Tezro: 4x800MHz | 8GB | V12 | DCD | DM10 | SAS | USB
Unread postby recondas » Tue Nov 23, 2010 10:54 pm
# hinv -vm
       IP53_4CPU Board: barcode NER934     part 030-1956-002 rev -C
       WS_INT_53 Board: barcode NBY982     part 030-1881-007 rev -A
      ODY128B1_2 Board: barcode NNB535     part 030-1884-005 rev -B
             IO9 Board: barcode NFW612     part 030-1771-005 rev -A
4 800 MHZ IP35 Processors
CPU 0 at Module 001c01/Slot 0/Slice A: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 1 at Module 001c01/Slot 0/Slice B: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 800 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 8192 Mbytes
Integral SCSI controller 5: Version LS1030, low voltage differential
Integral SCSI controller 6: Version LS1030, low voltage differential
Integral SCSI controller 3: Version SAS/SATA LS1064
Integral SCSI controller 4: Version IEEE1394 SBP2
  Disk drive / removable media: unit 2 on SCSI controller 4
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: V12
  PCI Adapter ID (vendor 0x1000, device 0x0050) PCI slot 1
  PCI Adapter ID (vendor 0x1033, device 0x0035) PCI slot 1
  PCI Adapter ID (vendor 0x1033, device 0x00e0) PCI slot 1
  PCI Adapter ID (vendor 0x104c, device 0xac28) PCI slot 2
  PCI Adapter ID (vendor 0x104c, device 0x8024) PCI slot 2
IOC4 firmware revision 79
Dual Channel Display
USB controller: type OHCI
# /usr/gfx/gfxinfo -v
        Managed (":0.0") 3200x1200
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
        Dual Channel Display option
         Monitor 1 type: Unknown         Monitor 2 type: Unknown
         Video Output: 1600 pixels, 1200 lines, 60.00Hz (2@1600x1200_60_ds)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
        Channel 1:
         Origin = (1600,0)
         Sync Disabled
         Using Gamma Map 0
# l1cmd serial all
Local System Serial Number      NVRAM         P10003xx
Reference System Serial Number  NVRAM         P10003xx
Local Brick Serial Number       EEPROM        NBY982
Reference Brick Serial Number   NVRAM         NBY982
INTERFACE   WS_INT_53       NBY982         030_1881_007          A    00
IO9         IO9             NFW612         030_1771_005          A    00
ODYSSEY     ODY128B1_2      NNB535         030_1884_005          B    00
NODE        IP53_4CPU       NER934         030_1956_002          C    00
IO DGHTR    CHWS_IO_DAUG    NEB185         030_1875_003          A    00
DIMM 0     CE000000000000000CA3E100 M3 46L2820ET3-CA0   3E   10.0  N/A
DIMM 2     CE000000000000000C9BE100 M3 46L2820ET3-CA0   3E   10.0  N/A
DIMM 4     CE000000000000000CDE4800 M3 46L2820BT2-CA0   2B   10.0  N/A
DIMM 6     CE000000000000000CE64200 M3 46L2820BT2-CA0   2B   10.0  N/A
DIMM 1     CE000000000000000C97E100 M3 46L2820ET3-CA0   3E   10.0  N/A
DIMM 3     CE000000000000000C8BE100 M3 46L2820ET3-CA0   3E   10.0  N/A
DIMM 5     CE000000000000000CF04200 M3 46L2820BT2-CA0   2B   10.0  N/A
DIMM 7     CE000000000000000CE64800 M3 46L2820BT2-CA0   2B   10.0  N/A
# l1cmd env
          1.8V    Enabled  10%   1.62/  1.98  20%   1.44/  2.16    1.791
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.063
        12V #2    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.188
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.337
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.509
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.063
        5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.268
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
  XIO 12V BIAS    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.457
  XIO 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
 IP53 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
   IP53 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      IP53 12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.063
