Fuel: 700 MHz, 4GB RAM, V12, GigE, 2xU320, DM6
smj
Unread postby smj » Mon Dec 20, 2010 9:33 pm
# hinv -vm
            IP34 Board: barcode NYX987     part 030-1707-005 rev -B
          ASTODY Board: barcode RBG430     part 030-1726-006 rev -B
1 700 MHZ IP35 Processor
CPU: MIPS R16000 Processor Chip Revision: 4.1
FPU: MIPS R16010 Floating Point Chip Revision: 4.1
  Processor revision: 4.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0xa
Main memory size: 4096 Mbytes
Integral SCSI controller 2: Version unknown (30)
Integral SCSI controller 3: Version unknown (30)
IOC3 serial port: tty1
IOC3 serial port: tty2
Graphics board: V12
Gigabit Ethernet: tg1, module 001c01, PCI bus 2 slot 2
  PCI Adapter ID (vendor 4096, device 48) pci slot 1
  PCI Adapter ID (vendor 5348, device 5701) pci slot 2
  PCI Adapter ID (vendor 4215, device 4630) pci slot 1
  PCI Adapter ID (vendor 4334, device 53585) pci slot 2
  PCI Adapter ID (vendor 4265, device 3) pci slot 4
  PCI Adapter ID (vendor 4165, device 51297) pci slot 5
SD-DIGVID Standard Definition Digital Video: unit 0, revision 7.60.0
USB controller: type OHCI
# /usr/gfx/gfxinfo -vv
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: DEL -24568
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  DEL-40968
         Gain (all color components) - 0.000000 ; range [1,10]
Monitor is a Dell 2001FP 20" 4:3 LCD panel - not sure why it's reporting this way
# scsicontrol -i /dev/scsi/*
/dev/scsi/sc0d1l0:  Disk          SGI     IC35L073UWDY10-0S27C
Device is  ready
/dev/scsi/sc1d6l0:  CD-ROM        TOSHIBA DVD-ROM SD-M17111005
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  synch linkedcmds
Device is  not ready
# /sbin/diskpatch -v
sc0d1l0:  Disk         SGI     IC35L073UWDY10-0S27C  Serial: E6WYY66C
Since this is an IP35-based system I thought I'd be able to collect the L1 information, but when I tried to run "l1cmd serial all" it locked up the machine. Not sure what's up with that...
EDIT: Here's what I got from the motherboard serial connector:
001a01-L1>serial all
Local System Serial Number      EEPROM        08:00:69:10:89:1A
Local Brick Serial Number       EEPROM        NYX987
Reference Brick Serial Number   NVRAM         NYX987
NODE        IP34            NYX987         030_1707_005          B    00
MAC         MAC ADDRESS     NA             NA                    NA   NA
PIMM        IP34PIMM        NZS678         030_1891_001          D    00
XIO         ASTODY          RBG430         030_1726_006          B    00
DIMM 0     7F94FFFFFFFFFFFF3FFDD01D SM57228DSGI100C2   00FF   8.0  N/A
DIMM 2     CE0000000000000026371600 M3 46L2820BT1-CA0   0B    8.0  N/A
DIMM 1     7F94FFFFFFFFFFFF3C03D01D SM57228DSGI100C2   00FF   8.0  N/A
DIMM 3     CE0000000000000027142100 M3 46L2820BT1-CA0   0B    8.0  N/A
001a01-L1>
001a01-L1>env
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.938
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.992
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.354
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.457
          1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.466
        5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.096
      3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
 PIMM 12V BIAS    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
          SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.522
          VCPU    Enabled  10%   1.13/  1.38  20%   1.00/  1.50    1.255
     PIMM 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.480
 PIMM 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
   PIMM 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.096
  XIO 12V BIAS    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.875
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.018
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.470
  XIO 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
FAN  0  EXHAUST    Enabled          920         1240
FAN  1       HD    Enabled         1560         2149
FAN  2      PCI    Enabled         1120         1454
FAN  3    XIO 1    Enabled         1600         2311
FAN  4    XIO 2    Enabled         1600         2235
FAN  5       PS    Enabled         1349         2518
 0 NODE 0            Enabled    [Autofan Control]    80C/176F   37C/ 98F
 1 NODE 1            Enabled    [Autofan Control]    80C/176F   39C/102F
 2 NODE 2            Enabled    [Autofan Control]    80C/176F   30C/ 86F
 3 PIMM              Enabled    [Autofan Control]    80C/176F   41C/105F
 4 ODYSSEY           Enabled    [Autofan Control]    80C/176F   35C/ 95F
 5 BEDROCK           Enabled    [Autofan Control]    85C/185F   40C/104F
001a01-L1>
EDIT: This might explain the problems with the L1 commands from IRIX -- I'll add "flash status" to the hinv guidelines page in the wiki... There are reports of issues with at least Fuels and the later L1 firmware releases, as described here: viewtopic.php?f=3&t=16721896
001a01-L1>flash status
Flash image B currently booted
Image      Status        Revision    Built
  A     valid           1.44.4       09/25/2006 13:05:01
  B     default         1.44.4       09/25/2006 13:05:01
001a01-L1>
Re: Fuel: 700 MHz, 4GB RAM, V12, GigE, 2xU320, DM6
Unread postby recondas » Mon Dec 20, 2010 9:40 pm
Congratulations - that's a very nice Fuel.
