Fuel DMediaPro DM6 PCI Digital Video
smj
Unread postby smj » Mon Dec 20, 2010 8:05 pm
I recently acquired a Fuel that included a DMediaPro DM6 PCI digital video option card. These seem to be rare beasts, so I thought I'd better put up what information I had about it. SGI part number for this example is 013-3745-002, and the board bears "DVS EDDY4" in a couple locations.
The station itself seems to be part of a turnkey solution possibly intended to run something called "Opal" - I found some traces of a digital asset management package, a video/image enhancement package, and a number of production outfits by that name via Google. I can say that this system also ran ObjectStore (v5), which I haven't run across in many years, and that it has dependencies on other machines in some kind of local network.
If you just want to see a couple photos, scroll down. First I'll put in some info from/about the card.
Partial hinv output:
  PCI Adapter ID (vendor 4096, device 48) pci slot 1
  PCI Adapter ID (vendor 5348, device 5701) pci slot 2
  PCI Adapter ID (vendor 4215, device 4630) pci slot 1
  PCI Adapter ID (vendor 4334, device 53585) pci slot 2
  PCI Adapter ID (vendor 4265, device 3) pci slot 4
  PCI Adapter ID (vendor 4165, device 51297) pci slot 5
SD-DIGVID Standard Definition Digital Video: unit 0, revision 7.60.0
Select output from dvsinfo:
DVSINFO Information File
General Info
Date:   2010/11/21 22:18:27
dvsinfo: 2.5p22
Driver Info
driverinfo:
 version      2.5p33
 compiled     Aug 28 2002  12:42:20
licence:
 ramsize      128 MB
 audio        0 channels
 beta         0
 diskrecorder 0
 disksize     0 MB
 duallink     0
 film2k       0
 film2kplus   0
 hd360        0
 hsdl         0
 keychannel   0
 mixer        1
 rgbsupport   1
 sdtv         1
 streamer     1
hwinfo0:
 epldversion  73c00
 epldoptions  0f6fefff
 cardrevision 43201
 cardoptions  0000150f
 serialnr     19060503
 pciwidth     64
 pcispeed     33 MHz
epld:
 pciif        7.60.0
 csrmux       1.0.13
 pixmux       1.0.19
PCI Scan
PCI Device List
 Vendor:10ee Id:d151 at bus:0 device:0 function:0
 Vendor : 'Xilinx' Device : 'DVS:SDBoard' rev:2
PCI Dump
PCI Device List
00 Vendor     10ee
02 Device     d151
04 Command    0006      Memory Master
06 Status     0200      Devsel:Medium
08 Revision   02
09 Class      040000    MultimediaController VideoDevice
0c Cacheline  00        Cachelinesize 0 bytes
0d Latancy    f8        Latancy 248 PCI cycles
0e Header     00        Header type:Normal
0f BIST       00
10 Addr0      00400000  00400000
14 Addr1      02000000  02000000
18 Addr2      00000000
1c Addr3      00000000
20 Addr4      00000000
24 Addr5      00000000
30 ExRom      00000000
3c IntLine    ff
3d IntPin     01
3e Min Grant  01
3f Max Lat    ff
Front side of the DM6, Fuel PCI card
Back side of the DM6, Fuel PCI card
Re: Fuel DMediaPro DM6 PCI Digital Video
Unread postby recondas » Mon Dec 20, 2010 8:49 pm
Interesting - while similar, it is different than the DM6 I have. The DM6 was <originally> based on the DVS SDStation OEM, which has a slightly different layout <a line drawing illustrating the board layout can be seen on page 2-2 of the download-only manual http://techpubs.sgi.com/library/manuals ... 64-002.pdf >
Here's a photo of the one I have bearing an SGI part number label <just visible in the top right corner>. Of course, its very possible that SGI might have released a later or updated board with a different layout <yours is marked with part number 013-3745-002, while the one I have has 013-3745-001>:
Unread postby nekonoko » Mon Dec 20, 2010 9:22 pm
Another kind of interesting detail is smj's card is keyed for 3.3V and recondas' card is 3.3V/5V universal.
Dr. Dave
Unread postby Dr. Dave » Mon Dec 20, 2010 10:29 pm
I have a few of them here, but they look like the -001 version with the green PCB. I also have some of the brackets with the cables which plug into the connectors on the top of the board, though these are likely not used when running in SGI mode. I think that these cards can also handle audio - but traditionally SGI's use a separate discrete audio path - so it likely goes unused.