     IP53 SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.483
     IP53 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.480
     IP53 VCPU    Enabled  10%   1.13/  1.38  20%   1.00/  1.50    1.241
FAN  0   NODE 1    Enabled         1800         2096
FAN  1   NODE 2    Enabled         1800         2096
FAN  2   NODE 3    Enabled         1800         2163
FAN  3    PCI 1    Enabled         1350         1486
FAN  4    PCI 2    Enabled         1350         1493
FAN  5       HD    Enabled         1620         3308
FAN  6    ODY 1    Enabled         1350         1704
FAN  7    ODY 2    Enabled         1350         1607
 0 INTERFACE 0       Enabled    [Autofan Control]    76C/168F   35C/ 95F
 1 INTERFACE 1       Enabled    [Autofan Control]    76C/168F   32C/ 88F
 2 INTERFACE 2       Enabled    [Autofan Control]    76C/168F   30C/ 86F
 3 INTERFACE 3       Enabled    [Autofan Control]    76C/168F   42C/107F
 4 ODYSSEY           Enabled    [Autofan Control]    76C/168F   50C/122F
 5 NODE              Enabled    [Autofan Control]    76C/168F   46C/114F
 6 BEDROCK           Enabled    [Autofan Control]    85C/185F   47C/116F
                     Zone Temp     Target    Current   Zone Fan   Curr/Min
Zone Name  State     Sensors       Average   Average   Index      Fan %
Node        Enabled           5,6  62C/143F  46C/114F          0   46%/ 46%
PCI         Enabled       0,1,2,3  45C/113F  36C/ 96F        3,4   57%/ 57%
ODY         Enabled             4  50C/122F  50C/122F          6   65%/ 61%
HD          Enabled             5  40C/104F  44C/112F          5   52%/ 38%
# l1cmd flash status
Flash image A currently booted
Image      Status        Revision    Built
  A     default         1.48.1       01/22/2007 11:34:34
  B     valid           1.32.6       09/27/2004 14:40:25
# 1cmd pci
Bus Slot Slot Stat Bus Stat  Power Mode/Speed
  1    1 0x80 0x01      0x04   15W PCI  66MHz
  2    1 0x00 0x0f      0x42  none PCI  33MHz
  2    2 0x00 0x00      0x42  7.5W PCI  33MHz
  2    3 0x00 0x0f      0x42  none PCI  33MHz
  3    1 0x00 0x01      0x00   15W PCI  33MHz
  3    2 0x00 0x0f      0x00  none PCI  33MHz
  4    1 0x00 0x0c      0x6c  7.5W PCIX 133MHz
  4    2 0x00 0x0f      0x6c  none PCIX 133MHz
# topology -t
Machine tezro.null.com has:
4 cpu's
1 memory nodes
The cpus are:
cpu 0 is /hw/module/001c01/node/cpubus/0/a
cpu 1 is /hw/module/001c01/node/cpubus/0/b
cpu 2 is /hw/module/001c01/node/cpubus/1/a
cpu 3 is /hw/module/001c01/node/cpubus/1/b
The nodes are:
node 0 is /hw/module/001c01/node [Tezro]
The topology is defined by:
/hw/module/001c01/node/xtalk/0/link -> /hw/module/001c01/IXbrick
A few photos - some have said they don't care for the tower Tezro's case design, and I wonder if that partially due to the fact most photos are taken head-on. Now that I've seen one in person, I don't think most photos accurately depict the visual strength of the design. I found the Tezro's most striking feature to be it's proportions - particularly the less often seen profile:
Sitting on an SGI short-rack - Fuel in the foreground.
Multi-processor versions of the Tezro have 8 PCI slots (the single processor version only 4). The mandatory main I/O controller board (IO9) occupies the first PCI slot (towards the top of the case). The IO9 is essential for proper system operation, leaving 7 expansion PCI slots. The power supply is to the top left, DVD drive to the right. The DVD drive is an IDE/ATAPI Matsushita SR-8588-C. The vertical black object to the right is the fan wall that holds fans to cool PCI expansion boards and the V12 graphics board. The V12 is located below the PCI slots inside the rectangular metal cooling shroud. Between the top of the V12 cooling shroud and the bottom PCI slot is an XIO2 connection header for the optional DM3 HD video capture board.
