Slow Spheres
Martin Steen
Slow Spheres
Unread postby Martin Steen » Thu May 20, 2010 11:42 pm
Just for teh lulz:
http://www.faktor0.de/sslow.gz
(single executable file compressed with gzip)
To start the program:
gunzip sslow.gz
chmod 755 sslow
./sslow
Required Nekoware SDL packages
(same as for "thieves"):
neko_sdl-1.2.13.tardist
neko_libiconv-1.11.tardist
neko_expat-2005-01-28.tardist
neko_gettext-0.17.tardist
neko_glib-2.12.13.tardist
neko_libcroco-0.6.1.tardist
neko_libxml2-2.6.27.tardist
neko_zlib-1.2.3-r1.tardist
neko_ncurses-5.7.tardist
neko_readline-4.3.tardist
snowolf
Re: Slow Spheres
Unread postby snowolf » Thu May 20, 2010 11:49 pm
Very cool! Is the source code available by any chance? :]
:Indigo: :Octane: :PI:
squeen
Re: Slow Spheres
Unread postby squeen » Mon May 24, 2010 3:28 am
Looks cool. Can't wait to try it.
Geoman
Re: Slow Spheres
Unread postby Geoman » Tue May 25, 2010 12:58 am
again: fine piece of work!
:Indy: :O2: :O2: :Indigo: :Indigo2IMP: :Indigo2IMP: :Octane: :Octane2: :Octane2:
Martin Steen
Re: Slow Spheres
Unread postby Martin Steen » Tue May 25, 2010 9:42 am
snowolf wrote:Very cool! Is the source code available by any chance? :]
Not yet. I have to clean up the code before I show it to the public.
Re: Slow Spheres
Unread postby hamei » Thu May 27, 2010 11:14 am
Martin Steen wrote: I have to clean up the code before I show it to the public.
I keep the door to my bedroom closed, too :D
squeen
Re: Slow Spheres
Unread postby squeen » Fri May 28, 2010 3:59 am
On the Onxy with default gamma, the spheres are a bit too white. Is there a command-line option for gamma correction?
Also, have you thought of submitting this to Xscreensaver?
Martin Steen
Re: Slow Spheres
Unread postby Martin Steen » Thu Jun 03, 2010 2:38 am
squeen wrote:On the Onxy with default gamma, the spheres are a bit too white. Is there a command-line option for gamma correction?
You're right!
I must add some commandline-options. If I can manage it, I do an update this weekend.
squeen wrote:Also, have you thought of submitting this to Xscreensaver?
No. But thank you for the hint!
canavan
Re: Slow Spheres
Unread postby canavan » Sat Jun 05, 2010 5:03 am
A nekoware-style tardist.
neko_sslow-0.0.tardist
(310 KiB) Downloaded 266 times
Martin Steen
Re: Slow Spheres
Unread postby Martin Steen » Sun Jun 06, 2010 7:25 am
Unfortunatelly, the SGI implementation of SDL does not support SDL_SetGamma.
But you can change the size and the number of the spheres now with two new
commandline-options:
-num <n> - set number of spheres (2..512) default=64
-size <s> - set size of spheres (0.2 .. 5.0) default=1.0
Example: ./sslow -num 16 -size 0.5
The new executable is here:
There is also a soundtrack for the program to get you into the right mood:
http://www.faktor0.de/music/slow_spheres.mp3
(ca 15 minutes of ambient noise, size = 14MB)
Martin Steen
Re: Slow Spheres
Unread postby Martin Steen » Sun Jun 06, 2010 7:31 am
canavan wrote:A nekoware-style tardist.
Wow, thanks!
Since I never learned how to make a tardist, I am happy if somebody is doing it!
canavan
Re: Slow Spheres
Unread postby canavan » Sun Jun 06, 2010 9:17 am
The required bits to re-generate a new tardist are part of the archive itself in the opt.dist component. You could either use the swpkg tool for a nice GUI to package editing and generation, or edit the .idb to add/remove files or change their location, or the .spec to change versions, dependencies, package names and descriptions. If you want to start from scratch, a number of scripts have been posted here to automate package generation, my attempt is attached to a thread discussing pixie.
Bill622
Re: Slow Spheres
Unread postby Bill622 » Tue Jun 08, 2010 4:53 am
Newbie question: could it be used as a screen saver on my SGI ?
Strangly, girls talks to me when I walk with my O2?!
Image R12k @ 300MHz, 384Mb Ram
mis
Re: Slow Spheres
Unread postby mis » Fri Jun 11, 2010 10:18 am
Hey everyone
i saw the screenshot and thought why not try that on my O2 R5200 300 mhz
i installed all the parts and ran it
hoever i then get this
Trace/BPT/RangeErr/divZero/Ovflow trap (core dumped)
Any ideer what thats all about or some way i can solve it so i can check it out ?
best reguards
mis
Best regards
MIS
Re: Slow Spheres
Unread postby nekonoko » Fri Jun 11, 2010 10:23 am
mis wrote:i installed all the parts and ran it
That's usually an indication you're trying to run software compiled on 6.5.21+ on a a lesser version.