Interesting about the serial all induced lockup - anything interesting appear in the system or L1 logs?
smj
Unread postby smj » Mon Dec 20, 2010 9:41 pm
Earlier this month I came across an auction for a Fuel with the following description:
USED SGI SILICON GRAPHICS FUEL
Working
700 MHz
2 GB RAM Memory
73 GB Hard Drive
Irix 6.5 Operating System Installed (May Need Reintall)
Irix 6.5 OS Disks included
* ITEM WILL BE SOLD AS IS
Not exactly a verbose description, but if accurate at US$300 this was already a good deal. The fact that the IRIX CDs looked like a later release didn't hurt any, and if the hinv picture was accurate there was a GigE card installed.
Well, the CDs turned out to be for 6.5.30. The gfx turned out to be V12, and there's a dual-channel LSI 22320-R UltraSCSI 320 controller as well as the SGI-tagged 3COM 3C996B-T. And totally unexpectedly <drumroll please> there was a DMediaPro DM6 PCI card (013-3745-002) digital video card installed as well. (For more on the card, I started this thread in SGI:Hardware.)
After I can image the disk this will probably become my primary IRIX desktop. I'll be looking around for one of the supported PCI audio cards. I've already maxed out the RAM and added the DVD-ROM drive.
Pictures to follow shortly.
Unread postby recondas » Mon Dec 20, 2010 9:49 pm
$300 would easily classify as an early Christmas gift. :D
smj wrote:After I can image the disk this will probably become my primary IRIX desktop. I'll be looking around for one of the supported PCI audio cards. I've already maxed out the RAM and added the DVD-ROM drive.
Be interesting to see if any of the apps you mentioned in your DM6 thread include video control or capture tools. The DM6 <and the DM3, for that matter>, used OpenML rather than the traditional IRIX Video Control Panel <VCP> and IRIX video daemon <videod>.
smj
Unread postby smj » Mon Dec 20, 2010 10:00 pm
recondas wrote:Congratulations - that's a very nice Fuel. Interesting about the serial all lockup - anything interesting appear in the system or L1 logs?
Thanks - and I'm not sure about the L1 logs, because when I tried running "l1cmd log" it locked up again. Not sure it's useful, but here's what I've got from the serial port during a startup after I'd added the RAM and DVD drive (and restarted, otherwise you'd see the PROM message about previously unknown RAM).
Running in DDR mode
Testing/Initializing memory ...............      DONE
Copying PROM code to memory ...............      DONE
Discovering local IO ......................      DONE
Local hub NUMAlink is down.
*** Local network link down
DONE
Found 1 objects (1 hubs, 0 routers) in 30360 usec
Waiting for peers to complete discovery....      DONE
Intializing any CPUless nodes..............      DONE
Checking partitioning information .........      DONE
Loading BASEIO prom .......................      DONE
BASEIO PROM Monitor SGI Version 6.210  built 02:30:38 PM Aug 26, 2004 (BE64)
1 CPUs on 1 nodes found.
PS/2 Keyboard & Mouse diagnostics
    Found mouse on port 0
    Found keyboard on port 1
PS/2 Keyboard & Mouse diagnostics passed
Graphics diagnostics
        Board version 1 - Buzz revision 3B
        On board sdram size: 128 Mb
        Cas latency: CAS 3
        4 banks by sdram module
Device passed diagnostics
Walking SCSI Adapter 0, (pci id 1)
1+ Device Vendor Product: SGI IC35L073UWDY10-0
2- 3- 4- 5- 6- 7- 8- 9- 10- 11- 12- 13- 14- 15- = 1 device(s)
Walking SCSI Adapter 1, (pci id 1)
1- 2- 3- 4- 5- 6+ Device Vendor Product: TOSHIBA DVD-ROM SD-M1711
XXXX console login:
Interesting bit there with the console login - the graphics console automatically logs in as the "opal" user and tries to start up some apps, which appear to fail-restart-fail in an endless loop. Other messages indicate the failure is related to the other network nodes which are no longer reachable.
I haven't tried talking to the L1 via the dedicated USB port yet. Due to disk space limitations, the laptop that's hosting the DINA VM can't also have the L3 VM at the same time. :?
Unread postby recondas » Mon Dec 20, 2010 10:03 pm
smj wrote:I haven't tried talking to the L1 via the dedicated USB port yet. Due to disk space limitations, the laptop that's hosting the DINA VM can't also have the L3 VM at the same time. :?
There should be a DB9 serial port on the motherboard <right next to the planar SCSI connector> that provides a slightly more convenient connection to the L1 controller. You might try those commands with only the L1 running.
smj
Unread postby smj » Mon Dec 20, 2010 10:07 pm
Nothing shocking about the pictures, but just for the sake of completeness...
Does the 3/4 view make it look more interesting?
