SPARCstation 5 headless?
pilot345
Re: SPARCstation 5 headless?
Unread postby pilot345 » Tue Jul 20, 2010 4:44 pm
I used to run my SS5 as a router. I never changed anything in the PROM to run headless I dont think, I didnt need a serial console though. It booted up fine without a keyboard and monitor, it just would beep and complain, then keep booting I think. Then, like you want, I would just login over the network. So I guess give it a shot headless, but still set to keyboard and screen? Its been a while, I could be wrong....
zmttoxics
Unread postby zmttoxics » Tue Jul 20, 2010 5:58 pm
So just to run down the list for the fun of it...
-You disconnected the keyboard / mouse.
-You rebooted the machine (sans keyboard/ mouse).
-You are using a null modem cable and not a straight serial cable.
-You are using the standard 9600 / 8 / N / 1 / HW serial settings.
Right?
Try a 'set-defaults' with the keyboard and mouse hooked up in OBP then power down the machine, remove the gear and try again... Out side of that I am not sure what would be causing it. Good luck!
Stuff.
kjaer
Unread postby kjaer » Mon Jul 26, 2010 11:57 am
eMGee wrote:I'll try that, see if it can detect it, thanks for the advice.
I certainly would. Somebody messing with, for example, the sbus-probe-order list without knowing what he was doing could easily cause this kind of problem.
tingo
Unread postby tingo » Thu Aug 05, 2010 11:22 am
FWIW, on my SS2 (as in SparcStation 2) I had to take out the graphics card in order for it to run headless. YMMV.
Torfinn
miod
Unread postby miod » Thu Aug 05, 2010 3:28 pm
tingo wrote:FWIW, on my SS2 (as in SparcStation 2) I had to take out the graphics card in order for it to run headless. YMMV.
This was caused by a bug in early OpenPROM 2.x versions (IIRC from 2.0 up to 2.3 inclusive).
SPARCstation 5 ought to have OpenPROM >= 2.9 and default to serial if no keyboard is connected, even with a framebuffer installed.
Now, if this machine is actually a Cycle 5 upgrade of an SS2 into an SS5, keeping the SS2 chassis, the serial ports are actually an SS20-like multiplexed port connected to the enclosure `B' port (the `A' port being the parallel port).
Return to “Sun”