The Processor node board. The processors are under the perforated metal box/shroud. The diagram on the shroud shows four processors, but that's not a reliable indicator of the actual number. Dual and quad processor Tezros up to 800MHz use the same shroud, the shroud over 1GHz processors is taller to accommodate larger heat sinks (there wasn't a 900MHz Tezro processor). At the top left is the hard drive bay with SCA backplane - it will accommodate two low profile SCSI hard drives. At the top right is the I/O daughter card. The red arrow indicates the position of the node board part number label - the most reliable method to determine type and number of processors installed .
Just in case you ever need to tell an eBay seller where to find the part number so you figure out which and how many processors are in the system or node board he's selling.
PymbleSoftware
Re: Tezro: 4x800MHz | 6GB | V12 | DCD | DM10 | SAS
Unread postby PymbleSoftware » Wed Nov 24, 2010 12:43 am
Let me congratulate you and again express my envy
R.
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
Unread postby recondas » Wed Nov 24, 2010 10:01 am
Looks like the 800MHZ nodes generate a little more heat. After a few hours of run time I noticed the temps reported by an 'L1 env' were several degrees C warmer than these nekonoko posted for his Tezro.
To make the comparison a little more balanced I ran the 800MHz Tezro overnight with the same amount of RAM and number of PCI boards as nekonoko's Tezro <though I'm clearly short of whatever heat nekonoko's DM3 generates>. Here's the fan and temperature portion of nekonoko's Tezro:
FAN  0   NODE 1    Enabled         1800         2205
FAN  1   NODE 2    Enabled         1800         2235
FAN  2   NODE 3    Enabled         1800         2205
FAN  3    PCI 1    Enabled         1350         1527
FAN  4    PCI 2    Enabled         1350         1555
FAN  5       HD    Enabled         1620         2812
FAN  6    ODY 1     Active         1299         1814
FAN  7    ODY 2     Active         1299         1748
1 INTERFACE 1       Enabled    [Autofan Control]    76C/168F   31C/ 87F
2 INTERFACE 2       Enabled    [Autofan Control]    76C/168F   33C/ 91F
3 INTERFACE 3       Enabled    [Autofan Control]    76C/168F   37C/ 98F
5 NODE              Enabled    [Autofan Control]    76C/168F   45C/113F
PCI         Enabled       0,1,2,3  45C/113F  34C/ 93F        3,4   57%/ 57%
ODY         Enabled             4  50C/122F  50C/122F          6   67%/ 64%
HD          Enabled             5  40C/104F  45C/113F          5   52%/ 38%
and the same section of the 800MHz Tezro <with approximately 8-hours of run time>:
FAN  0   NODE 1    Enabled         1800         2109
FAN  1   NODE 2    Enabled         1800         2109
FAN  3    PCI 1    Enabled         1350         1513
FAN  4    PCI 2    Enabled         1350         1520
FAN  5       HD    Enabled         1620         3183
FAN  6    ODY 1    Enabled         1350         1767
FAN  7    ODY 2    Enabled         1350         1662
 0 INTERFACE 0       Enabled    [Autofan Control]    76C/168F   38C/100F
 1 INTERFACE 1       Enabled    [Autofan Control]    76C/168F   34C/ 93F
 3 INTERFACE 3       Enabled    [Autofan Control]    76C/168F   41C/105F
 5 NODE              Enabled    [Autofan Control]    76C/168F   48C/118F
 6 BEDROCK           Enabled    [Autofan Control]    85C/185F   53C/127F
Node        Enabled           5,6  62C/143F  50C/122F          0   46%/ 46%
PCI         Enabled       0,1,2,3  45C/113F  35C/ 95F        3,4   57%/ 57%
ODY         Enabled             4  50C/122F  50C/122F          6   67%/ 61%
HD          Enabled             5  40C/104F  48C/118F          5   61%/ 38%
If the temperature increases were anywhere near proportional to the speed increases of the R16 processor, it's easy to see why SGI more than doubled the size of the heatsinks on the 1GHz IP53 node boards <though I'm sure adding another 12MB of processor scache played into that too>.
fu
Unread postby fu » Thu Nov 25, 2010 12:45 pm
congratulations dave :)
nice to hear about its noise levels too, i've been wondering how much of a noisemaker the tez is
Unread postby recondas » Fri Nov 26, 2010 11:24 am
Thanks fu!