Differences seem to be in the top connectors, obviously. I'd bet the boards are electrically and functionally equivalent, with the 'newer' board utilizing smaller parts, and looks like it has centralized the logic a bit more (one big Xilinx as opposed to a bunch of various glue FPGA/CPLD's), and since many Xilinx parts include internal RAM, you don't need external memory chips. This also might explain the '3V only' change as well. There also is significantly less heatsinking on the newer board, which also leads me to believe the newer board is evolutionary, as this all adds up to the sorts of changes boards go through from first revisions.
Supposedly the DM6 works in Octane too. Anyone remember offhand if they are keyed for 5V or 3V in the shoebox/shoehorns?
Unread postby nekonoko » Tue Dec 21, 2010 12:35 am
Dr. Dave wrote:Supposedly the DM6 works in Octane too. Anyone remember offhand if they are keyed for 5V or 3V in the shoebox/shoehorns?
Octane is 5V only, so they'd need to be the green 3.3V/5V version.
oldsgifan2011
Unread postby oldsgifan2011 » Tue Jan 11, 2011 12:05 pm
I am new to nekochan so I'm quite sure of the etiquette - I would like to buy one of these Fuel Digital Video cards if possible - suggestions?
oldsgifan2011
Unread postby oldsgifan2011 » Tue Jan 11, 2011 12:06 pm
I meant to say - not quite sure of....
PymbleSoftware
Unread postby PymbleSoftware » Tue Jan 11, 2011 12:25 pm
oldsgifan2011 wrote:I am new to nekochan so I'm quite sure of the etiquette - I would like to buy one of these Fuel Digital Video cards if possible - suggestions?
Click here:
viewforum.php?f=5
Then click the "new topic" button.
Post the hinv of your Fuel in
viewforum.php?f=14
You can list your SGIs in your signature line as described in this topic:
viewtopic.php?f=2&t=16717997
R.
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
QuicksilverG4
Unread postby QuicksilverG4 » Fri Jan 28, 2011 5:43 pm
I'd picked up some DVS SDStation boards awhile ago (see thread here) but wasn't having any luck with them. All three were passed on though I don't recall who got them at the moment. Have you been able to do anything with the DM6? I don't think we ever figured out if the boards I bought were really identical to what SGI sold and I don't think there's ever been much about the DM6 posted on the board.
Unread postby recondas » Fri Jan 28, 2011 6:04 pm
The DM6 relies upon OpenML rather than the traditional SGI video tools or libraries. So the old school IRIX video daemon, videod, doesn't recognize the board and won't load, which also means none of the other IRIX video capture tools work either. Using a combination of the DM6 software package provided by SGI and the SDK from DVS, the one I have will display RGB test screens, but that's as far as I got without an SD video source.
The situation is similar to that of the DM3, which is also OpenML based. The most widely known DM3 application(s) were provided by Discreet. So far I haven't found an equivalent app for the DM6.
BSDero
Unread postby BSDero » Mon Dec 31, 2012 9:07 pm
got one of these cards with my SGI fuel, and really, HAVE NOT IDEA WHAT TO DO WITH THIS CARD or WHAT CAN BE DONE.
suggestions??
__Zacatito__Image 600 MHZ R14000; 17GBytes HD
__Nopalito__Image 200 MHZ R5000; 9GBytes HD
Guadalajara, Jal and Aguascalientes, Ags
Mexico
canavan
Unread postby canavan » Tue Jan 01, 2013 12:51 pm
You could add OpenML drivers to e.g. Blender, Cinelerra, Kdenlive, LiVES, Ekiga or Linphone. If you need an IRIX dmedia audio driver before you build a nekoware package for any of those, I'll be glad to be of assistance.
BSDero
Unread postby BSDero » Tue Jan 15, 2013 1:12 pm
:D mmmm some ideas crossed my mind
Mexico
devv
Unread postby devv » Mon May 02, 2016 6:33 am
(Just for cross-referencing purposes -- DM6 base support file + SDK archive location can be found in:
viewtopic.php?f=16&t=16730629&p=7389723)
oOoO :Tezro: oOoO
mapesdhs
Unread postby mapesdhs » Thu Jul 20, 2017 7:39 am
Old thread, but a relevant query: anyone know if the generic version of the green card (-001) would work in Fuel? I found a source, but the card doesn't have an SGI sticker on it.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
