> 2 serial ports on Octane
Axatax
Unread postby Axatax » Fri Sep 03, 2010 1:54 pm
Anyway to add additional serial ports to an Octane besides that ridiculous 6x serial XIO card or a terminal server? Maybe a PCI card I could put in the shoebox?
:Octane2: Dual R14K@600MHz, 2GB RAM, V12, 1x72GB HDD
:O2: R10K@175MHz, 512MB RAM, 1x72GB HDD
:Cube: 68040@33MHz, 128MB RAM, NeXTdimension 32MB, 2x 4.3GB HDD
...And lots of other UNIX-like systems for which there is no icon.
kshuff
Re: > 2 serial ports on Octane
Unread postby kshuff » Fri Sep 03, 2010 2:15 pm
What's wrong with the XIO card?
-ks
See them all >here<
Unread postby recondas » Fri Sep 03, 2010 4:04 pm
Axatax wrote:Maybe a PCI card I could put in the shoebox?
PCI?
SGI marketed a two-port PCI Serial I/O Option Board <part number 030-1657-003>.
While the PCI Serial I/O Option Board would physically fit into the 5V PCI slots used by the Octane <it's a "universal" PCI card, keyed to fit either 3.3 or 5 volt PCI slots>, I only know of drivers for the next the next generation of systems <the Fuel/O300/O350/O3k/etc.>.
So you'd probably have to do some research to find out if it'd work in an Octane - or try one to see if you get lucky.
There's a photo of one in the IRIX compatible PCI Cards - A Visual Aggregation thread.
skywriter
Unread postby skywriter » Fri Sep 03, 2010 5:28 pm
what's so ridiculous about the quad ethernet/6 serial port card? how many serial port options beside the dials+buttons box did sgi carry?
:Skywriter:
DECUS Member 368596
Unread postby SAQ » Fri Sep 03, 2010 8:31 pm
skywriter wrote:what's so ridiculous about the quad ethernet/6 serial port card? how many serial port options beside the dials+buttons box did sgi carry?
I wonder if it's cost.
skywriter
Unread postby skywriter » Fri Sep 03, 2010 10:46 pm
i bought 12 for $25 a piece several years ago.
i need the 6 ports for all my dials and buttons (some day), and to trunk the 100baseT's. of course that was before a gige card was know to work instead; better to only manage one TCP stack, than four. i wonder if there was any optimization for that. i suspect so... but who truly knows at this late date.
:Skywriter:
DECUS Member 368596
Unread postby jan-jaap » Sat Sep 04, 2010 3:46 am
The Digi ClassicBoard PCI works. Comes in 4 or 8 port versions.
I've got one in my Octane. You can still download IRIX drivers from Digi. I can't tell you if it works though, I don't have the required breakout cable ...
Axatax
Unread postby Axatax » Sat Sep 04, 2010 10:11 am
Thanks. I had completely forgotten about this.
I didn't want to use the XIO board since it seemed like overkill for a single serial port.
Unread postby SAQ » Sun Sep 05, 2010 8:34 am
It might be the cheapest option at this time, since anything PCI would require a shoehorn or shoebox.
Teddy
Unread postby Teddy » Mon Sep 06, 2010 1:10 am
I can confirm the PCI 2 Port Serial card (SGI P/N: 030-1657-003 Rev A) works in an octane ip30 running 6.5.29 with the PCI Shoebox adapter.
Tested and working ok with a Wacom graphics tablet!
Unread postby recondas » Mon Sep 06, 2010 3:17 am
jan-jaap wrote:The Digi ClassicBoard PCI works. Comes in 4 or 8 port versions.
Teddy wrote:I can confirm the PCI 2 Port Serial card (SGI P/N: 030-1657-003 Rev A) works in an octane ip30 running 6.5.29 with the PCI Shoebox adapter. Tested and working ok with a Wacom graphics tablet!
Thanks for the updates! I'll add both to the Octane Hardware Aggregator.
Users browsing this forum: Ahrefs [Bot], Baidu [Spider] and 2 guests
