Onyx2 4x400MHz 4.6 GB RAM, IR2
pablodiablo
Unread postby pablodiablo » Sun Nov 21, 2010 8:00 am
My upgraded machine - base for Inferno System
IRIS 7# hinv -vm
            IP31 Board: barcode LAM658     part 030-1523-001 rev  C
   IP31PIMMR12KS Board: barcode LAM440     part 030-1423-002 rev  G
        MODULEID Board: barcode K0005444   part              rev
      4P1G5_MPLN Board: barcode LZG106     part 030-1066-002 rev  L
            IP31 Board: barcode KRL430     part 030-1523-001 rev  C
   IP31PIMMR12KS Board: barcode KRK643     part 030-1423-002 rev  G
          GE16-4 Board: barcode GMX309     part 030-1398-001 rev  A
         PCI_XIO Board: barcode GSC581     part 030-1062-002 rev  D
            DIVO Board: barcode MHF886     part 030-1305-005 rev  A
       XT-DIGVID Board: barcode MMB191     part 030-1653-002 rev  H
           HDTV1 Board: barcode MFM499     part 030-1282-002 rev  F
    HDTV_GENLOCK Board: barcode MFM342     part 030-1382-004 rev  D
             MIO Board: barcode LKJ937     part 030-0880-003 rev  G
          BASEIO Board: barcode LKX975     part 030-0734-003 rev  A
4 400 MHZ IP27 Processors
FPU: MIPS R12010 Floating Point Chip Revision: 3.5
CPU 0 at Module 1/Slot 2/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 3.5. Scache: Size 8 MB Speed 266 Mhz  Tap 0xa
CPU 1 at Module 1/Slot 2/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 1/Slot 1/Slice A: 400 Mhz MIPS R12000 Processor Chip (enabled)
CPU 3 at Module 1/Slot 1/Slice B: 400 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 4608 Mbytes
Memory at Module 1/Slot 82: 2048 MB (enabled)
  Bank 0 contains 256 MB (Standard) DIMMS (enabled)
  Bank 1 contains 256 MB (Standard) DIMMS (enabled)
  Bank 2 contains 256 MB (Standard) DIMMS (enabled)
  Bank 3 contains 256 MB (Standard) DIMMS (enabled)
  Bank 4 contains 256 MB (Standard) DIMMS (enabled)
  Bank 5 contains 256 MB (Standard) DIMMS (enabled)
  Bank 6 contains 256 MB (Standard) DIMMS (enabled)
  Bank 7 contains 256 MB (Standard) DIMMS (enabled)
Memory at Module 1/Slot 81: 2560 MB (enabled)
Integral SCSI controller 2: Version Fibre Channel QL2342 Port 1, 33 MHz PCI
Integral SCSI controller 3: Version Fibre Channel QL2342 Port 2, 33 MHz PCI
Integral SCSI controller 4: Version Fibre Channel QL2342 Port 1, 33 MHz PCI
Integral SCSI controller 5: Version Fibre Channel QL2342 Port 2, 33 MHz PCI
  Disk drive: unit 32 on SCSI controller 5 (unit 32)
  Disk drive: unit 33 on SCSI controller 5 (unit 33)
  Disk drive: unit 34 on SCSI controller 5 (unit 34)
  Disk drive: unit 35 on SCSI controller 5 (unit 35)
  Disk drive: unit 36 on SCSI controller 5 (unit 36)
  Disk drive: unit 37 on SCSI controller 5 (unit 37)
  Disk drive: unit 38 on SCSI controller 5 (unit 38)
  Disk drive: unit 39 on SCSI controller 5 (unit 39)
  Disk drive: unit 40 on SCSI controller 5 (unit 40)
  Disk drive: unit 41 on SCSI controller 5 (unit 41)
  Disk drive: unit 42 on SCSI controller 5 (unit 42)
  Disk drive: unit 43 on SCSI controller 5 (unit 43)
  Disk drive: unit 44 on SCSI controller 5 (unit 44)
  Disk drive: unit 45 on SCSI controller 5 (unit 45)
Integral SCSI controller 6: Version Fibre Channel QL2342 Port 1, 33 MHz PCI
  Disk drive: unit 5 on SCSI controller 0 (unit 5)
Integral SCSI controller 7: Version Fibre Channel QL2342 Port 2, 33 MHz PCI
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: InfiniteReality2E
Iris Audio Processor: version RAD revision 7.0, number 1
Origin PCI XIO board, module 1 slot 2: Revision 3
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 0
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 1
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 2
  PCI Adapter ID (vendor 0x10a9, device 0x0002) PCI slot 0
  PCI Adapter ID (vendor 0x10a9, device 0x0002) PCI slot 2
Origin BASEIO board, module 1 slot 1: Revision 4
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 6
  PCI Adapter ID (vendor 0x10a9, device 0x0005) PCI slot 7
XT-HDIO Video: controller 0, unit 0, version 0x0
HUB in Module 1/Slot 2: Revision 6 Speed 100.00 Mhz (enabled)
HUB in Module 1/Slot 1: Revision 6 Speed 100.00 Mhz (enabled)
IO6prom on Global Master Baseio in Module 1/Slot io2: Revision 6.156
/usr/gfx/gfxinfo
        Display has 2 channels
        4 GEs (of 4), occmask = 0x0f
        2 RM9 boards (of 2) 1/1/0/0
        Texture Memory: 64MB/64MB/-/-
        Large pixel depth
        32K cmap
        TVO option detected
:Onyx2: :Onyx2: :Octane2: :Indigo2IMP:
pablodiablo
Re: Onyx2 4x400MHz 4.6 GB RAM, IR2
Unread postby pablodiablo » Sun Nov 21, 2010 8:03 am
Can anyone yell me what this red code is for, I suspect some problems here...
