Origin 350, 8xR16K 700MHz, 16GB RAM, SAS3041X-R, 4TB disk
Re: Origin 350, 8xR16K 700MHz, 16GB RAM, SAS3041X-R, 4TB dis
Unread postby jan-jaap » Tue Apr 12, 2011 3:39 am
Found an affordable 147GB Seagate 15K.5 to replace the 73GB 15K.3 system disk:
speedo 6# diskperf -W -D -n "Seagate 15K.5 ST3146855LC" /tmp/junk
# Disk Performance Test Results Generated By Diskperf V1.2
# Test name     : Seagate 15K.5 ST3146855LC
# Test date     : Tue Apr 12 10:14:06 2011
# Test machine  : IRIX64 speedo 6.5 07202013 IP35
# Test type     : XFS data subvolume
# Test path     : /tmp/junk
# Request sizes : min=16384 max=16777216
# Parameters    : direct=1 time=10 scale=1.000 delay=0.000
# XFS file size : 1334837248 bytes
      16384   62.07   66.62   35.24    9.52   10.02    4.66
      32768   87.24   92.08   58.06   20.17   18.27    8.77
      65536  108.70  112.41   82.84   29.20   32.74   15.43
     131072  125.60  127.85  105.22   42.91   49.16   25.51
     262144  133.23  134.14  103.35   43.14   65.49   37.95
     524288  133.11  134.05   69.45   48.13   70.08   49.63
    1048576  133.24  134.07   87.46   64.42   92.10   58.71
    2097152  133.38  133.86  105.76   85.87  108.15   84.13
    4194304  133.08  129.22  126.07  112.45  118.59  107.74
    8388608  132.15  112.59  127.00  113.20  125.83  112.33
   16777216  128.94  115.45  130.27  113.94  129.32  114.11
The dip in bwd_wt at 512K/1024K is reproducible, but it's still a nice improvement :)
Unread postby jan-jaap » Mon Sep 19, 2011 4:06 am
Updated the IO9 firmware.
We have seen a fair number of ethernet adapters fail here, so I'm now using a modded OEM (HP/Compaq) 'tg' card, rather than waiting for my IO9 to suffer a mysterious death.
Unread postby jan-jaap » Tue Nov 15, 2011 5:31 am
Added L2 controller. It came without power adapter, but thanks to this post by Recondas, that problem was quickly solved.
I'm using THIS power adapter. I had to order the DD50 connector in (multiples of) qty 10, and the backshell in qty 5. If someone wants to repeat this exercise, you can have a connector + backshell for 5€ + shipping.
Re: Origin 350, 8xR16K 700MHz, 16GB RAM, SAS3041X-R, 4TB disk
Unread postby jan-jaap » Fri Nov 25, 2016 2:39 am
Was greeted with this a couple of days ago:
Nov 21 10:01:03 6A:speedo unix: dksc5d1vol: [Alert] Media error: Unrecovered data block read error (asc=0x11, asq=0x0), Block #18446744073139073539
Nov 21 10:01:03 6A:speedo unix: dksc5d1vol:   retrying request
Nov 21 10:01:03 6A:speedo unix: |$(3)<6>dksc5d1vol: I/O error, retries exhausted
Nov 21 10:01:03 4A:speedo unix: WARNING: XVM: READ I/O error - errno=5 dev=0xf7 bp=0xa8000000acb61c80 flags=0xd addr=0xa800000093a3dc00 pages=0x0 blkno=0xddff3203, ior=0xa8000000acb61080 io_flags=0x4001 io_resid=0x0 io_error=0xa8000002be030001
Nov 21 10:01:03 1A:speedo unix: ALERT: I/O error in filesystem ("/xvm0") meta-data dev 0x430012d block 0x1bbfe4403
Nov 21 10:01:03 2A:speedo unix:        ("xfs_trans_read_buf") b_error 5 b_bcount 512 b_resid 0
Nov 21 10:01:03 5A:speedo unix: NOTICE: xfs_force_shutdown(/xvm0,0x8) called from line 6143 of file ../fs/xfs/xfs_rw.c.  Return address = 0xc000000000384718
Nov 21 10:01:03 1A:speedo unix: ALERT: Filesystem "/xvm0": |$(3721)Corruption of in-memory data detected.  Shutting down filesystem: /xvm0
Nov 21 10:01:03 1A:speedo unix: ALERT: Please umount the filesystem, and rectify the problem(s)
One of the SATA disks gave up after running 24/7 for 6 years straight (this system had not been rebooted in over a year).
I had a spare disk, but this was a stripe so now I'm reloading 3.5TB of data from backups ...
Unread postby dexter1 » Fri Nov 25, 2016 8:09 am
I hope this is not ruining your weekend, Jan-Jaap?
Unread postby jan-jaap » Mon Nov 28, 2016 1:12 am
dexter1 wrote:I hope this is not ruining your weekend, Jan-Jaap?
Nope :D
While this system is hosted at work, I'm not crazy enough to run critical tasks on a ~ 15 year old server with striped SATA disks for storage. With proper backups it's a minor inconvenience, restore completed without hick-ups and the systems is back online.
Unread postby vishnu » Mon Nov 28, 2016 12:22 pm
I wonder if it's worth trying to port smartmontools to IRIX... :roll:
