Fuel: 700 MHz, 4GB RAM, V12, GigE, 2xU320, DM6
smj
Re: Fuel: 700 MHz, 4GB RAM, V12, GigE, 2xU320, DM6
Unread postby smj » Mon May 02, 2016 4:28 pm
BTW: The PSU on this Fuel is no longer powering up. Not sure if I'll replace it or try the ATX hack yet, but stay tuned. (Don't literally stay tuned, it might be another five years...)
mopar5150
Unread postby mopar5150 » Wed May 04, 2016 11:42 am
I have a Fuel PSU I can give you cheap if you don't go the ATX hack route. PM me your info.
:Tezro: :O3x0: :A350:
Unread postby Trippynet » Wed May 04, 2016 11:52 am
mopar5150 wrote:I have a Fuel PSU I can give you cheap if you don't go the ATX hack route. PM me your info.
Are there any spares you don't have? :D
mopar5150
Unread postby mopar5150 » Wed May 04, 2016 1:17 pm
I tend to get this stuff by the pallet so I wind up with a little of everything. :D
Unread postby ClassicHasClass » Thu May 05, 2016 3:51 am
You should see his house.
(*has seen his house :D )
smj
Unread postby smj » Sat Jul 09, 2016 2:26 pm
Thanks again to mopar5150 for the replacement PSU.
The thin client on my desk couldn't access the serial port (nice job, Wyse/SuSE). As it was on the desk right above the Fuel, I couldn't just drag in some other device... I finally sorted it out by pulling the flash DOM and booting Debian off of a thumb drive.
So here's what was in the L1 logs from previous attempts to powet up:
L1 wrote:05/27/16 01:14:12 L1 booting 1.44.4
05/27/16 01:14:13 USB0: waiting on open
05/27/16 01:14:34 power up (PANEL)
05/27/16 01:14:40 reset again MIPS
05/27/16 01:14:46 SRAM low fault limit reached @ 1.053V.
05/27/16 01:15:16 power down (ENVIRONMENTAL)
05/27/16 01:15:26 NMI (PANEL)
05/27/16 01:15:30 power up (PANEL)
05/27/16 01:15:36 reset again MIPS
05/27/16 01:15:42 SRAM low fault limit reached @ 1.027V.
05/27/16 01:16:12 power down (ENVIRONMENTAL)
05/27/16 18:47:50 power up (PANEL)
05/27/16 18:47:56 reset again MIPS
05/27/16 18:48:01 SRAM low fault limit reached @ 1.053V.
05/27/16 18:48:31 power down (ENVIRONMENTAL)
Not promising. Here's what I got when I tried to power it up from the L1:
L1 wrote:001a01-L1>power up
001a01 ATTN: PIMM 1.5V low fault limit reached @ 1.015V.
001a01 ATTN: brick auto power down in 30 seconds
001a01 ATTN: brick auto power down in 5 seconds
001a01 ATTN: brick is powering down now!
001a01-L1>
At (hopefully) small risk of doing further damage I turned off environmental monitoring and powered up again, so I'd have a little more time to get actual voltage readings out of the L1.
           12V   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.063
        12V IO   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.125
            5V   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
          3.3V   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.337
          2.5V   Disabled  10%   2.25/  2.75  20%   2.00/  3.00    2.470
          1.5V   Disabled  10%   1.35/  1.65  20%   1.20/  1.80    1.466
        5V AUX   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.096
      3.3V AUX   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
 PIMM 12V BIAS   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.125
          SRAM   Disabled  10%   2.25/  2.75  20%   2.00/  3.00    0.962     <== !!!
          VCPU   Disabled  10%   1.13/  1.38  20%   1.00/  1.50    1.255
     PIMM 1.5V   Disabled  10%   1.35/  1.65  20%   1.20/  1.80    0.818     <== !!!
 PIMM 3.3V AUX   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
   PIMM 5V AUX   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.096
  XIO 12V BIAS   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
        XIO 5V   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
      XIO 2.5V   Disabled  10%   2.25/  2.75  20%   2.00/  3.00    2.470
  XIO 3.3V AUX   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
So, not promising. Time to start searching the forums and 'Net for these errors. Maybe take enough things out of the Fuel for a close visual inspection, and reseat a few things. And time to post this, since this Live Debian instance has already locked up on me once, losing a post...
mopar5150
Unread postby mopar5150 » Mon Jul 11, 2016 6:59 am
Start by pulling out all of the PCI cards and then disconnect the HDD and power it up again. I can send you a 600mhz MB+CPU to test with if you need it.
As dumb as it sounds, check for screws rolling around in the case or under the PIMM module. I have found this in many machines where I had random PSU and memory issues.
Unread postby uunix » Fri Jul 14, 2017 1:40 pm
Did we get a solution on this?
I came back tonight and for the first time in a week powered on the FUEL.. only to be greeted with it powering off after 30 seconds (I now know).
Checked the console out which would have given me a red hearing as I'd be pulling all sorts of things..
Running in DDR mode
Testing/Initializing memory ...........
So connected to the L1
001a01 ATTN: XIO 3.3V AUX low fault limit reached @  0.000V.
001a01 ATTN: brick auto power down in 25 seconds
001a01 ATTN: brick auto power down in 20 seconds
001a01 ATTN: brick auto power down in 15 seconds
001a01 ATTN: brick auto power down in 10 seconds
Pulled cards, disconnected drives, changed the power plug it was plugged into.. no joy!
AND THIS IS WHAT PISSES ME OFF!!!
I don't turn it on for a few days, and then they cry like a damn baby and blow themselves up!!! It's not been moved, there are no screws floating around , there has been no power spikes.. IT's JUST HAVING A BITCH FIT BECAUSE IT FELT LEFT OUT!!! FSCKER!!!
This machine has been flawless, each day I turn it on.. and I know it's going to turn on!
ajw99uk
Unread postby ajw99uk » Sat Jul 15, 2017 12:59 pm
Mine's not been on for weeks, maybe months - this does not bode well ... though maybe the prospect of pseudo-DCD when I come to experiment with the Dualhead2Go will be incentive enough.
It has red-lighted before but recovered after a console log-in. <fingers crossed >