The back of the machine
Closer view of the labeling
smj
Unread postby smj » Mon Dec 20, 2010 10:25 pm
recondas wrote:There should be a DB9 serial port on the motherboard <right next to the planar SCSI connector> that provides a slightly more convenient connection to the L1 controller. You might try running the commands with only the L1 running.
I took the cable I'd been using to speak to the external serial port and plugged it into the motherboard DB9, but it came all the way up to the menu on the V12 w/o any activity on the L1 connector. No "linenoise" indicating a speed mismatch, just an absence of any output. Whacking the enter key makes no difference.
If it's a crossover/null modem issue, I'm lacking anything to suit for DB9... Guess I'd better check the docs.
Unread postby recondas » Mon Dec 20, 2010 10:31 pm
smj wrote:I took the cable I'd been using to speak to the external serial port and plugged it into the motherboard DB9, Guess I'd better check the docs.
That same cable ought to work - what serial port settings did you use - 38400 / 8 / N / 1 / ?
Dr. Dave
Unread postby Dr. Dave » Mon Dec 20, 2010 10:32 pm
You should be able to find the DB9 cross-cables super cheap at your local satellite shop, they were often used for upgrading firmware on FTA units.
smj
Unread postby smj » Mon Dec 20, 2010 10:52 pm
recondas wrote:That same cable ought to work - what serial port settings did you use - 38400 / 8 / N / 1 / ?
I hate it when I out-clever myself. The console serial port is set to run at 9600, but I ass-umed that I'd see garbage even if the L1 port was running at another speed... So here's the L1 log:
001a01-L1>log
12/20/10 17:25:22 reset (PANEL)
12/20/10 22:58:29 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:31 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:33 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:35 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:37 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:39 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:41 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:43 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:45 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:47 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:49 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:51 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:53 SCC WR 0 (len=127) - UART:UART_TIMEOUT
12/20/10 22:58:55 SCC WR 0 (len=62) - UART:UART_TIMEOUT
12/20/10 22:59:21 Power Down: press power button again to immediately power down.
12/20/10 22:59:22 SCC WR 0 (len=102) - UART:UART_TIMEOUT
12/20/10 23:00:20 power down (PANEL)
12/20/10 23:54:54 SMP unregistering events
12/20/10 23:54:54 UNREG: 3000513c 0 4
12/20/10 23:54:55 SMP-R: UART:UART_NO_CONNECTION
12/20/10 23:55:13 SMP unregistering events
12/20/10 23:55:13 UNREG: 3000513c 0 4
12/20/10 23:55:14 SMP-R: UART:UART_FRAMING_ERROR
12/20/10 23:55:21 power up (PANEL)
12/20/10 23:55:27 reset again MIPS
12/20/10 23:55:31 SMP unregistering events
12/20/10 23:55:31 UNREG: 3000513c 0 4
12/20/10 23:55:32 SMP-R: UART:UART_FRAMING_ERROR
12/20/10 23:55:41 SMP unregistering events
12/20/10 23:55:41 UNREG: 3000513c 0 4
12/20/10 23:55:42 SMP-R: UART:UART_FRAMING_ERROR
12/20/10 23:56:35 SMP unregistering events
12/20/10 23:56:35 UNREG: 3000513c 0 4
12/20/10 23:56:36 SMP-R: UART:UART_FRAMING_ERROR
12/20/10 23:57:33 SMP unregistering events
12/20/10 23:57:33 UNREG: 3000513c 0 4
12/20/10 23:57:34 SMP-R: UART:UART_FRAMING_ERROR
001a01-L1>
Note: I'll go paste the usual L1 output into the top post.
Unread postby recondas » Mon Dec 20, 2010 10:55 pm
smj wrote:Note: I'll go paste the usual L1 output into the top post.
OK - I'm curious to see the various hardware revisions in serial all.
Dr. Dave
Unread postby Dr. Dave » Mon Dec 20, 2010 11:19 pm
The Sound Blaster Audigy (with the firewire port) works fine, though the firewire port is purely cosmetic. The Audigy2 cards have sample-rate issues that render them problematic on a Fuel. Some of the later 'cheaper' Audigy cards don't use the EMU chip though, so best to stick with the original Audigy (or the Audigy ES, same minus the firewire).
An M-Audio Revolution 7.1 is the best one obviously but practically unobtanium, and the RAD boards require an external DAC.
smj
Unread postby smj » Mon Dec 20, 2010 11:34 pm
Dr. Dave wrote:The Sound Blaster Audigy (with the firewire port) works fine, though the firewire port is purely cosmetic. The Audigy2 cards have sample-rate issues that render them problematic on a Fuel. Some of the later 'cheaper' Audigy cards don't use the EMU chip though, so best to stick with the original Audigy (or the Audigy ES, same minus the firewire).
That's interesting, because the recommendations I'd read specified the Audigy2 ZS. Does the "ZS" avoid the sample-rate issues you mention?
smj
Unread postby smj » Mon Dec 20, 2010 11:40 pm
recondas wrote:OK - I'm curious to see the various hardware revisions in serial all.
Bear in mind there's one potentially relevant piece of information I left out of the top post - the existing installation is IRIX 6.5.18. Could be missing one or more patches, etc.
