Indigo2 R4400 250MHz, 320MB, Solid, Impact Compression
jpstewart
Unread postby jpstewart » Sun Sep 26, 2010 1:45 pm
Hello, everyone. I'm a newcomer here. Actually, I'm a long time lurker who has finally decided to come out of the shadows and join into the discussions. I used to be somewhat active in the comp.sys.sgi.* newsgroups 8-10 years ago. My Indigo2 was set aside for a number of years, but I've been playing with it again lately. (Amazingly, after five years in storage it booted up just fine!) I thought I'd introduce my Indigo2 now:
hinv -vm
CPU: MIPS R4400 Processor Chip Revision: 6.0
1 250 MHZ IP22 Processor
Main memory size: 64 Mbytes
Secondary unified instruction/data cache size: 2 Mbytes on Processor 0
Data cache size: 16 Kbytes
On-board serial ports: 2
Graphics board: Solid Impact
EISA bus: adapter 0
Graphics board 0 is "IMPACT" graphics.
   Product ID 0x1, 1 GE, 1 RE, 0 TRAMs
   VC3 rev A, CMAP rev EMC rev C
The EISA bus adapter is an E100 Fast Ethernet card. I actually have Phobos G160 sitting on my desk, but it's still in the original box (even shrink wrapped!) so I'm a little reluctant to install it.
The Indigo2 is connected to a 17 inch Samsung SyncMaster 760V LCD through a cheap 13W3<->VGA adapter.
The box came with IRIX 6.5 pre-installed when I bought it about 8 or 9 years ago. I recently downloaded and installed the 6.5.22 patchset. I should probably do a full re-install (once I get my hands on IRIX media) since I almost certainly messed up the installation in the early days before I knew much about IRIX. (I'm a Linux guy, primarily. But ever since using Solaris 2.x in the early- to mid-1990s, I've had an interest in anything Unix-y.)
I know the system desperately needs more RAM, but it's getting hard to find (and consequently rather expensive). I almost purchased an Octane recently, and have a few Octane accessories already sitting on my desk waiting for a home. So I'm not sure if I'll upgrade the RAM or not. I've heard older versions of IRIX run better with 64MB, so I may downgrade the OS instead.
I'll try to get some pictures to post.
HP C8000
Digital DECstation 5000/125
andyjpb
Re: Indigo2 R4400 250MHz, 64MB, Solid Impact
Unread postby andyjpb » Mon Sep 27, 2010 9:51 am
Hi,
jpstewart wrote:Hello, everyone. I'm a newcomer here. Actually, I'm a long time lurker who has finally decided to come out of the shadows and join into the discussions. I used to be somewhat active in the comp.sys.sgi.* newsgroups 8-10 years ago. My Indigo2 was set aside for a number of years, but I've been playing with it again lately. (Amazingly, after five years in storage it booted up just fine!) I thought I'd introduce my Indigo2 now:
Welcome (back)!
Unread postby vishnu » Mon Sep 27, 2010 3:40 pm
There are a couple of empty Octane cases for sale on Ebay these days, if you're looking for a shiny new home for your Octane parts... :mrgreen:
Southwestern Ontario, anywhere near Atikokan? :?:
jpstewart
Unread postby jpstewart » Tue Sep 28, 2010 12:27 pm
vishnu wrote:There are a couple of empty Octane cases for sale on Ebay these days, if you're looking for a shiny new home for your Octane parts... :mrgreen:
Yeah, I'm quite familiar with all the temptations eBay currently has to offer. Most of the vendors want nearly $100 to ship the $20 empty Octane case, though. I keep hoping an Octane will show up within driving distance to avoid shipping one of those beasts.
vishnu wrote:Southwestern Ontario, anywhere near Atikokan? :?:
Nope. Atikokan is Northwestern Ontario. I'm nowhere near that far north nor even that far west. "Southwestern Ontario" generally refers to the Windsor/London area (and even a little further east). The area southwest of Toronto, basically. I'm actually between Buffalo NY and Detroit MI. Atikokan is roughly 1000 miles (or 1600 km) northwest of me.
HP C8000
Unread postby vishnu » Wed Sep 29, 2010 1:42 pm
We've sent a couple hundred Octane/Octane2's to the recyclers over the past few years and none of them have shown up on the secondhand market... :cry:
Nope. Atikokan is Northwestern Ontario...
Ah! I get it, Atikokan is in the Southwestern section of the Northwestern part... :mrgreen:
Unread postby jan-jaap » Wed Sep 29, 2010 2:14 pm
jpstewart wrote:I've heard older versions of IRIX run better with 64MB, so I may downgrade the OS instead.
Seems like you need to talk to SAQ.
jpstewart
Unread postby jpstewart » Fri Dec 03, 2010 4:25 pm
Thanks to Mike in this For Sale thread, I've finally been able to upgrade to a reasonable amount of RAM at a reasonable price. I got 2x128MB kits from him and now my Indigo2 totals 320MB. It swaps a lot less (obviously!) and so it now performs surprisingly well as long as you keep in mind that it is a 15 year old computer.
hinv -vm
Main memory size: 320 Mbytes
EISA bus: adapter 0
IMPACT Compression: unit 0, revision 0:0
Oh, yes: I also scored an IMPACT Compression card off of eBay last month (although I'd be willing to bet that that seller was also a forum member here). I guess I'll have to excavate down to make some desk space near the I2 for some video gear!
HP C8000
jpstewart
Re: Indigo2 R4400 250MHz, 320MB, SI, Impact Compression
Unread postby jpstewart » Sat Dec 04, 2010 7:49 am
Edited the original post to change the thread title to reflect the new configuration.
HP C8000