~ Added a couple of exterior shots to the photos in the hinv post.
Unread postby recondas » Tue Dec 07, 2010 6:20 am
While cleaning and setting up my Tezro I noticed I could lower the ambient operating temperatures of the processor nodes, bedrock ASIC and V12 5C to 7C simply by leaving the front skin off of the Tezro. As a result I decided to take a look at what could be easily done to lower the overall long-term operating temperatures with the full set of skins installed. My initial concern was the V12. There have a been a few posts on nekochan by Tezro owners that suggest their V12 died <I say suggest because none included a follow up>, and I wondered if those failures might be heat related <especially since the Fuel and O350/V12 report significantly lower operating temps for their V12s>. Might be only a coincidence, but I also noticed SGI included an <unused> three-pin fan header on the Tezro version of the V12 that isn't present on the Fuel version of the V12.
As a test I installed a low-rpm/low decibel 80mm fan on top of the metal shroud that encloses the V12, using the perforations in the shroud as attachment points for the rubber anti-vibration fan mounts.The fan is positioned directly above and blows air onto the V12 heatsink. The result was a 10C/18F reduction in the temperature the L1 reports for the V12. I don't have a DM3 installed - a Tezro with a DM3 would have a limited amount space to install a fan using this method, though there looks to be sufficient room to attach a radial fan to the underside of the V12 shroud <laterally positioned between the heatsink and bulkhead>, with the fan exhaust directed at the bulkhead.
Emboldened by the success, I took a look at the bedrock and node temps reported by the L1. The 1GHz versions of the Tezro include three 60mm fans positioned just to the front side of the node board cooling shroud. There's more than enough room to install fans in that same location. I didn't have any 60mm fans <nor did any of the sources local to me>, but I did have two 38mm fans pre-wired in a two-fan array with a molex-splitter power attachment. For initial testing I zip-tied the 38mm fans to the perforated metal shielding, directly in front and blowing onto the perforations in the node board cooling shroud, and made an air duct so that air was directed into the openings in the node board shroud <rather than the dead air space above the shroud. The molex splitter was connected at the <molex> power feed for the hard drive backplane <located directly above the node board>. The 38mm fans are only rated at 4.5CFM each <I plan to order three 12CFM-each low-DBA 60mm fans as replacements>, but made a noticeable 6C/11F drop in the operating temperature of the bedrock a ASIC. Here's the output of an L1 env run after 24 hours of continuous runtime and several hours of heavy use:
FAN  1   NODE 2    Enabled         1800         2083
FAN  2   NODE 3    Enabled         1800         2149
FAN  3    PCI 1    Enabled         1350         1534
FAN  4    PCI 2    Enabled         1350         1548
FAN  5       HD    Enabled         1620         2721
FAN  6    ODY 1    Enabled         1350         1555
FAN  7    ODY 2    Enabled         1350         1461
 0 INTERFACE 0       Enabled    [Autofan Control]    76C/168F   36C/ 96F
 2 INTERFACE 2       Enabled    [Autofan Control]    76C/168F   28C/ 82F
 3 INTERFACE 3       Enabled    [Autofan Control]    76C/168F   39C/102F
 4 ODYSSEY           Enabled    [Autofan Control]    76C/168F   40C/104F
Node        Enabled           5,6  62C/143F  45C/113F          0   46%/ 46%
PCI         Enabled       0,1,2,3  45C/113F  33C/ 91F        3,4   57%/ 57%
ODY         Enabled             4  50C/122F  40C/104F          6   61%/ 61%
and for comparison, the same L1 environmental data taken before adding the fans:
The "HD" temp reported in the table appears to actually the node temp , scsimon actually reports the hard drive temp as 29C. SGI probably intended for the HD fan to assist in cooling the node board <the HD fan pulls air across the hard drives and blows air onto the RAM end of the node board>.
