :Fuel: :Fuel:
necron2600
Unread postby necron2600 » Thu Aug 17, 2017 11:20 am
Tell the wife why your Onyx2 runs for days or weeks consuming electricity for no reason:
From the Onyx2 Owners Guide page 95 http://www.irix7.com/techpubs/007-3454-004.pdf
"Do not power off the system frequently; leave it running over nights and weekends,
if possible."
The manual said so!
Users browsing this forum: Titox and 0 guests