NOTICE: XT-HD: /hw/module/1/slot/io3/hdtv1: removing HUB 636960 IVACK workaround
XT-HD: see /var/sysgen/mtune/xthd to override
NOTICE: XT-DIGVID: /hw/module/1/slot/io5/xt_digvid: removing HUB 636960 IVACK workaround
XT-DIGVID: see /var/sysgen/mtune/xtdigvid to override
NOTICE: Starting failsoftd
dksc0d5vol: Recovered Error: Self Diagnostics predict unit will fail soon (asc=0x5d, asq=0x0)
It comes from the booting console output below:
IP27 PROM SGI Version 6.156  built 11:27:56 AM Nov 18, 2003
Discovering local IO ......................
Found an io Board with nic 030-1305-005.
DONE
Discovering NUMAlink connectivity .........             DONE
Found 2 objects (2 hubs, 0 routers) in 10466 usec
Global master is /hw/module/1/slot/n2                                      Testing/Initializing all memory ...........         DONE
waiting for node with nic 401ec2 at module 1 slot 1 at global barrier...........        Checking partitioning information .........              DONE                  Loading BASEIO prom .......................              DONE
BASEIO PROM Monitor SGI Version 6.156  built 11:26:28 AM Nov 18, 2003 (BE64)
4 CPUs on 2 nodes found.
Walking SCSI Adapter 0 (/hw/module/1/slot/io1), (pci id 0)
1+ 2- 3- 4- 5+ 6- 7- 8- 9- 10- 11- 12- 13- 14- 15- = 2 device(s)
Walking SCSI Adapter 1 (/hw/module/1/slot/io1), (pci id 1)
Cannot connect to keyboard -- check the cable.
Cannot open /dev/input/ioc3pckm0 for input
Checking hardware inventory ...............
***Warning: Found a different board in module 1, slot n2,
Previous barcode was K0005444, New barcode is LAM658
***Warning: Found a new  board in module 1, slot io3, serial MFM499
Please use the 'update' command from the PROM Monitor to update the inventory
***Warning: Found a new IP27 board in module 1, slot n1, serial K0005444
DONE
**** System Configuration and Diagnostics Summary ****
CONFIG:
         No. of NODEs enabled    = 2
         No. of NODEs disabled   = 0
         No. of CPUs enabled     = 4
         No. of CPUs disabled    = 0
         Mem enabled             = 4608 MB
         Mem disabled            = 0 MB
         No. of RTRs enabled     = 0
         No. of RTRs disabled    = 0
DIAG RESULTS:
         ALL DIAGS PASSED.
System Maintenance Menu
1) Start System
2) Install System Software
3) Run Diagnostics
4) Recover System
5) Enter Command Monitor
Option? 5
Command Monitor.  Type "exit" to return to the menu.
>> exit
1) Start System
3) Run Diagnostics
4) Recover System
Option? 1
                           Starting up the system...
IRIX Release 6.5 IP27 Version 07010238 System V - 64 Bit
Copyright 1987-2005 Silicon Graphics, Inc.
Setting rbaud to 19200
/hw/module/1/slot/io2/pci_xio/pci/0a/scsi_ctlr/0: Firmware version: 3.3.6: TP.
/hw/module/1/slot/io2/pci_xio/pci/0b/scsi_ctlr/0: Firmware version: 3.3.6: TP.
/hw/module/1/slot/io2/pci_xio/pci/1a/scsi_ctlr/0: Firmware version: 3.3.6: TP.
/hw/module/1/slot/io2/pci_xio/pci/1b/scsi_ctlr/0: Firmware version: 3.3.6: TP.
/hw/module/1/slot/io2/pci_xio/pci/2a/scsi_ctlr/0: Firmware version: 3.3.6: TP.
/hw/module/1/slot/io2/pci_xio/pci/2b/scsi_ctlr/0: Firmware version: 3.3.6: TP.
/hw/module/1/slot/io2/pci_xio/pci/1b/scsi_ctlr/0: 14 FCP targets.
/hw/module/1/slot/io2/pci_xio/pci/0a/scsi_ctlr/0: no cable detected.
/hw/module/1/slot/io2/pci_xio/pci/0b/scsi_ctlr/0: no cable detected.
/hw/module/1/slot/io2/pci_xio/pci/1a/scsi_ctlr/0: no cable detected.
/hw/module/1/slot/io2/pci_xio/pci/2a/scsi_ctlr/0: no cable detected.
/hw/module/1/slot/io2/pci_xio/pci/2b/scsi_ctlr/0: no cable detected.
The system is coming up.
Starting new eventmond...
No System change detected.
IR0: ARM: Welcome to ARMLand - 0/0x0d00
IR0: ARM: running...(sherwood-root 0507010047)
IR0: ARM: ******************************************************
IR0: ARM: * InfiniteReality/Reality Software, IRIX 6.5 release *
IRIS console login: IR0: GE2: Welcome to GELand!
IR0: GE3: Welcome to GELand!
IR0: GE0: Welcome to GELand!
IR0: GE1: Welcome to GELand!
Unread postby jan-jaap » Sun Nov 21, 2010 11:40 am
pablodiablo wrote:Can anyone yell me what this red code is for, I suspect some problems here...
- disk 5 in the internal disk bay is about to fail. backup and replace it.
- I remember that XT-HD needs a fairly new HUB chip on the IP31 board. I think those should be on the 400 and 500MHz node boards. Yours have fairly new serial numbers so I don't think this affects you. I don't know much about XT-HD I'm afraid ...
Nice Onyx2. Onyx2 is a beautiful system :)