Tabalabs
Re: Tezro: 4x800MHz | 6GB | V12 | DCD | DM10 | SAS | USB
Unread postby Tabalabs » Tue Dec 07, 2010 7:58 am
Quick tip:
Hot ar is less dense than cold air, that's why baloons go up :) So, if you put a fan on TOP of anything, make it PULLING air and not BLOWING. It will have a higher CFM if you keep the normal flux of air.
THE dream come true: Silicon Graphics' Octane
Image Octane R10000 225MHz, 2GB RAM, 1x36GB HDs, 21" monitor, SSI (no TRAM) graphics
:Indy: Indy R5000 (specs to be determined)
Unread postby recondas » Tue Dec 07, 2010 8:34 am
Tabalabs wrote:Quick tip:
I considered that, but in this case pulling air up from the heatsink would disrupt the front to rear air flow of the V12's existing fans - as well as dump hot air into the PCI card cage rather than out the exhaust vents in the chassis for the V12.
Not to mention that blowing air across the cooling fins on the heatsink isn't uncommon behavior for CPU and GPU cooling fans.
Unread postby recondas » Thu Dec 16, 2010 11:44 am
Got around to installing the DM10 drivers, and connected a firewire memory card reader. Just in case someone else might find a walk through of the process helpful, here's a summary.
The pseudo-DM10 is a generic firewire 3-port PCI board (two external, one internal FW ports with a TI chipset), the firewire memory card reader is a Microtech CameraMate. The compact flash memory card used is a 1GB SanDisk and the IRIX version is 6.5.30.
Installing the DM10 drivers requires a reboot (the kernel is rebuilt). As the system rebooted the following appeared in the boot messages (and was written to the syslog):
unix: Scanning FireWire bus /hw/module/001c01/IXbrick/xtalk/15/pci-x/1/2/ohci/0 (1 node)
unix: FireWire Node [0]: <6>OXFORD SEMICONDUCTOR LTD., OXFORD IDE Device
unix: NOTICE: IEEE1394 SBP2 Target with GUID 0x30e00100001419 has firmware rev 0x120
When the system booted the following was included in an hinv -vm:
fwprobe (supplied with the DM10 driver package) returned the following info: Addendum - I later installed the DMediaPro D10 version 1.1 *beta*, which despite being a beta, seems to offer some improvements. fwprobe now fully identifies the generic FW board as a DM10. With DM10 version 1.0.1 the 'Model' and 'Proto' fields were both listed as unknown, after installing the DM10 1.1 beta version, fwprobe now identifies the pseudo-DM10 Model as 'DMediaPro DM10' and Proto as 'HBA', and it eliminated boot-time error messages that occurred as the 1.0.1 release scanned the FW bus:
# fwprobe
Probing DM10 cards...
Number of cards: 1
Card Info
Card #: 0
Ports : 3
Speed : 400 / 400
2 devices attached
Device 0: 0x5160000030E0A
  Vendor: Silicon Graphics, Inc.
   Model: DMediaPro DM10
   Proto: HBA
Device 1: 0x30E00100001419
  Vendor: OXFORD SEMICONDUCTOR LTD.
   Model: OXFORD IDE Device
   Proto: SBP2
and the 'versions' command reported:
# versions dm10
I = Installed, R = Removed
   Name                 Date        Description
I  dm10                 12/18/2010  DMediaPro DM10 Execution Environment, 1.1 for IRIX 6.5
I  dm10.man             12/18/2010  DMediaPro DM10 Man Pages
I  dm10.man.pages       12/18/2010  DMediaPro DM10 Man Pages
I  dm10.man.relnotes    12/18/2010  DMediaPro DM10 Release Notes
I  dm10.sw              12/18/2010  DMediaPro DM10 Software
I  dm10.sw.eoe          12/18/2010  DMediaPro DM10 Execution Environment
I  dm10.sw.tools        12/18/2010  DMediaPro DM10 Tools
There was an entry for the compact flash card under /hw/rdisk/1394 (the specific identification string, "30e00100001419", will be different on every system). I was able to manually mount the compact flash card that was in the card reader using:
# mount -t dos -o partition=1 /hw/rdisk/1394/30e00100001419/lun0vol/c4p0 /usr/FW/
and access the contents of the compact flash card:
# ls /usr/FW/dcim/288canon/
crw_8802.crw  crw_8805.jpg  crw_8809.jpg  crw_8813.jpg  crw_8817.jpg  crw_8821.jpg  crw_8825.jpg  crw_8829.jpg
crw_8802.jpg  crw_8806.crw  crw_8810.crw  crw_8814.crw  crw_8818.crw  crw_8822.crw  crw_8826.crw  crw_8830.crw
crw_8802.xmp  crw_8806.jpg  crw_8810.jpg  crw_8814.jpg  crw_8818.jpg  crw_8822.jpg  crw_8826.jpg  crw_8830.jpg
crw_8803.crw  crw_8807.crw  crw_8811.crw  crw_8815.crw  crw_8819.crw  crw_8823.crw  crw_8827.crw
crw_8803.jpg  crw_8807.jpg  crw_8811.jpg  crw_8815.jpg  crw_8819.jpg  crw_8823.jpg  crw_8827.jpg
crw_8804.crw  crw_8808.crw  crw_8812.crw  crw_8816.crw  crw_8820.crw  crw_8824.crw  crw_8828.crw
crw_8804.jpg  crw_8808.jpg  crw_8812.jpg  crw_8816.jpg  crw_8820.jpg  crw_8824.jpg  crw_8828.jpg
and was able to open, edit and save one of the jpg files (back onto the CF card). It's worth noting the IRIX mounts of "DOS" file systems didn't progress beyond FAT16, which means using 2GB cards or smaller.
Was also able to hot-swap the compact flash card by unmounting the CF card with (use caution with my version of this command if you have more than one dos file system mounted),
# umount -t dos
then inserted a different CF card and successfully mounted and accessed the second CF card (using a repeat of the mount command from above).
The Microtech CameraMate has a single compact flash slot, I was able to mount a 2GB SD card using a CF-to-SD adapter.
I've also done some preliminary testing with a an external firewire hard drive. fx is able to 'see' the 250GB hard drive installed in the enclosure (the enclosure uses an Initio chipset rather than the Oxford chipset that has worked for others), but I haven't attempted to put a xfs file system on the drive (it currently holds the TimeMachine backup for one of my Macs). As soon as I pick up another PATA hard drive to install in the enclosure I'll try fx and report back.
Unread postby foetz » Fri Dec 24, 2010 6:40 pm
PymbleSoftware wrote:Let me congratulate you and again express my envy
R.
same here :D
very nice machine and pics! and as i can see you've put the usual work into it ... only the card reader makes me feel odd somehow :lol:
i'm sure you'll have your fun with it :)
Unread postby recondas » Sun Dec 26, 2010 10:28 pm
foetz wrote:very nice machine and pics! and as i can see you've put the usual work into it Thanks!
foetz wrote: only the card reader makes me feel odd somehow :lol:
When you like to play with Tezros and DSLRs, an IRIX supported memory card reader is a nice way to combine interests.
Unread postby foetz » Sat Jan 01, 2011 6:28 am
recondas wrote:When you like to play with Tezros and DSLRs, an IRIX supported memory card reader is a nice way to combine interests.
of course, wasn't totally serious :D
as i said much fun and a long happy life for the tezro :)
Re: Tezro: 4x800MHz | 8GB | V12 | DCD | DM10 | SAS | USB
Unread postby recondas » Mon Nov 07, 2011 1:08 pm
Updated gfxinfo to include the change to a 3200x1200_60 desktop:
Unread postby hamei » Mon Nov 07, 2011 4:54 pm
recondas wrote:Updated gfxinfo to include the change to a 3200x1200_60 desktop:
Huh ? Is this a twoie desktop with the dcd ? What single monitor can you run at 3200 x 1200 ?
Unread postby recondas » Mon Nov 07, 2011 6:11 pm
hamei wrote:Huh ? Is this a twoie desktop with the dcd ?
Exactly.
I didn't quote the entire gfxinfo section that was updated (since the entire update is included in the original post) - it's two ViewSonic VP2039b LCD panels in an Ergotron mount.
